Blink Camera Outdoor not showing live stream
hey didnt see this, it is part of the automations and scenes, just create a new scene and either edit it in the yaml as provided above or through the gui if that is your preference.
Hi, I cannot get this to work. I believe some of the services have recently been deprecated? Does anyone have an updated working example please?
same here!!
I am also getting an error saying that the blink.blink_update is deprecated and will be removed. Is there a workaround at all?
It’s work if you use homeassistant.update_entity to replace blink update
Is there something I’m missing? I think asking for a live video stream is already implemented in blinkpy, which returns a standard rtsps stream.
Docs here:
So it should be very straightforward to implement this in home assistant.
Any updates for this?
If a motion only stream with some latency is acceptable, this will get you an RTSP stream: Blink camera -> RTSP bridge (for Frigate, etc.)
New user here, just went through this and it works great using the homeassistant.update_entity action. Thanks guys
