his is really amazing work! And with the B&O releasing the open API and this component for Home Assistant is mind blowing! I’m really impressed with B&Os commitment to the longevity of their products.
Not to sound ungrateful, but I don’t suppose there’s a chance of them expanding this component to also cover the old “BeoPlay” platform?
Hi guys. Im brand new to the HA world, and Im wondering if any of you got Beremote Halo to work? I have tried to install this: GitHub - bang-olufsen/beoremote-halo: Beoremote Halo Open API through HACS but with no luck.
Really want the Halo to work. Any ideas?
I’ve made an automation that announces which other product in the home I’m joining, when making a long press on the Play/Pause button. It’s using the built-in Overlay TTS function in the Mozart speaker, so it does not stop what’s playing, it just lowers the volume and plays the announcement on top.
alias: "Long press on Mozart speakers "
description: Tells which room is joined
### If long press on Play/pause on Beosound Level
- platform: device
device_id: b95e76a87142de088e4466c8a8e6f585
domain: bangolufsen
type: PlayPause_longPress
### If long press on Play/pause on Beosound Emerge
- platform: device
device_id: ce3c4cf11bc51e0bc34f52ee2c988743
domain: bangolufsen
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
### Only speak if there is something to join
- wait_template: >-
{{state_attr("media_player.beosound_level","beolink").leader is defined}}
continue_on_timeout: false
timeout: "2"
- delay:
milliseconds: 700
### Say which prodict has been joined. It will use the Friendly name of the product
- service: bangolufsen.overlay_audio
volume_offset: 20
tts: >-
Joined {{(state_attr("media_player.beosound_level","beolink").leader | list).0}}
tts_language: en-us
entity_id: media_player.beosound_level
- conditions:
sequence:
- wait_template: >-
{{state_attr("media_player.beosound_emerge","beolink").leader is defined}}
timeout: "2"
- delay:
milliseconds: 700
volume_offset: 20
tts: >-
Joined {{(state_attr("media_player.beosound_emerge","beolink").leader | list).0}}
tts_language: en-us
entity_id: media_player.beosound_emerge
mode: single
I’ve been using my own Nodered flow since the launch of CI features on Halo, and it’s working perfect for me.
Here is my sample flow: Pastiebin.com 626c3976a94e8
Go in anc change the websocket in and out to be ws://:8080 and press the ‘send configuration manully’ button, you should be able to swipe up on your halo and see 4 buttons.
Hmm weird. Are you using the HA Nodered add-on? As far as I know all the needed “modules” are installed by default when using the add-on (websocket in/out, delay node, etc.).
I did a restart and now I can see the buttons. That is awesome. So just a newbie question. If I want to control the lights in my “Stue” which is my living room. The only thing I need to change is the state_changed: and pick the light? Do I also need to change the HA server? I can see now that it says CK Home Assistant.
Basically, all the fields where there is a comment next to, you should change to fit your system. So yes, it should connect to YOUR HA server. And in regards to the light, you need to insert your light entity in 2 places, as shown on this image.
Yes, you can.
You have probably seen the function node that says PRIMARY. That is the configuration that lets Halo know what you have. So in there you need to add another light too, and give it a unique id (just change some characters in the end or something). Otherwise the button never shows up:)
Then take that new unique id and put into the Light subflow node that you duplicated. This will ensure that all updates are sent to the new button you just created.
You can have up to 8 buttons in one row, and up to 3 rows.
Hi CMDK, first of all thank you very much for your wonderful work… Last week I’ve added a Beosound Balance with no problem but today I tried to add the couple of Beolab 28 and got this:
Logger: homeassistant.config_entries
Source: custom_components/bangolufsen/select.py:127
Integration: Bang & Olufsen (documentation, issues)
First occurred: 11:15:14 (6 occurrences)
Last logged: 13:36:31
Error setting up entry Beolab 28 for bangolufsen
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 372, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/bangolufsen/__init__.py", line 67, in async_setup_entry
if not await init_entities(hass, entry):
File "/config/custom_components/bangolufsen/__init__.py", line 163, in init_entities
selects.append(BangOlufsenSelectSoundMode(entry))
File "/config/custom_components/bangolufsen/select.py", line 88, in __init__
self._initial_setup()
File "/config/custom_components/bangolufsen/select.py", line 101, in _initial_setup
self._attr_current_option = self._get_sound_mode_name(active_sound_mode.id)
File "/config/custom_components/bangolufsen/select.py", line 127, in _get_sound_mode_name
return [x for x in self._sound_modes if self._sound_modes[x] == sound_mode_id][
IndexError: list index out of range
