I’ve just purchase BG WIFI 2-Gang SP Weatherproof Socket hoping I could intergrate it into HA. Should of checked first
Any ideas on how I can intergrate this into HA?
It looks.like the usual BG ones, have a read here it shows how to get it into HA using the broadlink app
Perfect, switched to the broadlink app and intergated into HA.
Thank you!
Any news on this?
I’ve just installed some but the broadlink all refuses to pair with them. They’ve paired fine with the BG app but I need to add them to HA.
Sorted this - used the wife’s phone as a hotspot with the same name as my Google mesh (can’t be split into 2.4 & 5) and unplugged the Google mesh. Joined the hotspot with my phone and put the sockets into pairing mode (hold the power button until fast flashing)
Joined the BG sockets using the broadlonk app and made sure to select them as a power strip device -General WiFi Device does not work. (I had to block the rest of the house from joining the hotspot as it has a 10 device limit)
Killed off the hotspot and powered up the Google mesh, waited a few seconds and the sockets joined the network.
Once joined I was able to unlock the sockets and then add them manually to home assistant.
I created these instructions for myself about a year ago.
They might be still relevant, but posting here for others in case they are. Hope they help.
Hello, Sygad,
Which version of broadlink do you use please because i am struggling to get any of the versions to connect to the switches.
The Broadlink app I have installed says it is version 1.7.14
Since I wrote those instructions I have updated my phone, but I have not yet had cause to use the app again.
registered an account to reply to this. The steps still works after 2 years
thanks Darren.
April 2025 - still works a treat. ![]()
I have a similar issue with my sockets. Purchased and installed today, they flash red but no local wifi is created (BGHome-xxxxx) therefore both Smart and AP setup mode fail. Sockets deliver power correctly but are otherwise dumb at the moment.
Update: After a few hours of me doing nothing, then trying again, the BGHome SSID was broadcast. I set up the device in the BG Home app, assigned a room, and then Home Assistant spotted the device and added the integration. No need for the Broadlink app.
Do these communicate locally with home assistant? Or do they have to go to the cloud?
I have 3 of these double socket and they work fine, setup was easy. Please note that I’m using the Broadlink app with them not the BG Home app. Oh and yes they do run locally.
I currently have four of these sockets set up in the BG app. What would be the best way to add them to HA in year 2025? Thanks
Can you please share the model number of the BG socket, looking at one at Screwfix WP22.
British General IP66 13A 2-Gang SP Weatherproof Outdoor Switched Smart Wi-Fi Controlled Socket - Screwfix for just over £20 with discount code
