2018-03-04 07:24:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/src/app/homeassistant/helpers/discovery.py”, line 164, in async_load_platform
hass, component, hass_config)
File “/usr/src/app/homeassistant/setup.py”, line 46, in async_setup_component
return (yield from setup_tasks[domain])
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 329, in iter
return self.result() # May raise too.
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 243, in result
raise self._exception
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 182, in _step
result = coro.throw(exc)
File “/usr/src/app/homeassistant/setup.py”, line 57, in async_setup_component
return (yield from task)
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 327, in iter
yield self # This tells Task to wait for completion.
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/src/app/homeassistant/setup.py”, line 119, in _async_setup_component
conf_util.async_process_component_config(hass, config, domain)
File “/usr/src/app/homeassistant/config.py”, line 624, in async_process_component_config
platform = get_platform(domain, p_name)
File “/usr/src/app/homeassistant/loader.py”, line 104, in get_platform
return get_component(PLATFORM_FORMAT.format(domain, platform))
File “/usr/src/app/homeassistant/loader.py”, line 142, in get_component
module = importlib.import_module(path)
File “/usr/local/lib/python3.6/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 994, in _gcd_import
File “”, line 971, in _find_and_load
File “”, line 955, in _find_and_load_unlocked
File “”, line 665, in _load_unlocked
File “”, line 674, in exec_module
File “”, line 781, in get_code
File “”, line 741, in source_to_code
File “”, line 219, in _call_with_frames_removed
File “/config/custom_components/climate/broadlink.py”, line 7
SyntaxError: invalid syntax
2018-03-04 07:24:44 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
future.result()
