Is it possible to define an input for a blueprint, where the user can select either a weather service or a temperature entity? I.e. the select should list all weather and all temperature entities and the user can select one item from the list?
input:
temperature_entity:
default: "weather.home"
selector:
entity:
filter:
- domain:
- weather
- device_class:
- temperature
Note: the dash ("-") before the “device_class” is crucial since it leads to two filters which are (apparently) combined with OR. Without the dash, one filter is created, which combines its properties with AND!
@Sir_Goodenough thanks for your feedback, my question was not completely on point, as I did not realize then, that “weather” is just an entity.
