Blueprints: Get your !input value into a template
When you gather data in a blueprint using !inputs, you will need to use that data in the lower parts of the blueprint. All the native Home Assistant places accept the
!input my_data
format for this.
If you are using the value in a template, however, this does not work.
The code inside of the template brackets is all rendered by a jinja2 template engine, not Home Assistant. That engine does not know what the !input tag is. That is looking for a variable.
Therefore in order for template engine to see the value, it needs to be converted to a variable.
input:
  notification_id:
    name: Optional Persistent Notification ID
    default: []
    selector:
      text: {}
variables:
    # Get the notification_id into a variable.
  _notification_id: !input notification_id
- choose:
  - conditions: '{{ _notification_id | length > 0 }}'
    sequence:
    - alias: Notify interested parties WITH notification_id
      service: persistent_notification.create
        title: '{{ states[trigger.to_state.entity_id].name + '' Status'' }}'
        message: '{{ states[trigger.to_state.entity_id].name + '' is 'home' }} '
        notification_id: '{{ _notification_id }}'
This conversion / translation will work in both the variables: and trigger_variables: sections.
The Home Assistant Cookbook - Index.
FTR
variables:
works too, you can give the same name to the variable
Yup, it’s just easier to keep the straight if you do some naming convention like that.
