I’ve created a custom cover component to control my driveway gates but am having issues trying to set the state of the frontend buttons.
When the gates are closed, there is the option to open and stop as expected. When I click open I can stop the gates but once stopped, I can only continue to open the gates. What I would like is the ability to hit close.
There’s no reason for the gates to have to fully open before closing again.
Is there any way to override the open/close buttons to allow them to be clicked when the cover is in the “stopped” state and just after open/close has been clicked? The gates will accept “close” when they are opening or stopped and will immediately close the gates.
The component code is below. Note I only have a “moving” state and not opening/closing as it’s difficult to determine this from the manufacturer’s API.
"""Platform for the BFT cover component."""
import logging
import requests
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.components.cover import CoverDevice, PLATFORM_SCHEMA
from homeassistant.helpers.event import track_utc_time_change
from homeassistant.const import (
CONF_DEVICE,
CONF_USERNAME,
CONF_PASSWORD,
CONF_ACCESS_TOKEN,
CONF_NAME,
STATE_CLOSED,
STATE_OPEN,
CONF_COVERS,
_LOGGER = logging.getLogger(__name__)
ATTR_AVAILABLE = "available"
ATTR_TIME_IN_STATE = "time_in_state"
DEFAULT_NAME = "BFT"
STATE_MOVING = "moving"
STATE_OFFLINE = "offline"
STATE_STOPPED = "stopped"
STATES_MAP = {
"open": STATE_OPEN,
"moving": STATE_MOVING,
"closed": STATE_CLOSED,
"stopped": STATE_STOPPED,
COVER_SCHEMA = vol.Schema(
vol.Optional(CONF_ACCESS_TOKEN): cv.string,
vol.Optional(CONF_DEVICE): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_PASSWORD): cv.string,
vol.Optional(CONF_USERNAME): cv.string,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
{vol.Required(CONF_COVERS): cv.schema_with_slug_keys(COVER_SCHEMA)}
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the BFT covers."""
covers = []
devices = config.get(CONF_COVERS)
for device_name, device_config in devices.items():
args = {
"name": device_config.get(CONF_NAME),
"device": device_config.get(CONF_DEVICE),
"username": device_config.get(CONF_USERNAME),
"password": device_config.get(CONF_PASSWORD),
"access_token": device_config.get(CONF_ACCESS_TOKEN),
covers.append(BftCover(hass, args))
add_entities(covers)
class BftCover(CoverDevice):
"""Representation of a BFT cover."""
def __init__(self, hass, args):
"""Initialize the cover."""
self.particle_url = "https://ucontrol-api.bft-automation.com"
self.dispatcher_api_url = (
"https://ucontrol-dispatcher.bft-automation.com/automations"
self.hass = hass
self._name = args["name"]
self.device_name = args["device"]
self.device_id = None
self.access_token = args["access_token"]
self.obtained_token = False
self._username = args["username"]
self._password = args["password"]
self._state = None
self.time_in_state = None
self._unsub_listener_cover = None
self._available = True
if self.access_token is None:
self.access_token = self.get_token()
self._obtained_token = True
if self.device_id is None:
self.device_id = self.get_device_id()
try:
self.update()
except requests.exceptions.ConnectionError as ex:
_LOGGER.error("Unable to connect to server: %(reason)s", dict(reason=ex))
self._state = STATE_OFFLINE
self._available = False
self._name = DEFAULT_NAME
except KeyError:
_LOGGER.warning(
"BFT device %(device)s seems to be offline", dict(device=self.device_id)
def __del__(self):
"""Try to remove token."""
if self._obtained_token is True:
if self.access_token is not None:
self.remove_token()
@property
def name(self):
"""Return the name of the cover."""
return self._name
@property
def should_poll(self):
"""No polling needed for a demo cover."""
return True
@property
def available(self):
"""Return True if entity is available."""
return self._available
@property
def device_state_attributes(self):
"""Return the device state attributes."""
data = {}
if self.time_in_state is not None:
data[ATTR_TIME_IN_STATE] = self.time_in_state
data[CONF_ACCESS_TOKEN] = self.access_token
return data
@property
def is_closed(self):
"""Return if the cover is closed."""
if self._state is None:
return None
return self._state == STATE_CLOSED
@property
def device_class(self):
"""Return the class of this device, from component DEVICE_CLASSES."""
return "door"
def get_token(self):
"""Get new token for usage during this session."""
args = {
"grant_type": "password",
"username": self._username,
"password": self._password,
url = "{}/oauth/token".format(self.particle_url)
ret = requests.post(url, auth=("particle", "particle"), data=args, timeout=10)
try:
return ret.json()["access_token"]
except KeyError:
_LOGGER.error("Unable to retrieve access token %s")
def get_device_id(self):
"""Get device id from name."""
url = "{}/api/v1/users/?access_token={}".format(
self.particle_url, self.access_token
ret = requests.get(url, timeout=10)
for automations in ret.json()["data"]["automations"]:
if automations["info"]["name"] == self.device_name:
_LOGGER.debug("UUID: %s" % automations["uuid"])
_LOGGER.debug("Device Name: %s" % automations["info"]["name"])
return automations["uuid"]
def remove_token(self):
"""Remove authorization token from API."""
url = "{}/v1/access_tokens/{}".format(self.particle_url, self.access_token)
ret = requests.delete(url, auth=(self._username, self._password), timeout=10)
return ret.text
def _start_watcher(self, command):
"""Start watcher."""
_LOGGER.debug("Starting Watcher for command: %s ", command)
if self._unsub_listener_cover is None:
self._unsub_listener_cover = track_utc_time_change(
self.hass, self._check_state
def _check_state(self, now):
"""Check the state of the service during an operation."""
self.schedule_update_ha_state(True)
def close_cover(self, **kwargs):
"""Close the cover."""
if self._state not in ["close"]:
ret = self._put_command("close")
self._start_watcher("close")
return ret.get("status") == "done"
def open_cover(self, **kwargs):
"""Open the cover."""
if self._state not in ["open"]:
ret = self._put_command("open")
self._start_watcher("open")
def stop_cover(self, **kwargs):
"""Stop the door where it is."""
if self._state not in ["stopped"]:
ret = self._put_command("stop")
self._start_watcher("stop")
return ret["status"] == "done"
def update(self):
"""Get updated status from API."""
try:
status = self._get_variable("diagnosis")
self._state = self._get_gate_status(status)
_LOGGER.debug(self._state)
except KeyError:
_LOGGER.warning(
if self._state not in [STATE_MOVING]:
if self._unsub_listener_cover is not None:
self._unsub_listener_cover()
def _get_gate_status(self, status):
"""Get gate status from position and velocity."""
_LOGGER.debug("Current Status: %s", status)
first_engine_pos_int = status["first_engine_pos_int"]
second_engine_pos_int = status["second_engine_pos_int"]
first_engine_vel_int = status["first_engine_vel_int"]
second_engine_vel_int = status["second_engine_vel_int"]
if (
(first_engine_pos_int == 100 and second_engine_pos_int == 100)
and (first_engine_vel_int == 0 and second_engine_vel_int == 0)
_LOGGER.warning("open")
return STATES_MAP.get("open", None)
if (
and (first_engine_pos_int > 0 or second_engine_pos_int > 0)
_LOGGER.warning("stopped")
return STATES_MAP.get("stopped", None)
if (
(first_engine_pos_int == 0 and second_engine_pos_int == 0)
_LOGGER.warning("closed")
return STATES_MAP.get("closed", None)
if first_engine_vel_int > 0 or second_engine_vel_int > 0:
_LOGGER.warning("moving")
return STATES_MAP.get("moving", None)
def _get_variable(self, var):
"""Get latest status."""
api_call_headers = {"Authorization": "Bearer " + self.access_token}
url = "{}/{}/execute/{}".format(self.dispatcher_api_url, self.device_id, var)
_LOGGER.debug(url)
ret = requests.get(url, timeout=10, headers=api_call_headers)
return ret.json()
def _put_command(self, func):
"""Send commands to API."""
url = "{}/{}/execute/{}".format(self.dispatcher_api_url, self.device_id, func)
_LOGGER.debug(url)
return ret.json()
