Bose Soundtouch - Source selection & presets
After integrating the Bose sound system - I found it a bit weird that the source switching wasn’t enabled by default. I kinda understand why now after digging through the APIs …- but it’s not an insurmountable issue that couldn’t be coded up in future. I also wanted to select my preset favourites (1-6) and that standard integration didn’t work for me out the box.
I figured there was a way to get it all working without digging in the standard integration, and I was right. I just couldn’t find an all in one guide. I hope that someone who’s a bit better (well - a developer) would be happy to take my learnings and update the standard integration. If someone who’s got a bit more time could write a custom-component out of my stuff?
Until then - here’s my all in one guide using standard components for changing source (TV, Spotify & Amazon Prime Music) and selecting presets 1->6. It does however require a bit of digging into how stuff’s set up in your environment.
Attributes you will need: tenacity, a brain, patience and troubleshooting.
Specific information you’ll need to substitute into the appropriate places in config:
  • IP address of your Bose Soundtouch device
  • spotify ID
  • email address you signed up for amazon with
URLs to get information to help you out after you’ve got your Bose Soundtouch’s IP address (substitute soundtouch-lounge for the ip address):
http://soundtouch-lounge:8090/info
http://soundtouch-lounge:8090/sources
http://soundtouch-lounge:8090/now_playing
If you want more than play button, preset buttons 1->6, spotify, amazon prime music and TV sources, have fun:
Bose API documentation: https://developer.bose.com/guides/bose-soundtouch-api/bose-soundtouch-api-reference (you’ll need a developer account - a few minutes to register)
Without further ado, here’s my set-up which I hope you can copy, paste and edit in a few minutes to get it all working (sans personal info?):
configuration.yaml
shell_command: # can place this into a !include shell_command.yaml
    #soundtouch - preset selectors (use release for selecting - press for setting preset to current playing)
    bose_preset_1_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PRESET_1</key>' http://<soundtouch ip address>:8090/key
    bose_preset_1_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PRESET_1</key>' http://<soundtouch ip address>:8090/key
    bose_preset_2_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PRESET_2</key>' http://<soundtouch ip address>:8090/key
    bose_preset_2_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PRESET_2</key>' http://<soundtouch ip address>:8090/key
    bose_preset_3_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PRESET_3</key>' http://<soundtouch ip address>:8090/key
    bose_preset_3_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PRESET_3</key>' http://<soundtouch ip address>:8090/key
    bose_preset_4_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PRESET_4</key>' http://<soundtouch ip address>:8090/key
    bose_preset_4_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PRESET_4</key>' http://<soundtouch ip address>:8090/key
    bose_preset_5_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PRESET_5</key>' http://<soundtouch ip address>:8090/key # used for setting if called on its own ... long press
    bose_preset_5_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PRESET_5</key>' http://<soundtouch ip address>:8090/key # used for press & release function
    bose_preset_6_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PRESET_6</key>' http://<soundtouch ip address>:8090/key
    bose_preset_6_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PRESET_6</key>' http://<soundtouch ip address>:8090/key
    bose_play_press: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="press" sender="Gabbo">PLAY</key>' http://<soundtouch ip address>:8090/key
    bose_play_release: curl -X POST -H 'application/xml;charset=utf-8'  -d '<?xml version="1.0" ?><key state="release" sender="Gabbo">PLAY</key>' http://<soundtouch ip address>:8090/key
    #soundtouch - source selectors
    bose_amazon_music: curl -X POST -H 'application/xml;charset=utf-8' -d '<?xml version="1.0" ?><ContentItem source="AMAZON" type="tracklist" location="library/playlists/A1F83G8C2ARO7P_3AB01FSVTHAY/#playable" sourceAccount="<your.email@address>"></ContentItem>' http://<soundtouch ip address>:8090/select #why can't I resume without specifying a 'location' aka track/playlist?
    bose_tv_source: curl -X POST -H 'application/xml;charset=utf-8' -d '<?xml version="1.0" ?><ContentItem source="PRODUCT" sourceAccount="TV"></ContentItem>' http://<soundtouch ip address>:8090/select
    bose_spotify: curl -X POST -H 'application/xml;charset=utf-8' -d '<?xml version="1.0" ?><ContentItem source="SPOTIFY" type="uri" sourceAccount="<account ID>"></ContentItem>' http://<soundtouch ip address>:8090/select #documentation on bose api was missing 'type="URI"' for restarting web streaming services
scripts.yaml
  # soundtouch - preset selector
  bose_preset_1:
    alias: Soundtouch Preset 1
    description: "Switches to pre-set 1 station"
    sequence:
      #Release
      - service: shell_command.bose_preset_1_release
        alias: Release button 1
      - event: LOGBOOK_ENTRY
        event_data:
          name: Lounge - preset 1 switch
          message: Lounge sound to Radio BBC1
          entity_id: media_player.soundtouch_300_living_room
          domain: media_player
  bose_preset_2:
    alias: Soundtouch Preset 2
    description: "Switches to pre-set 2 station"
    sequence:
      #Release
      - service: shell_command.bose_preset_2_release
        alias: Release button 2
        event_data:
          name: Lounge - preset 2 switch
          message: Lounge sound to Radio Preset 2
  bose_preset_3:
    alias: Soundtouch Preset 3
    description: "Switches to pre-set 3 station"
    sequence:
      #Release
      - service: shell_command.bose_preset_3_release
        alias: Release button 3
        event_data:
          name: Lounge - preset 3 switch
          message: Lounge sound to Radio BBC3
  bose_preset_4:
    alias: Soundtouch Preset 4
    description: "Switches to pre-set 4 station"
    sequence:
      #Release
      - service: shell_command.bose_preset_4_release
        alias: Release button 4
        event_data:
          name: Lounge - preset 4 switch
          message: Lounge sound to Radio BBC4
  bose_preset_5:
    alias: Soundtouch Preset 5
    description: "Switches to pre-set 5 station"
    sequence:
      #Release
      - service: shell_command.bose_preset_5_release
        alias: Release button 5
        event_data:
          name: Lounge - preset 5 switch
          message: Lounge sound to Radio BBC5
  # soundtouch - preset set
  # use the press function without calling release on the specified preset number
  bose_preset_6:
    alias: Soundtouch Preset 6
    description: "Switches to pre-set 6 station"
    sequence:
      #Press
      - service: shell_command.bose_preset_6_press
        alias: Press button 6
      #Release
      - service: shell_command.bose_preset_6_release
        alias: Release button 6
        event_data:
          name: Lounge - preset 6 switch
          message: Lounge sound to Radio BBC6
    #source switch
  # soundtouch - TV selector
  bose_souce_tv:
    alias: Soundtouch TV Source
    sequence:
      #Press
      - service: shell_command.bose_tv_source
        alias: Press TV button
        event_data:
          name: Lounge - TV Switch
          message: Lounge sound to TV
  # soundtouch -  Spotify selector
  bose_souce_spotify:
    alias: Soundtouch resume spotify play
    description: "Switches to spotify source and plays"
    sequence:
      #Press
      - service: shell_command.bose_spotify
        alias: Press Spotify button
      #Press play
      - service: shell_command.bose_play_release
        alias: Press button play
      #Release play
        alias: Release button play
        event_data:
          name: Lounge - Spotify Switch
          message: Lounge sound to Spotify
  # soundtouch - Amazon music selector
  bose_souce_amazon:
    alias: Soundtouch resume Amazon play
    sequence:
      #Press
      - service: shell_command.bose_amazon_music
        alias: Press Amazon button
      #Press play
      #Release play
        event_data:
          name: Lounge - Amazon Switch
          message: Lounge sound to Amazon
Lovelace UI yaml file
# a new tab for media - the full one contains my tv too, hence the icon. :)
## media
  - title: Media
    icon: mdi:video-vintage
    path: media
    cards:
    ## bose soundtouch
      - cards:
        #source selection
          - entities:
                #type: glance
            #tv source
              - type: entity-button
                entity: script.bose_souce_tv
                icon: mdi:television
                icon_height: 50px
                show_name: true
                tap_action:
                  action: call-service
                  service: script.bose_souce_tv
               #spotify source
                entity: script.bose_souce_spotify
                icon: mdi:spotify
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_souce_spotify
               #amazon
                entity: script.bose_souce_amazon
                icon: mdi:amazon
                icon_height: 50px
                name: Amazon Prime Music
                show_name: true
                tap_action:
                  service: script.bose_souce_amazon
            show_state: false
            type: glance
        #preset selection row a
          - entities:
                #type: glance
              #Preset 1
                entity: script.bose_preset_1
                icon: mdi:numeric-1-box-outline
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_preset_1
              #Preset 2
                entity: script.bose_preset_2
                icon: mdi:numeric-2-box-outline
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_preset_2
              #Preset 3
                entity: script.bose_preset_3
                icon: mdi:numeric-3-box-outline
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_preset_3
            show_state: false
            type: glance
        #preset selection row b
          - entities:
                #type: glance
              #Preset 4
                entity: script.bose_preset_4
                icon: mdi:numeric-4-box-outline
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_preset_4
              #Preset 5
                entity: script.bose_preset_5
                icon: mdi:numeric-5-box-outline
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_preset_5
              #Preset 6
                entity: script.bose_preset_6
                icon: mdi:numeric-6-box-outline
                icon_height: 50px
                show_name: true
                tap_action:
                  service: script.bose_preset_6
            show_state: false
            type: glance
          #custom card experiment
            #- type: custom:button-card
            #  icon: mdi:spotify
            #  action: service
            #  service:
            #    domain: rest_command
            #    action: lounge_soundbar_spotify
            #  icon: mdi:television
            #  action: service
            #  service:
            #    action: lounge_soundbar_tv
            #    data:
            #standard bose media player contorl
          - entity: media_player.soundtouch_300_living_room
            name: Living room soundbar
            type: media-control
        title: Bose
        type: vertical-stack
Here’s a picture for proof of life:
Looking forward to seeing where this goes. :slight_smile:
check out the mini-media-player custom card, over which it’s really easy to at least select presets
type: 'custom:mini-media-player'
shortcuts:
  buttons:
    - data:
        media_content_id: 1
        media_content_type: PLAYLIST
      type: service
    - data:
        media_content_id: 2
      type: service
    - data:
        media_content_id: 3
      type: service
    - data:
        media_content_id: 4
      type: service
    - data:
        media_content_id: 5
      type: service
    - data:
        media_content_id: 6
      type: service
  columns: 6
source: icon
@Bergals thank you very much for posting this. The ability to (automatically) select source has been a frustration for me since I got these speakers. If I was listening to music and didnt return the source (with the remote) to tv afterwards, my wife would come try watch tv and offcourse no sound, etc… thank you.
You are welcome @juan11perez Glad it helped someone other than just me. :wink:
Ah cool, I had that installed - but didn’t get the presets working on it. Your stuff helped me get it working.
One of the other challenges - custom cards don’t always render or render well on Mobile. I’m mucking about with Ariela and the HA Client app on android. While I prefer the look and combustibility of this custom card - its lack of render-ability isn’t working out as well for me as I’d like.
Thank you for your work!!! , everything works perfectly for me
the address: http://soundtouch-ip:8090/sources and http://soundtouch-ip:8090/sources are very important to configure the sources, I had to change “TV” to “AUX” and I had to delete all < > that surrounded the Ip address and my email address amazon music.
I could also add a bluetooth source and a playlist from my soundtouch music library
I think it will now be possible to ask google assistant to launch playlists thanks to scripts created
Great to hear @Divalz
… voice assistants should be one of my next projects for it. :smiley:
Any update on getting google assistant to work with SoundTouch?
And is this still the best way to control the SoundTouch speakers from HA?
how can i run in with python ?
If you integrate google (or siri or alexa), it should work - but asking the Assistant to run a script just requires the right phrasing. It worked for me with light scripts I’d set up (‘Hey google, run I’ve arrived home’) if memory serves worked. It was a bit hit and miss if the voice assistant chose to use it.
Sorry, not a python expert person… but I assume you can search for “python rest” and then use the same calls I used in these scripts.
Thanks, really like this integration and support! Had some struggles with getting Spotify working. Seems to be a little mistake in the scripts.yaml (?) , both Press and Release services refers to shell_command.bose_play_release. This will not make Spotify start. Therefore, you’ve you change ‘shell_command.bose_play_release’ to ‘shell_command.bose_play_press’ in Press Play, scripts.yaml. Got it working now. Thanks again for your work.
The SoundTouch integration already has support for activating any one of the 6 presets via a service call. You do not need to do cURL.
@pdg82 This was posted prior to the soundtouch integration being a built in addition to HomeAssistant. I believe they used what I had above as the basis for the integration - so in theory! We don’t have to worry about what I went through above. :smiley:
… and I should play with it and update the way I’ve integrated my soundtouch!
I just developed a new SoundTouchPlus custom component if you’re interested. It can easily be installed via HACS as well. More information can be found in this forum post.
I stumbled across this and have an older speaker and I couldn’t see that in the sound touch integration, this was a great find! Thank you
