UPDATE As I was writing this I upgradded to the latest version, and the problem has gone away. I think it was the full reset of Hass.io rather than 0.67 fixing some bug. I’m going to post this anyway as the solution seemed to be a full restart of Hass.io, rather then just restarting Home Assistant. If it happens with my next one, I’ll capture relevant info from OZW and open a bug.
I’m trying to add a new Philio PAN11-4 switch to my zwave network, I already have one up and running so I know the devices work on my network.
When you first switch it on it goes into auto-setup mode, and you’re supposed to start the inclusion process on your controller, which I did through the ZWave config page in Home Assistant, it’s found the device, but it hasn’t given it an identifier for the switch or one of the sensors. It’s also not saved the device to zwcfg either.
I left the device overnight to see if it would correct itself but it’s still the same this morning (day 2).
Yesterday (day 2) I tried to remove/exclude the node from the network, and I thought I had so I went to include it again, and now (day 3) I have 2 devices, with id’s 14 & 15, 14 being the original. Overnight one has been marked as failed, so I went to remove it via the config interface and while the OZW log suggests it tried, nothing in the UI seems to have changed.
The network itself is healthy, looking in the OZW logs the other devices see ID:15 as a neighbor, and don’t list ID:14 as one.
