Bosch Easy control integration wanted!
HACS works and I see the “Bosch thermostat” integration in HACS, but when I want to add it in “Integrations” I only get the Bosch SHC integation that showes up. It’s been 14 hours since the installation. Strange.
Weird. There was one similar report some time ago that ended with a HA restart and a cleared Browser cache.
Hey Webeling,
That did it!!
Thx a lot for your help!
For me not even coming back its set temperature to selected one. but not getting any temperature back
Hi all,
I tried to integrate my CT200 but something is not working
First of all I’ve installed HACS, no issue there.
I registered my CT200 via the Bosch app on my phone
External services says that the device is online as last status
  1. Installed the Bosch Thermostat integration in HA
  2. Selected Eaycontrol
  3. Entered my Serial, Access Code (without spaces) and my password
Result “Failed to setup”
This is what I see in the logs:
Cannot connect to Bosch gateway, host My UID with UUID: None
8:34:05 PM – (ERROR) Bosch thermostat (custom integration)
Your device is unknown null
Couldn’t find device model. Got product ID: None
8:34:05 PM – (ERROR) /usr/local/lib/python3.9/site-packages/bosch_thermostat_client/gateway/easycontrol.py
What am I doing wrong here?
Sounds a bit like issues with connection to the EasyControl. Can you try to do a raw scan: Dev Raw Scan for the Bosch Devices · bosch-thermostat/home-assistant-bosch-custom-component Wiki · GitHub
That fixed it! thanks
I keep getting the same error as @RedC;
I have tried to run the raw scan and it’s keeps outputting;
Successfully connected to gateway. Found UUID: None
Then Nothing useful after with the following JSON output;
        "/systemStates": "not found"
        "/dhwCircuits": "not found"
        "/gateway": "not found"
        "/heatingCircuits": "not found"
        "/heatSources": "not found"
        "/notifications": "not found"
        "/system": "not found"
        "/solarCircuits": "not found"
        "/recordings": "not found"
        "/devices": "not found"
        "/energy": "not found"
        "/events": "not found"
        "/programs": "not found"
        "/zones": "not found"
        "/ecus": "not found"
        "/application": "not found"
        "/gservice_tariff": "not found"
Can someone help please.
I dont know what else to do
Thank
It will be possible to add Easycontrol to HA Energy Panel?
Hi there.
I would like to integrate my CT200 and valves, but I dont know where I can get access token. When I tried to register device, always when I tried to login with Bosh ID I got 403 access forbiden. Many thanks for your help.
Read the installation guide in GitHub. You need two passwords. One is on the sticker of the CT200 and the second one is in the Easycontrol app on your phone. Hope the documentation helps you through.
followed the instruction but getting error. mine is CT200 B. Could this be new model not supported by this integration?
Logger: bosch_thermostat_client.gateway.easycontrol
Source: custom_components/bosch/config_flow.py:164
Integration: Bosch thermostat (documentation, issues)
First occurred: 4:15:29 PM (1 occurrences)
Last logged: 4:15:29 PM
Hi, how did you manage to take the current indoor temperature on the screen?
Hi there, I am trying to integrate my Bosch EasyControl, however without success. I am running HA on HAOS (Intel NUC). All the numbers in the XMPP configuration are correct including a simple 8 character password without special characters. It keeps on saying “Cannot connect to Bosch gateway” and keeps on retrying. Any suggestion how to resolve this?
First of all great integration. Yesterday I installed the integration and connecting to the CT200 worked flawless.
Today I have installed Bosch EasyControl RT10-RF Smart Radiator Thermostats (5 in total) and connected them to the CT200. I can see, and control, them in the Bosch App but is there a way to see, and control, these radiator thermostats also in Home Assistant?
Sure. Use HACS and install the Bosch EasyControl integration. GitHub - bosch-thermostat/home-assistant-bosch-custom-component: HA custom component for Bosch thermostats
I’m trying to add our new Bosch CT 200 to Home Assistant, but repeatedly get the following error:
I tried a dozen of times, but no luck.
Does anyone here have an idea on how to fix this?
Thanks in advance.
Found this in the HA logs:
“ERROR (MainThread) [custom_components.bosch.config_flow] Error connecting Bosch at 1xxxxxxxx - Can’t authorize to XMPP server.”
The Bosch app on my Android phone authorizes just fine with the same credentials.
What am I missing here?
Please check the installation documentation. Home Assistant Installation Guide · bosch-thermostat/home-assistant-bosch-custom-component Wiki · GitHub
The text has some lines on issues reported.
