i have 2 questions, but first i show you my configuration:
i have HA in version 0.60.1 and my blinds are without servo, but a type like this: https://youtu.be/GOd1n4p5Eic
So, the best choice is to use the SonOff with MQTT or eMylo® AC 220V with Broadlink?
And, in case, which is the command in MQTT to control UP/DOWN the blind? because i use sonoff with a light and is a simply ON/OFF command, but in case of blinds?
Thanks for the reply.
I have a SonOff Dual R2, so i can use one sonoff… no problem, thanks.
But i don’t know whick commands i need to use the sonoff with blinds because (if possible) i want two buttons with “Open” and “Close” , so the blinds open and close with only one click… then maybe a button or a slider for the medium adjustments… i don’t know how can use this sonoff?
After you configure the two relays of the Sonoff Dual, create an automation to activate the UP and DOWN functions. UP connected to one relay and DOWN to the other relay.
For now i made only tests…
I have a raspberry with HA, use SonOff for two lightts and now i want to try the blinds, never use Arduino or other devices. I have only a Broadlink rm pro (a present) so i don’t know if is the best choice or if the best way is the Sonoff Dual for test the blinds
Ok, thank you. so i can try to flash with Tasmota Firmware and then try with the blinds… because i have some problems (with sonoff basic i made it in 2 minutes -.- )
Thank you!
