Blink a light when someone new follow me on instagram (no ifttt)
Hello everyone, first post form me.
I try to make an automation who is trigged when i have a new follower on Instagram.
Exemple: The number of followers increase from 70 to 71 (whawoo!) β†’ switch on and off the light.
I figured out how to gate the number of followers and create a sensor (Thank napsio)
- platform: scrape
    resource: https://www.instagram.com/######/
    name: instagram followers
    select: 'meta[name="description"]'
    attribute: content
    value_template: '{{ value.split(" ")[0] }}'
Ok now i have the sensor. So i try this:
 - alias: 'instagram'
   initial_state: False
     platform: template
       value_template: '{{ states.sensor.instagram_followers | int + 1 }}'
     - service: scene.turn_on
       entity_id: scene.flash_instagram
     - delay: '00:00:03'
     - service: light.turn_off
       entity_id: light.neopixel_light
But it doesn’t work.
If someone can help me. thank by advance.
Please read this, particularly point 11: How to help us help you - or How to ask a good question
Your template will never trigger. All this does:
is add 1 to your current sensor value. Or it would if it was correctly reading the sensor state. It should be: states.sensor.instagram_followers.state , or preferably states('sensor.instagram_followers')
You could use the trend sensor:
Also see this post for another option:
