Bosch 5000i air conditioning
I was also able to do add with Matter but it doesn’t work properly with the Thermostat type for dashboards
@andyet & @miguelaeg
How have you managed to add it into Home Assistant? What are the prerequisites (hardware?) and what steps are necessary to add it into Home Assistant?
Thanks in advance :slight_smile:
Hi all, I've had my Bosch 3000i units in Home Assistant over matter for a while and it works great.
But has anyone figured out if there is a way to change the increments on the fan controller from 20% to say 5 or even 1?
I tried changing in developer > states to test it. It changes the setting but doesn't transmit to the unit. Any ideas or is it just not supported?
