Broadlink IR Climate Component
You would have to use something like IFTTT or Stringify to have GH do an API call to home assistant.
Its not that hard to set up.
I really love this but anyone can input a switch on/off in front page like image below…
This works great with the latest dev version of HA posted a few hours ago.
Is there any way to integrate an external humidity sensor into this component?
This would allow me to simplify this screen:
I’ll also have to round the temperature sensor to the nearest integer…
No, sorry. This component follows the universal rules of the climate component, so humidity value not exists.
You can try home assistant custom UI in order to accomplish your task.
Thank you
You can use an on/off switch (not in the group position) with the help of a template switch but the on state must be hardcoded.
Please send me if you want an example.
Sorry, but the most AC’s send the swing value together with temperature, mode, etc. So it’s impossible to implement this feature. I suggest you keep the default swing mode when you generate your codes.
Thanks Vassilis. Are you going to try to get this into the main release? Works great, so far it’s much more functional than Daikin’s own climate adapter…
Thanks you!
Please give an example if you are free :slight_smile:
switch:
    switches:
      my_ac:
        value_template: "{{not is_state('climate.office_ac', 'idle') }}"
        turn_off:
          service: climate.set_operation_mode
            entity_id: climate.office_ac
            operation_mode: idle
        turn_on:
            operation_mode: heat
Looking for the same!
If anyone has gone through the hassle of making a IR file for Pansonic AC/Heat Pump, i will really appreciate it!:slight_smile:
Hi
I am also looking for a Panasonic AC/Heat pump IR file. Would somebody be kind enough to share.
Many Thanks
Jman
I already did a sample with
mode: Auto - Cool - Dry
Fan speed: auto
Template: 16-28
But with full code really too hard :slight_smile:
@CloudHoang want to share it? would be great :wink:
Here it is…
Some one please improve this with me
[off]
off_command = JgC8AXU3EA0PKg8MEAwQDQ8NDw0PDBAMEA0PDQ8MEAwQKRANDw0PDBAMEA0PDQ8MECkQKRAqDw0PDBApEA0PDQ8NDwwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDwwQDBANDw0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MECkQKg8NDw0PDBAMEA0PAAFHdDgPDBApEA0PDQ8NDw0PDBAMEA0PDQ8MEAwQDBAqDw0PDBAMEAwQDQ8NDwwQKRAqDyoPDQ8MECkQDBANDw0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBAqDw0PDBAMEA0PDQ8MEAwQDBANDyoPKRApEA0PDQ8NDwwQDBANDw0PKRApECkQKg8qDwwQKRAMECoPDQ8MEAwQKg8NDw4PDBAMEA0PDQ8MEAwQDBANDw0PDBAMECoPKg8pEAwQDBANDw0PDBAMEAwWDBANDyoPKRApEA0PFg8NDw0PFg8MEAwWDBANDw0TDQ8NDxAPDQ8MHAwQKRAaDwwQDBwMEA0PDQ8qDwwQDBANDw0PDQ8MEAwQDQ8NEAwPFQ8NDw0PDA8NEA0PDQ8NDykQDBAqDw0PDBApEAANBQAAAAAAAAAAAAAAAA==
[idle]
idle_command = JgC8AXU3EA0PKg8MEAwQDQ8NDw0PDBAMEA0PDQ8MEAwQKRANDw0PDBAMEA0PDQ8MECkQKRAqDw0PDBApEA0PDQ8NDwwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDwwQDBANDw0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MECkQKg8NDw0PDBAMEA0PAAFHdDgPDBApEA0PDQ8NDw0PDBAMEA0PDQ8MEAwQDBAqDw0PDBAMEAwQDQ8NDwwQKRAqDyoPDQ8MECkQDBANDw0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBAqDw0PDBAMEA0PDQ8MEAwQDBANDyoPKRApEA0PDQ8NDwwQDBANDw0PKRApECkQKg8qDwwQKRAMECoPDQ8MEAwQKg8NDw4PDBAMEA0PDQ8MEAwQDBANDw0PDBAMECoPKg8pEAwQDBANDw0PDBAMEAwWDBANDyoPKRApEA0PFg8NDw0PFg8MEAwWDBANDw0TDQ8NDxAPDQ8MHAwQKRAaDwwQDBwMEA0PDQ8qDwwQDBANDw0PDQ8MEAwQDQ8NEAwPFQ8NDw0PDA8NEA0PDQ8NDykQDBAqDw0PDBApEAANBQAAAAAAAAAAAAAAAA==
[auto]
auto_16 = 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
auto_17 = 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
auto_18 = JgC8AXU3EAwQKRANDwwQDBAMEAwQDQ8MEAwQDBANDw0PKRAMEAwQDQ8NDwwQDBAMECoPKRApEAwQDBAqDw0PDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDBAMECkQKg8NDwwQDBAMEA0PAAFHdDcQDBApEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8pEAwQDQ8MEAwQDBANDw0PKRApECkQDQ8NDykQDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8pEAwQDBAqDwwQDBAMEA0PDQ8MEAwQDBANDykQKRApEAwQDQ8MEAwQDBANDw0PKRApECkQKg8pEAwQKRANDykQDBAMEAwQKg8MEAwQDBANDw0PDBAMEAwQDQ8MEAwQDBAMECoPKRApEAwQDQ8NDwwQDBAMEA0PDQ8MECkOKxAqDw0PDBAMEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8MEAwQKRANDw0PDBANDw0PDBApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDwwQDBAMEA0PKg8MECkQDBApEA0PDBApEAANBQAAAAAAAAAAAAAAAA==
auto_19 = 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
auto_20 = 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
auto_21 = 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
auto_22 = 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
auto_23 = JgC8AXQ3EAwQKRANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PKRAMEAwQDQ8NDwwQDBAMECoPKg8pEAwQDBAqDwwQDBAMEAwQDQ8NDwwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMECoPKg8MEAwQDBANDwwQAAFGdTcQDBAqDwwQDBAMEA0PDQ8MEAwQDBANDwwQDBApEA0PDQ8MEAwQDBANDw0PKRApECkQDQ8ODykQDQ8MEAwQDBAMEA0PDBAMEA0PDQ8MEAwQDBAqDwwQDBAqDw0PDQ8MEAwQDQ8NDwwQDBAMECoPKRApEAwQDQ8MEAwQDBANDw0PKRAqDyoPKRApEAwQKg8MECkQDBANDw0PKRAMEAwQDQ8NDwwQDBAMEA0PDBAMEAwQDQ8NDykQKRApEA0PDQ8MEAwQDBANDw0PDBAMECkQKg8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQKRANDwwQDBAMEA0PDQ8pEAwQDQ8MEA0PDBANDw0PDBAMDw0QDQ8NDwwQDBANDw0PKRAMECkQDQ8pEAwQDBApEAANBQAAAAAAAAAAAAAAAA==
auto_24 = 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
auto_25 = JgC8AXU3EAwQKRANDw0PDBAMEAwQDQ8MEAwQDBANDw0PKRAMEAwQDQ8NDwwQDA4OECoPKRApEAwQDBAqDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDwwQDBAMEAwQDQ8MECkQKRANDw0PDBAMEAwQAAFHdDgPDBApEAwQDQ8NDwwQDA0PEA0PDBAMEAwQDQ8pEAwQDBAMEAwQDBAMEA0PKRApECkQDQ8NDykQDBAMEA0PDBAMEAwQDQ8MEAwQDBANDw0PDBApEAwQDQ8qDwwQDBANDw0PDBAMDg4QDQ8NDykQKRAqDwwQDA0PEA0PDQ8MEAwQKRAqDyoPKRApDg4QKg8NDykQDBAMEA0PKRAMEAwQDQ8NDwwQDBAMEA0PDBAMEAwQDQ8NDykQKRApEA0PDQ8MEAwQDBANDw0PDBAMECoPKg8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDBAMEAwQKg8NDwwQDBAMEAwQDBApEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8MEAwQDBANDwwQKRAMECoPDQ8pEAwQDBAqDwANBQAAAAAAAAAAAAAAAA==
auto_26 = JgC8AXQ3EA0PKg8MEAwQDBANDw0PDBAMEAwQDQ8MEAwQKRANDw0PDBAMEAwQDQ8NDykQKRApEA0PDBApEAwQDQ8NDwwQDA0PEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBANDyoPKRAMEAwQDQ8MEAwQAAFGdTcgDBApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8qDwwQDBAMEA0PDQ8NDwwQKRApECoPDQ8MECkNDxANDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBApEAwQDBAqDw0PDBAMEAwQDQ8MEAwQDBANDyoPKRApDQ8QGA8MEAwQDQ8MEAwQKRAqDyoPKRApEAwQKg8NDykQDBAMEA0PKg8MEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDykQKRApEAwQDBANDw0PDBAMEAwQDQ8MEDMPKRAqEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQKg8MEAwQDBANDw0PDBApEAwQDQ8NDwwQDBAMEA0PDBAMEAwQDQ8NDwwQDBAMEA0PKRAMECkQDBAqDwwQDBApEAANBQAAAAAAAAAAAAAAAA==
auto_27 = 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
auto_28 = JgC8AXU3EAwQKRANDw0PDBAMDhAPDBAMEAwQDQ8NDwwQKRAMEA0PDBAMEAwQDQ8NDykQKRAqDwwQDBApEA0PDQ8MEAwQDBANDw0PDBAMEAwRDQ8MEAwQDQ8NDwwQDA0PEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8MECkQKRANDw0PDBAMEAwQAAFHdDcQDBApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwNDxAqDwwQDBAMEA0PDQ8MEAwQKRAqDyoPDBAMECkQDQ8MEAwQDBAMEA0PDBAMEAwQDQ8NDwwQDBApEA0PDQ8pEAwQDBANDwwQDBAMEA0PDQ8MECkQKRAqDw0PDBAMEAwQDQ8MEAwQKRAqDyoPKg8pEAwQKg8MECkQDBANDw0PKRAMDQ8QDQ8NDwwQDBAMEA0PDBANEAwQDQ8NDyoPKRApEAwQDQ8NDwwQDBAMEA0PDBAMECkQKg8qDwwQDBAMEA0PDBAMEAwQDQ8NDwwRDQ8NDwwQDBAMEA0PKg8MEAwQDBANDwwQDBAqDw0PDBAMEA0PDQ8MEAwQDBANDw0PDBAMDQ8QDQ8NDwwQKRAMECoPDQ8pEAwQDQ8qDwANBQAAAAAAAAAAAAAAAA==
[dry]
auto_16 = JgC8AXQ4Dw0PKRAMEA0PDQ8MEAwQDBANDwwQDBANDw0PKRAMEA0PDQ8NDwwQDBANDyoPKRApDg4RDBAqDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8NDw0PDBAMEAwQDQ8NDwwQDBAMECoPKRAMEAwQDQ8NDwwQAAFGdTcQDQ8qDw0PDBAMEA0PDQ8MEAwQDBANDw0PDBApEAwQDQ8NDwwQDBANDw0PKRApECkQDQ8NDykQDBAMEA0PDQ8MEAwQDQ8NDw0PDBAMEA0PDBApEA0PDQ8pEAwQKg8NDwwQDBAMEA0PDQ8MECkQDBANDwwQDBAMEA0PDQ8MEAwQKRAqDykQKRApEA0PKg8MECkQDBANDw0PKRAMEA0PDQ8MEAwQDBANDw0PDBAMDQ8QDQ8NDykQKRApEA0PDQ8MEAwQDBANDw0PDBAMECoPKg8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDBAMEAwQKg8NDwwQDBAMEAwQDBApEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDw8MEAwNDxANDw0PKRAMECoPDQ8pECkQKRAqDwANBQAAAAAAAAAAAAAAAA==
auto_17 = 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
auto_18 = 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
auto_19 = 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
auto_20 = JgC8AXU3EAwQKg8NDwwQDBAMEA0PDQ8MEAwQDQ8NDwwQKRAMEA0PDQ8MEAwQDBANDykQKRApEA0PDQ8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDBAMEA0PDQ8MEAwQDQ8NDwwQDA8NEA0PDQ8MEAwQDBANDykQKRAMEAwQDQ8NDwwQAAFGdTcQDQ8pEAwQDBAMEA0PDQ8MEAwQDQ8NDw0PDBApEAwQDQ8NDwwQDBANDw0PKRApECkQDQ8NDykQDBAMEA0PDQ8MEAwQDQ8NDw0PDBAMEAwQDQ8pEAwQDBAqDw0PKRAMEAwQDQ8NDwwQKRANDyoPDQ8MEAwQDQ8NDwwQDBAMEA0PKRApECkQKg8qDwwQKRAMECoPDRAMDwwQKRAMEA0PDQ8MEAwQDQ8NDw0PDQ8MEAwQDQ8NDykQKRApEA0PDBAMEAwQDQ8MEAwQDQ8NDykQKRApEA0PDQ8MEAwQDQ8NDwwQDQ8MEAwQDBANDw0PDBAMEA0PKg8MEAwQDBANDw0PDBApEA0PDQ8MEAwQDBANDw0PDBAMDw0QDQ8NDwwQDBAMEA0PKRAMECkQKg8qDykQKRApEAANBQAAAAAAAAAAAAAAAA==
auto_21 = 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
auto_22 = JgC8AXQ3EA4PKRAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQKg8NDwwQDA0PEA0PDg8MECkQKg8pEAwQDBAqDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDwwQDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBANDyoPKRAMEAwQDQ8NDwwQAAFGdTcQDQ8pEAwQDBANDwwQDBANDw0PDBAMEAwQDQ8qDwwQDBAMEA0PDQ8MEAwQKg8qDykQDBAMECoPDQ8MEA0PDQ8MEAwPDRANDw0PDBAMEAwQDQ8qDwwQDBApEA0PKRAMEAwQDQ8NDykQKRAMECoPDQ8NDwwQDBANDw0PDBAMEAwQKg8qDykQKRApEA0PKRAMECkQDQ8NDwwQKRAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MECkQKRAqDw0PDBAMEAwQDQ8NDwwQDBANDyoPKRApEAwQDQ8NDwwQDBANDw0PDQ8MEAwQDQ8NDwwQDA8NEA0PKg8MEAwQDBANDw0PDQ8pEAwQDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQKRANDw0PDBAMEAwQDQ8NDwANBQAAAAAAAAAAAAAAAA==
auto_23 = JgC8AXU3EAwQKg8NDwwQDA0PEA0PDQ8MEAwQDQ8NDwwQKRAMEA0PDQ8MEA0QDBANDyoPKRApEA0PDQ8pEAwODhANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDQ8MEA0PDQ8MEAwQDQ8NDw0PDBAMEA0PDQ8MEAwQDBANDyoPKRAMEAwQDQ8NDwwQAAFGdTcQDQ8qDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBApEAwQDQ8NDwwQDBANDw0PKRApECkQDQ8NDykQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8pEAwQDQ8qDwwQKRAMEA0PDQ8pECkQKRANDykQDBAMEA0PDBAMEAwQDQ8NDwwQKRApECsPKRAqDwwQKQ4OECoPDQ8MEAwQKRANDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMECoPKg8pEAwODhANDw0PDBAMEAwQDQ8NDykQKRApEA0PDBAMEAwQDQ8NDw0PDBAMEA0PDQ8MEAwQDBANDw0PKRAMEAwQDQ8NDw0PDBApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PKg8pEAwNDxANDw0PDBAMEAANBQAAAAAAAAAAAAAAAA==
auto_24 = 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
auto_25 = JgC8AXQ3EAwQKg8NDwwQDBAMEA0PDQ8MEAwQDQ8NDwwQKRAMEA0PDQ8MEAwQDQ8NDyoPKRApEA0PDQ8pEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDBAMEA0PDQ8NDwwQDBANDyoPKw8NDw0PDBAMEA0PAAFHdDgPDBApEAwQDQ8NDwwQDBANDw0PDBAMEAwQDQ8qDwwQDBAMEA0PDBAMEAwQKg8pECkQDBANDyoPDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8qDwwQDBApEA0PKg8MEAwQDBAqDwwQDBApECoPDQ8MEAwQDBANDw0PDBAMEA0PKg8pECkQKRAqDw0PKRAMECkQDQ8NDwwQKRANDw0PDQ8NDwwQDBANDw0PDBAMEAwQDQ8NDykQKRApEAwQDBAMEA0PDQ8MEAwQDQ8NDykQKRApEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8MEAwQDBANDw0PKRAMEAwQDQ8NDwwQDBApEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8MEAwQDBAODw0PKRApECkQDQ8NDwwQDBANDwANBQAAAAAAAAAAAAAAAA==
auto_26 = 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
auto_27 = 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
auto_28 = JgC8AXQ3EAwQKg8NDwwQDBAMEA0PDBAMEAwQDQ8NDwwQKRAMEA0PDQ8MEAwQDQ8NDykQKRApEA0PDQ8qDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8NDwwQDBANDw0PDBAMEAwQDQ8MEAwQDBANDw0PDBAMECkQKg8MEAwQDBANDw0PAAFGdTcQDBAqDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8pEAwQDBANDwwQDBAMEA0PKg8pECkQDBANDykQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQDBAqDw0PDBApEA0PKg8MEAwODhANDw0PKRApECkQDQ8NDwwQDBANDw0PDBAMEAwQKg8qDykQKRApEA0PKg8MECkQDQ8MEAwQKRANDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMECkQKg8pEAwQDBANDw0PDBAMEAwQDQ8NDykQKRAqDw0PDQ8MEAwPDRANDw0PDBAMEAwQDQ8MEAwQDBAMEA0PKRAMEAwQDQ8NDwwQDBApEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MEA0PDQ8MEAwQKRAODyoPKRAMEAwQDBANDwANBQAAAAAAAAAAAAAAAA==
[cool]
auto_16 = JgC8AXQ4DwwQKRAMEA0PDQ8MEAwQDBANDw0PDg8NDwwQKRAMEA0PDQ8MEAwQDBANDyoPKRApEAwQDQ8qDwwQDA0PEA0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MECkQKRANDw0PDBAMEAwQAAFHdDgPDBApEQwPDQ8MEAwQDBANDwwQDBAMEA0PDQ8pEAwQDBANDw0PDBAMEAwQKg8pECkQDBANDyoPDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBAqDwwQDBApECoPKg8MEAwQDBANDw0PDBAMECkQDQ8NDwwQDBANDw0PDBAMDg4QKg8pECkQKRApEA0PKRAMECkQDQ8MEAwQKg8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDyoPKRApEAwQDQ8NDwwQDBAMEAwQDQ8NDykQKRApEA0PDBAMDg4QDQ8NDwwQDQ8NDwwQDBAMEA0PDQ8MEAwQKRANDwwQDBAMEA0PDQ8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDBAMEAwQKg8NDykQDBAMEA0PDBAMEAANBQAAAAAAAAAAAAAAAA==
auto_17 = JgC8AXU3EAwQKRANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PKg8MEAwQDBANDw0PDBAMECoQKg8pEAwQDBApEA0PDBAMEAwQDBANDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBAMEA0PDQ8MEAwQDQ8NDykQKQ0PEA0PDQ8MEAwQAAFGdTgPDQ8pEAwQDBANDw0PDBAMEAwQDQ8MEAwQDBAqDwwQDBANDwwQDBAMEA0PKg8pECkQDBANDyoPDBAMDQ8QDQ8NDwwQDBANDw0PDBAMEA0PDQ8pEAwQDBAqDykQKRAMEA0PDQ8pEAwODhANDyoPDBAMEAwQDQ8NDwwQDBANDw0PKRApECkQKRAqDwwQKRAMECoPDQ8MEAwQKRANDw0PDBAMEAwQDQ8MEAwQDBANDw0PDQ8MECkQKRAqDw0PDBAMEA0PDQ8NDwwQDBAMECoPKRApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQKg8NDwwQDBAMEA0PDBApEAwQDQ8NDwwQDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQKRAqDykQDBANDwwQDBAMEAANBQAAAAAAAAAAAAAAAA==
auto_18 = JgC8AXQ3EA0PKRAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQKg8NDwwQDBANDw0PDBAMECkQKg8qDwwQDBArDwwQDQ8NDwwQDBAMEA0PDQ8NDwwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDBAMEAwQDQ8NDwwQDA8NECoPKRAMEAwQDQ8MEAwQAAFHdDgPDBApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8qDwwQDBAMEA0PDQ8MEAwQKRAqDykQDBAMECoPDQ8MEAwQDBANDw0PDBAMEAwQDQ8MEAwQDBAqDw0PDBApECkQKg8NDwwQDBAMECoPDBAMECkQDQ8NDwwQDBAMEA0PDBAMEAwQKg8qDykQKQ4rEA0PKRAMECkQDBANDwwQKRAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MECkQKRAqDwwQDBAMEA0PDBANDw0PDBAMECoPKg8pEAwQDBANDw0PDBAMEA0PDBAMEA0PDQ8MEAwQDBANDw0PKRAMEAwQDQ8NDwwQDBApEA0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEA0PDRANDw0PKRAMDg4QKg8NDwwQDBANDwANBQAAAAAAAAAAAAAAAA==
auto_19 = JgC8AXU3EAwQKg8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQKRAMEA0PDQ8MEAwPDRANDykQKRApEA0PDQ8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MEAwPDRANDw0PDQ8MECkQKRANDw0PDBAMEA0PAAFHdDcQDBApEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8pEAwQDBANDw0PDBAMEAwQKg8pECkQDBANDykQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDBApEA0PDQ8pECkQKRANDw0PDBApECkQDQ8NDykQDBAMEA0PDQ8MEAwQDBANDw0PKRApECoPKg8pEAwQKRANDyoPDBAMEA0PKg8MEAwQDBANDwwQDBANDw0PDBAMEAwQDQ8MECkQKRAqDw0PDBAMEAwQDQ8NDwwQDBAMECoPKRApEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEAwQDBANDw0PKRAMEAwQDQ8MEAwQDBAqDw0PDBAMDQ8QDQ8NDwwQDBAMEA0PDBAMEAwSDBAMEAwQKg8qDwwQKRAMEA0PDQ8MEAANBQAAAAAAAAAAAAAAAA==
auto_20 = 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
auto_21 = JgC8AXU3EA0PKg8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQKRAMEA0PDQ8MEAwQDQ8NDykQKRAqDw0PDBApEAwQDQ8MEAwQDBANDw0PDBAMDQ8QDQ8NDwwQDBAMEA0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8NDykQKRAMEA0PDQ8MEAwQAAFGdTcQDQ8pEAwQDBANDw0PDBAMDg4QDQ8NDwwQDBApEA0PDBAMEAwQDQ8NDwwQKRApECoPDQ8MECkQDBANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDBApEAwQDQ8qDykQKRAMEA0PDQ8pEAwQKRAMECkQDBANDwwQDBAMEA0PDQ8MEAwQKRAqDykQKRApEAwQKg8MECkQDBANDw0PKRAMEAwQDQ8NDwwQDBAMEA0PDBAMEAwQDQ8NDykQKRApEA0PDQ8MEAwQDBANDw0PDQ8NDykQKRApEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDw0PKRAMEAwQDQ8NDw0PDBApEA0PDg8MEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8MEAwQKRAqDykQKRAMEAwQDQ8MEAANBQAAAAAAAAAAAAAAAA==
auto_22 = JgC8AXQ3EA0PKRAMEAwQDQ8NDwwQDA0PEA0PDQ8MEAwQKRANDwwQDBANDwwQDBAMECoPKg8pEAwQDBAqDwwQDBANDw0PDBAMDQ8QDQ8MEAwNDxANDw0PDBAMEAwQDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDyoPKRAMEAwQDQ8NDwwQAAFGdTcQDQ8qDwwQDBAMEA0PDQ8MEAwQDBANDwwRDA8qDwwQDBAMEA0PDQ8MEAwQKg8qDykQDBAMECoPDQ8MEAwQDBANDwwQDBAMEA0PDQ8MEAwQDBAqDwwQDBApECoPKg8MEAwQDBANDykQKRAMECoPDQ8MEAwPDRANDw0PDBAMEA0PKg8pECkQKRAqDw0PKRAMECoPDQ8MEAwQKRAMEA0PDBAMEAwQDQ8NDwwQDA0PEA0PDQ8NDykQKRApEA0PDQ8MEAwNDxANDw0PDBAMECkQKg8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBANDw0PDBAMEAwQKg8NDwwQDBAMEA0PDQ8pEAwPDRANDw0PDBAMDQ8QDQ8NDwwQDBAMEA0PDQ8MEAwQKRANDw0PDBApEA0PDQ8MEAANBQAAAAAAAAAAAAAAAA==
auto_23 = 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
auto_24 = 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
auto_25 = JgC8AXU3Dg4QKg8NDwwQDQ8NDwwQDBAMEA0PDQ8MEAwQKRANDw0PDBAMEA0PDQ8MECkQKRAqDw0PDBApEAwQDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEA0PDQ8MECkQKRANDw0PDQ8MEAwQAAFGdTcQDQ8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBApEA0PDBAMEAwQDQ8MEAwQKRApECoPDBAMECkQDQ8NDwwQDQ8NDw0PDBAMEA0PDQ8MEAwQDBAqDw0PDBApECkQKg8NDwwQDBApEA0PDBApECoPDQ8MEAwQDBANDw0PDBAMEAwQKg8qDykQKRApEA0PKRAMECkQDQ8NDw0PKRAMEAwQDQ8NDw0PDBAMEAwQDQ8NDwwQDBAMECoPKg8pEAwQDBANDw0PDBAMEAwQDQ8NDykQKRApEA0PDBAMEAwQDQ8NDwwQDBANDw0PDBAMEAwQDQ8NDwwQKRAMEA0PDBAMEAwQDQ8qDwwQDA4OEA0PDQ8MEAwQDBANDwwQDBAMEA0PDQ8NDwwQKRAqECkQDBApDQ8QDQ8NDwANBQAAAAAAAAAAAAAAAA==
auto_26 = JgC8AXU4DwwQKRANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PKRAMEAwQDQ8NDwwQDA8NECoPKRApEAwQDBAqDw0PDBAMEAwQDQ8MEAwQDBANDw0PDBAMDQ8QDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDykQKRANDw0PDBAMEAwQAAFHdDQTDBApEAwQDQ8NDwwQDBANDw0PDBAMEAwQDQ8qDwwQDBANDw0PDBAMEA0PKg8pECkQDQ8NDykQDBAMEA0PDBAMEAwQDQ8NDwwQDBANDw0PDBApEA0PDQ8pECkQKRANDw0PDBAMECkQDQ8pECkQDBAMEA0PDQ8MEAwQDQ8NDwwQKQ0sECoPKRApEAwQKg8NDyoPDQ8MEAwQKRANDw0PDBANDw0PDBAMEAwQDQ8NDwwQDBAMECoPKg8pEAwPDRAMEAwQDQ8MEAwQDBANDyoPKRApEAwQDQ8NDwwQDBAMEA0PDQ8MEAwQDQ8NDwwQDBAMEA0PKRAMEAwQDBANDwwQDBApEA0PDQ8MEAwQDBANDw0PDBAMEA0PDQ8MEQ0PDQ8MEAwQKRANDwwQKRApEA0PDQ8MEAANBQAAAAAAAAAAAAAAAA==
auto_27 = 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
auto_28 = JgC8AXQ3EAwQKg8NDwwQDBAMEA0PDQ8MEAwQDBANDw0PKRAMEA0PDQ8MEAwQDBANDyoPKRApEAwQDQ8pEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBINDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDBAMDg4QDBAMEAwQDQ8NDykQKQ0PEA0PDQ8NDwwQAAFGdTcQDQ8qDw0PDBAMEAwQDQ8NDwwQDBAMEA0PDQ8pEAwQDBANDw0PDBAMEA0PKg8pECkQDQ8NDykQDBAMEA0PDBANDw0PDBAMEAwQDQ8NDw0PDBApEAwQDQ8qDykQKRAMEAwQDBANDwwQKRApECoPDQ8MEAwQDQ8MEAwQDQ8MEA0PKg8pECkQKRAqDw0PKRAMECkQDQ8NDw0PKRAMEA0PDQ8NDwwQDBAMEA0PDQ8MEAwQDBANDykQKRApEA0PDg8MEAwQDBAMEA0PDQ8MECkQKRAqDwwQDBAMEA0PDQ8MEAwQDQ8MEAwNDxANDw0PDBAMEA0PKg8MEAwQDBANDw0PDBApEAwQDQ8MEAwQDBANDw0PDBAMEAwQDQ8NDwwQDBAMEA0PKRANDioQKg8pEAwQDBANDwANBQAAAAAAAAAAAAAAAA==
Awesome thanks for sharing
Thanks! I don’t have “dry” in my config or on my remote control though - is it the same as “heat”?
not the same
for my AC.
for each [mode + fan + temp] give me a difference code
Hi everyone, I need help. I get this error:
2018-02-07 19:26:28 ERROR (MainThread) [homeassistant.loader] Unable to find component climate.broadlink
I have put it as you said in the thread but there is no way. I have tried different ways and nothing. What is the secret? What is the problem with climate:?
My routes:
imagen
imagen
imagen
Please, say something to me. Thanks.
I think climate.yaml goes in your config folder, and should be referenced on your configuration.yaml.
configuration:
  climate: !include climate.yaml.
