Blueprint - Tuya 4 button scene switch - TS004F - Zigbee2MQTT
Blueprint for Tuya 4 button switch. Inspired by Tweeterhub
Model: TS004F
Vendor: Moes, Tuya
Based on: Blueprint - Tuya 2 button scene switch - TS0042 - Zigbee2MQTT
Actions:
  1. Short press
  2. Double press
  3. Long press (5 seconds)
blueprint:
  name: Zigbee2MQTT - Tuya 4-Button Scene Switch 2501-01
  description: Automate your Tuya 4-Button Scene Switch via Zigbee2MQTT.
  domain: automation
  input:
    switch:
      name: Tuya 4-Button Scene Switch
      description: Tuya 4-Button Scene Switch to use
      selector:
        entity:
          integration: mqtt
          domain:
          - sensor
          multiple: false
          reorder: false
    button_one_short_press:
      name: Single Press - Button 1
      description: Action to run on button 1 (upper-left) single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Double Press - Button 1
      description: Action to run on button 1 (upper-left) double press
      default: []
      selector:
        action: {}
    button_one_long_press:
      name: Long Press - Button 1
      description: Action to run on button 1 (upper-left) long press
      default: []
      selector:
        action: {}
    button_two_short_press:
      name: Single Press - Button 2
      description: Action to run on button 2 (upper-right) single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Double Press - Button 2
      description: Action to run on button 2 (upper-right) double press
      default: []
      selector:
        action: {}
    button_two_long_press:
      name: Long Press - Button 2
      description: Action to run on button 2 (upper-right) long press
      default: []
      selector:
        action: {}
    button_three_short_press:
      name: Single Press - Button 3
      description: Action to run on button 3 (lower-left) single press
      default: []
      selector:
        action: {}
    button_three_double_press:
      name: Double Press - Button 3
      description: Action to run on button 3 (lower-left) double press
      default: []
      selector:
        action: {}
    button_three_long_press:
      name: Long Press - Button 3
      description: Action to run on button 3 (lower-left) long press
      default: []
      selector:
        action: {}
    button_four_short_press:
      name: Single Press - Button 4
      description: Action to run on button 1 (lower-right) single press
      default: []
      selector:
        action: {}
    button_four_double_press:
      name: Double Press - Button 4
      description: Action to run on button 1 (lower-right) double press
      default: []
      selector:
        action: {}
    button_four_long_press:
      name: Long Press - Button 4
      description: Action to run on button 1 (lower-right) long press
      default: []
      selector:
        action: {}
  source_url: https://github.com/tweeterhub/HomeAssistant/blob/main/Blueprint/Tuya-2button-ts0042_v2501-01.yaml
mode: restart
max_exceeded: silent
- platform: state
  entity_id: !input switch
- variables:
    command: '{{ trigger.to_state.state }}'
- choose:
  - conditions:
    - '{{ command == ''1_single'' }}'
    sequence: !input button_one_short_press
  - conditions:
    - '{{ command == ''2_single'' }}'
    sequence: !input button_two_short_press
  - conditions:
    - '{{ command == ''3_single'' }}'
    sequence: !input button_three_short_press
  - conditions:
    - '{{ command == ''4_single'' }}'
    sequence: !input button_four_short_press
  - conditions:
    - '{{ command == ''1_double'' }}'
    sequence: !input button_one_double_press
  - conditions:
    - '{{ command == ''2_double'' }}'
    sequence: !input button_two_double_press
  - conditions:
    - '{{ command == ''3_double'' }}'
    sequence: !input button_three_double_press
  - conditions:
    - '{{ command == ''4_double'' }}'
    sequence: !input button_four_double_press
  - conditions:
    - '{{ command == ''1_hold'' }}'
    sequence: !input button_one_long_press
  - conditions:
    - '{{ command == ''2_hold'' }}'
    sequence: !input button_two_long_press
  - conditions:
    - '{{ command == ''3_hold'' }}'
    sequence: !input button_three_long_press
  - conditions:
    - '{{ command == ''4_hold'' }}'
    sequence: !input button_four_long_press
