BMW Connected Drive Login Error
Hello All, anyone experience this issue with the BMW integration? When attempting to implement the integration I get an error “Failed to Connect”. Checked login details, logged in to myBMW and Connected Drive using same credentials via browser. The following messages appear in my logs:
2021-12-04 20:29:51 ERROR (SyncWorker_10) [bimmer_connected.account] Authentication failed (invalid_request): The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed
Any help would be appreciated.
PS:
Home Assistant OS, Version core-2021.11.4
I had a similar issue. Couldn’t add the integration when running 2021.11.5
Updated to 2021.12.1 and now it mostly works. Initially it gave an error when adding but had actually added it (i.e. I couldn’t add it again). Back at the integrations page it said “Not connected”
After restarting 2021.12.1 after adding the integration it has now pulled in 1 device (1 car) and 12 entities for that car so seems to be working. All data is correct too.
All good now I have upgraded
