That’s quite alright.
In fact, this might look like it’s more inline with what I am after. Really all I want at the moment is the icon mapping, e.g. pouring, lightning, rainy, etc.
Hi David, with the new BoM radar component, does yours cycle through the images properly? I have both the original custom_component and the new native one setup on the same Lovelace page but only the custom one cycles through images… the native one is just showing a single image.
Well thats given me two images, 30mins apart… not sure whats going on there. The delta: 600 should make them 10mins apart like the custom_component does.
It was only that I initially thought that I was previously using a ‘custom’ radar image other than the standard Perth one, but I later realised that it is actually my weather sensor location which is somewhat ‘custom’ compared to the base Perth one.
Now that I have adjusted the parameters of the BOM camera, it is working exactly as per the custom_component so I’ll be getting rid of that one from my config.
Did you even get the 512km composite working? All of my other scales work fine (I use an input_select to switch between views), but I get a black box for the 512km composite.
