Broadlink Manager - Docker version
Hi @SandmanXX,
The guide is ready.
I got it running on Windows 11… Works well in scanning, finding device, etc. Great job!
I’m still having the same problem. Typing in the code, 7E-7E which is a power on button code, at Yamaha IR Hex Converter gives me the hex string.
However, when I put the hex string in either broadlinkmanager, OR Hex to base64 converter (tomeko.net) gives me the exact same code, that does not look like right, or works on the amp.
It may be the yamaha converter giving the problem, I’m not having any luck from typing in the IR code from my sheet.
The hex string from yamaha gives me - 0000 006D 0022 0002 0155 00AA 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 05ED 0155 0055 0015 0E47
Converting it either way gives me - AAAAbQAiAAIBVQCqABUAFQAVAEAAFQBAABUAQAAVAEAAFQBAABUAQAAVABUAFQBAABUAFQAVABUAFQAVABUAFQAVABUAFQAVABUAQAAVABUAFQBAABUAQAAVAEAAFQBAABUAQAAVAEAAFQAVABUAQAAVABUAFQAVABUAFQAVABUAFQAVABUAFQAVAEAAFQXtAVUAVQAVDkc=
and that doesn’t work. I notice the standard IR codes in homeassistant all look like “JgBQAAABJJMUERM3ExISNxQ2FDYTNxMSEzYUERM3ExITEhMSExITNhMSFDYTNxMSEzYUERQRExITNxMSExITNhQRFDYUNhM3EgAFFQABJUgWAA0F” (I have this code from a button press, another button, not the one I need).
I don’t know what’s wrong.
Here’s a sheet I found on remote codes website.
Extended_IR_Codes_RX-V685RX-A780-RX-A3080CX-A5200_6.pdf (snapav.com)
If you have any input on this, greatly appreciated. Thanks!
As a side note, if I use an actual button on the remote, and then try converting the exact same button detailed above, I get a different code. :frowning:
No luck yet, trying to figure out how to use these hidden codes.
Is Python 3.9.7 a condition? Can the latest release be Python 3 - Python 3.10.0?
Thank you
I managed to install this as an addon for home assistant but I get an error when trying to access the WebUI. This is what I see in the log:
2022-08-15 13:06:56.439 | INFO     | __main__:<module>:48 - OS: posix
2022-08-15 13:06:56.441 | DEBUG    | __main__:get_env_ip_list:71 - Environement discovered IP List []
2022-08-15 13:06:56.444 | DEBUG    | __main__:get_local_ip_list:64 - Locally discovered IP List ['removed for security']
2022-08-15 13:06:56.444 | INFO     | __main__:<module>:126 - Broadlink will try to discover devices on the following IP interfaces: ['removed for security']
2022-08-15 13:06:56.445 | INFO     | __main__:<module>:135 - Configuring app
2022-08-15 13:06:56.447 | INFO     | __main__:get_analytics_code:179 - Content: <script async src="https://www.googletagmanager.com/gtag/js?id=UA-131664523-2"></script>
    <script>
        window.dataLayer = window.dataLayer || [];
        function gtag() { dataLayer.push(arguments); }
        gtag('js', new Date());
        gtag('config', 'UA-131664523-2');
    </script>
2022-08-15 13:06:56.455 | INFO     | __main__:<module>:652 - Broadllink Manager is up and running
INFO:     Started server process [7]
INFO:     Waiting for application startup.
INFO:     Application startup complete.
INFO:     Uvicorn running on http://0.0.0.0:7020 (Press CTRL+C to quit)
WARNING:  Unsupported upgrade request.
WARNING:  No supported WebSocket library detected. Please use 'pip install uvicorn[standard]', or install 'websockets' or 'wsproto' manually.
Hi all…got this setup fine following the HACS path however I cannot find my RM4 Pro when doing the scan.
Firewall checks out - HA running on RPi4 in main LAN with connection to all VLAN + RM4 Pro connected to IOT VLAN which has explicit access to the RPi only - and validated against other devices that have some setup and visible in HA.
2022-10-03 08:51:07.033 | INFO     | __main__:search_for_devices:603 - Searcing for devices...
2022-10-03 08:51:07.034 | INFO     | __main__:search_for_devices:605 - Checking devices on interface assigned with IP: 192.168.0.27
2022-10-03 08:51:12.038 | INFO     | __main__:search_for_devices:605 - Checking devices on interface assigned with IP: 172.17.0.1
2022-10-03 08:51:17.041 | INFO     | __main__:search_for_devices:605 - Checking devices on interface assigned with IP: 172.30.32.1
2022-10-03 08:51:22.045 | DEBUG    | __main__:search_for_devices:622 - Devices Found: []
INFO:     172.30.32.2:59500 - "GET /autodiscover HTTP/1.1" 200 OK
INFO:     172.30.32.2:59500 - "GET / HTTP/1.1" 200 OK
I have also tried to use the Broadlink integration and can connect via that so that confirms that firewall is not the issue.
Any assistance here or pointers would be much appreciated.
Hi there!
I’ve been using broadlind and home assistant for some time. I managed to discover the codes corresponding to my Panasonic TV during a period of time when I had an Android phone.
Today I tried capturing the corresponding codes to my Cambridge CXA61 amplifier and after trying multiple options, I managed to sniff the “mute” command using the Node-Red option: Broadlink - Home Assistant
This is what the sniffed code looks like:
38,0,48,0,27,31,58,59,56,31,28,30,27,31,29,30,27,32,27,58,28,31,57,60,27,0,11,123,31,28,56,59,59,30,28,30,28,29,29,29,29,30,29,59,28,30,56,60,29,0,13,5,0,0,0,0,0,0,0,0
I tried converting it to broadlink_base64 using irgen but I did not succeed. Whichever input type that I tried, resulted in an error.
Also, at some point I read that an HA add-on was available but I did not manage to find it in the list of available add-ons after including the repo in my setup: Home Assistant repo added but add-on not found ¡ Issue #66 ¡ t0mer/broadlinkmanager-docker ¡ GitHub
Could somebody help me understand what sort of code format did I sniff, and how I could include it in my configuration.yaml?
Note that by using node-red I managed to sniff the code and I also managed to verify it works using the guidance in the documentation:
I thank you in advance
Hi, same here. Do you fixed it? Device works even with homeassistant, but Broadlink manger cant find it. Tested Windows, Docker and addon version.
EDIT: Just found the solution: run a continous ping from a device to the rm4 pro and then scan. And try iot more than once
Todo:
  • Import data from Broadlink app.
Is this still coming? Maybe bad asking this 3 and a half years later… But learning RF commands is quite buggy to me. It works, but the commands are unreliable, where as the commands i learned inside the broadlink app work perfect.
Never could get it working. In the end I got a Bond Bridge which worked straight away with zero hassle
