Botslab: Indoor Security Camera - Cube F23 - Konnek Stein - 360cn
Hi there.
Few days ago, I`ve created other post (in feature request, and now i see it was a mistake, sorry about that).
I see now, it would fit better in here, since probably will depend on a integration.
I have about a year now, a indoor security camera bought in aliexpress branded as a “Konnek Stein” in front of it, but the software that came to acess it, is “Botslab”.
In the seller description it was labelled as a 'Tuya" and “alexa” compatilble (at that time I was never heard about homeassistant unfortunately), but is not all true about these integration.
The app “Botslab” works well in Android, but Tuya or SmartLife cant (and Ive tried hard to) see this camera directley… The QRCode the app generates that I have to “show” to the camera to set it up, its not compatible to one that smartlife and tuya apps generate.
i have tried to scan my network to see if I find any open port in the designed IP (I set it up a static IP by mac address in my router to make it easy). but only high ports and only when I was acessing by app (and not even a direct conection… the app conect to some cloud server and also the camera).
I couldnt find any direct information about web acess or even how to connect to this api server, but indirectly in my researchs i`ve found some informations.
This camera besides exterior brand labeled “Konnek Stein”, in the label below it contains two informations that I guess could be the model “Cube F23”
I have also found some mention to this in FCC reports, but nothing that could help me.
In another proach, I look at the “Alexa skill integration”, but to be able to get that, I have to change my country in amazon account (is avaiable only when i change to US address… and when I change back to Brazil, its desapear (thats similar to others skills only avaiable in US such as Monocle and NotifyMe unfortunatly0
anyway, when I have tried this skill, i take note in witch server it connects: “oauth2.iot.360.cn” but I cant acess it directly… I always get a NGINX message 403 Forbidden. Ive tried to look it up in 360 website, but theres no clear path to a web acess or something. BUT… i have found a PDF (SDK Im guessing) mentioning about rules of oauth2, API, and so on related to 360cn iot server. Theres a long time that I havent code nothing to elaborated (my main job is as Civil engineer… Im also system engineer and other things, but in the past 10 years mostly working as a civil engineer. light programing in python and some scritps only as a hobby).
Some of you guys probably have some toughts like “uf alexa sees it, I could expose the entity in HA” or something… but again unfortunetly no… Alexa could see the setream of camera when Im using Firetv only, but I cant even create some rule like if detects movement or somthing. theres no triggers whatsoever.
Other thing I have found about it, was a IFTTTT integration, but I couldnt make it work properly… Theres only some few triggers in normal IFTTT area (Im not VIP), and I saw that it also tris to connect to a 360cn server, but this time “oauth2.openapi.360.cn” (only changes “iot” to “openapi” but seems to be a alias point to same place).
Some other related information about this particular model that I found:
Botslab Camera Cubo F23
Konnek Stein Surveillance Camera 1080p HD Indoor
Seybold International Hong Kong Limited F23
SoC - Ingenic T21
Wifi Realtek 8188FTU
Sensor AD CUT09
MB AC11_MB_V3.0 - 2020/03/05
F23, 2ANJX-F23, 2ANJXF23, F23 Indoor Security Camera, Indoor Security Camera
And I think (but not sure) theres other major brands using the same hardware (and ever if theres the case, probably different firmware):
My guessing was:
J6: Smart Wifi Cube Camera with Quick and Easy Wifi Setup
ezvis
and
KaLay F23 F23 IP WIFI CAMERA User Manual 1 Vizolink (Shenzhen) .
Vizolink (Shenzhen) . IP WIFI CAMERA
I have tried to find any other mention to this camera (or even to botslab) in homeassistant comunities forum (not only this one) with no sucess., and I can only imagine that is not a popular brand in any country (not only this model, but any other model in botslab store nor 360cn store, and its not a few models as i can see, and theres also other iot components witch operates at the same app (ou api).
I will try a litle more, and also read that SDK doccument and sees if I can found anything before i jump to change the original firmware of this camera to IPC one.
Anyway, Im letting all this information here, in case someone needs it in future, or if it will be usefull to develop some kind of integration to this band’s devices.
Just for add more information:
I just found another brand, that sells this very same camera: Ahiya Technology
I found in Wall Mart advertisiment, but, in the picuture of product We can see “KonnekStein” printed… (I made a quick search in Aliexpress, and found the camera with the “Ahyia” printed on it)
If someone knows any other information about this camera (or other apps or integration that could work on ) I will be gratefull
Hello, have you been able to connect the camera with Home Assistant? I have a smart 360 that also it has the Ingenic chip, but I cannot access it from Home Assistant, only from the APP: Botslab.
