I’ve been trying for a while to connect my Bosch Thermostat II [+M] to my Home Assistant using Matter over Thread…
According to this guide, it should work relatively easy:
Unfortunately, I’m stuck at the “Connecting to device…” step shown on Smartphone.
My setup:
Home Assistant (everything up to date) on Raspberry Pi 5
I’ve already reconfigured the border router a few times and restarted Home Assistant afterwards… I’ve also tried connecting the thermostats countless times now – the connection process keeps failing
I’m completely out of ideas and would be incredibly grateful for any help!
Maybe these troubleshooting tips might be helpful:
Commisioning is initialized through a bluetooth connection between your phone and the TRV. Make sure bluetooth is enabled on your phone and the phone is in close range
make sure, your phone’s Wifi connection and the TBR are connected within the same broadcast domain
afaik ipv6 network connectivity is a requirement for matter/thread. Unique-Local Address (ULA) Scope should be suffiicient
use avahi-browse to check, if the TBR service is exposed:
Having experience with 4 different type of Thermostat devices I find this one would be the best, and I am in the process of replacing my remaining Aqara Thermostats by Bosch now.
My setup seats on top of zigbee2mqtt, and the same dongle is used: SONOFF ZBDongle-P.
