Blueprint with configurable boolean input and is_state() condition
I have the following blueprint and would like to query two boolean inputs in an is_state() condition. unfortunately this does not seem to work. the light is not dimmed or brightened.
blueprint:
  name: v5 Z2M IKEA STYRBAR Remote with Configurable Dimming Direction
  description: IKEA Remote Control with Zigbee2MQTT for controlling individual lamps with Left/Right buttons and two light groups with Up/Down buttons.
  domain: automation
  input:
    remote_topic:
      name: Zigbee2MQTT Remote Topic
      description: Enter the MQTT topic of your IKEA remote (e.g., "zigbee2mqtt/MB - SW - Schreibtisch").
      selector:
        text: {}
    lights_up_down:
      name: Lights for Up/Down
      description: Lights to control for brightness up, down, on, and off.
      selector:
        entity:
          domain: light
          multiple: true
    light_left:
      name: Light for Left Button
      description: Light to control with the Left button.
      selector:
        entity:
          domain: light
          multiple: false
    light_right:
      name: Light for Right Button
      description: Light to control with the Right button.
      selector:
        entity:
          domain: light
          multiple: false
    dimming_direction_left:
      name: Helper for Dimming Direction (Left Button)
      description: Input Boolean entity to track dimming direction for the Left button.
      selector:
        entity:
          domain: input_boolean
    dimming_direction_right:
      name: Helper for Dimming Direction (Right Button)
      description: Input Boolean entity to track dimming direction for the Right button.
      selector:
        entity:
    helper_step_up:
      name: Brightness step up
      default: 10
      selector:
        number:
          min: 5
          max: 50
          mode: slider
          step: 5
    helper_step_down:
      name: Brightness step down
      default: -10
      selector:
        number:
          min: -50
          max: -5
          mode: slider
          step: 5
    helper_transition_dim:
      name: Dimming transition time (seconds)
      default: 0.5
      selector:
        number:
          min: 0.0
          max: 10.0
          mode: slider
          step: 0.5
    helper_pause:
      name: Pause between dimming steps (ms)
      default: 500
      selector:
        number:
          min: 100
          max: 2000
          mode: slider
          step: 100
mode: restart
max_exceeded: silent
triggers:
- platform: mqtt
  topic: !input remote_topic
variables:
  command: '{{ trigger.payload_json.action }}'
actions:
- choose:
  # On/Off for Lights Up/Down
  - conditions:
      - condition: template
        value_template: '{{ command == "on" }}'
    sequence:
      - service: light.turn_on
          entity_id: !input lights_up_down
  - conditions:
        value_template: '{{ command == "off" }}'
    sequence:
      - service: light.turn_off
  # Brightness Move Up/Down for Lights Up/Down
  - conditions:
        value_template: '{{ command == "brightness_move_up" }}'
    sequence:
      - repeat:
          count: 20
          sequence:
                brightness_step_pct: !input helper_step_up
                transition: !input helper_transition_dim
            - delay:
                milliseconds: !input helper_pause
  - conditions:
        value_template: '{{ command == "brightness_move_down" }}'
    sequence:
      - repeat:
          count: 20
          sequence:
                brightness_step_pct: !input helper_step_down
            - delay:
  # Toggle for Left Button
  - conditions:
        value_template: '{{ command == "arrow_left_click" }}'
    sequence:
      - service: light.toggle
          entity_id: !input light_left
  # Dim/Brighten for Left Button
  - conditions:
        value_template: '{{ command == "arrow_left_hold" }}'
    sequence:
      - repeat:
          count: 20
          sequence:
            - choose:
                - conditions:
                      value_template: '{{ is_state("{{ !input dimming_direction_left }}", "off") }}'
                  sequence:
                        brightness_step: !input helper_step_up
                - conditions:
                      value_template: '{{ is_state("{{ !input dimming_direction_left }}", "on") }}'
                  sequence:
                        brightness_step: !input helper_step_down
            - delay:
  # Toggle for Right Button
  - conditions:
        value_template: '{{ command == "arrow_right_click" }}'
    sequence:
          entity_id: !input light_right
  # Dim/Brighten for Right Button
  - conditions:
        value_template: '{{ command == "arrow_right_hold" }}'
    sequence:
      - repeat:
          count: 20
          sequence:
            - choose:
                - conditions:
                      value_template: '{{ is_state("{{ !input dimming_direction_right }}", "off") }}'
                  sequence:
                - conditions:
                      value_template: '{{ is_state("{{ !input dimming_direction_right }}", "on") }}'
                  sequence:
            - delay:
  # Switch Dimming Direction for Left Button on Release
  - conditions:
        value_template: '{{ command == "arrow_left_release" }}'
    sequence:
      - service: input_boolean.toggle
          entity_id: !input dimming_direction_left
  # Switch Dimming Direction for Right Button on Release
  - conditions:
        value_template: '{{ command == "arrow_right_release" }}'
    sequence:
          entity_id: !input dimming_direction_right
I think the problem is e.g. here in the is_state().
  - conditions:
    sequence:
      - repeat:
          count: 20
          sequence:
            - choose:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
            - delay:
Without looking very deep I spot two immediate issues:
  1. You cannot use !input inside a template. You must offload your input values into variables before using them in templates.
variables:
  dimming_direction_left: !input dimming_direction_left
  1. You cannot have a template inside of another template.
value_template: "{{ is_state(dimming_direction_left, 'off') }}"
value_template: "{{ is_state(dimming_direction_left, 'on') }}"
Start by fixing those issues.
Hi BoergiM87,
I agree. See this…
Blueprints: Get your !input value into a template.
