Blueprint - Tuya 2 button scene switch - TS0042 - Zigbee2MQTT
Blueprint for Tuya 2 button switch.
Model: TS0042
Vendor: Tuya
Based on: Blueprint from Stinger 4 button switch (Profile - Stringer - Home Assistant Community)
Actions:
  1. Short press
  2. Double press
  3. Long press (5 seconds)
Two versions below! One with or without the action attribute.
OLD (with Action)
blueprint (OLD with Action):
  name: Zigbee2MQTT - Tuya 2-Button Scene Switch OLD
  description: Automate your Tuya 2-Button Scene Switch via Zigbee2MQTT.
  domain: automation
  input:
    switch:
      name: Tuya 2-Button Scene Switch
      description: Tuya 2-Button Scene Switch to use
      selector:
        entity:
          integration: mqtt
          domain: sensor
    button_one_short_press:
      name: Single Press - Button 1
      description: Action to run on button 1 (lower-left) single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Double Press - Button 1
      description: Action to run on button 1 (lower-left) double press
      default: []
      selector:
        action: {}
    button_one_long_press:
      name: Long Press - Button 1
      description: Action to run on button 1 (lower-left) long press
      default: []
      selector:
        action: {}
    button_two_short_press:
      name: Single Press - Button 2
      description: Action to run on button 2 (lower-right) single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Double Press - Button 2
      description: Action to run on button 2 (lower-right) double press
      default: []
      selector:
        action: {}
    button_two_long_press:
      name: Long Press - Button 2
      description: Action to run on button 2 (lower-right) long press
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
- platform: state
  entity_id: !input 'switch'
  attribute: action
- variables:
    command: '{{ trigger.to_state.state }}'
- choose:
  - conditions:
    - '{{ command == ''1_single'' }}'
    sequence: !input 'button_one_short_press'
  - conditions:
    - '{{ command == ''2_single'' }}'
    sequence: !input 'button_two_short_press'
  - conditions:
    - '{{ command == ''1_double'' }}'
    sequence: !input 'button_one_double_press'
  - conditions:
    - '{{ command == ''2_double'' }}'
    sequence: !input 'button_two_double_press'
  - conditions:
    - '{{ command == ''1_hold'' }}'
    sequence: !input 'button_one_long_press'
  - conditions:
    - '{{ command == ''2_hold'' }}'
    sequence: !input 'button_two_long_press'
New Without action line:
blueprint (new one without Action):
blueprint:
  name: Zigbee2MQTT - Tuya 2-Button Scene Switch 2501-01
  domain: automation
  input:
    switch:
      selector:
        entity:
          integration: mqtt
          domain: sensor
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
mode: restart
  - platform: state
  - variables:
  - choose:
      - conditions:
      - conditions:
      - conditions:
      - conditions:
      - conditions:
      - conditions:
I had to erase this line to get it working.
Thanks. I had the same problem. :clap:
Hello, the script works well for one device. But I have a second identical device and it is impossible to have the actions (single press, double press and long press for buttons 1 and 2). How to add this script to the second device.Thanks.
Hi, I had the same problem, I removed the string but only the 1st Action from the first button is working, the others are not.
Any idea ?
Hi, I bought a Tuya Scene switch TS0042. I’m able to add it as a zigbee device but automation won’t work. New to Blueprint. Would you mind guiding me on how to configure the Blueprint please?
Yes, had to remove this as well, now it works on both buttons.
Worked great for a long time, but unfortunately hasn’t worked at all since the beginning of the year. No error message, it just doesn’t work anymore. I’ve tried both versions, manually commented out the action attribute, but no luck. Anyone got any ideas?
Edit: Found the problem:
Only breaking when legacy is enabled:
  • All click sensors have been removed (homeassistant.legacy_triggers setting). This means all sensor.*_click entities are removed. Use the MQTT device trigger instead.
More Information here:
Someone mentioned to add the following to configuration.yaml, this broke my entire HA:
homeassistant:
  legacy_action_sensor: true
Tried it fow now with device trigger (settings-> automations). Bit had no time to test it yet.
