Hi @Tomer_Klein,
I still get the error, although I updated to the last version (version of June 16).
Hereās my container log:
* Serving Flask app "broadlinkmanager" (lazy loading)
* Environment: production
WARNING: This is a development server. Do not use it in a production deployment.
Use a production WSGI server instead.
* Debug mode: on
* Running on http://0.0.0.0:7020/ (Press CTRL+C to quit)
* Restarting with stat
* Debugger is active!
* Debugger PIN: 303-923-301
192.168.2.2 - - [16/Jun/2020 14:51:12] "[37mGET / HTTP/1.1[0m" 200 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /css/adminlte.min.css HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /js/bootstrap.bundle.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /js/jquery.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /css/all.min.css HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /js/adminlte.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /js/hex.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /js/home.js?V=4 HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:12] "[36mGET /js/clipboard.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:16] "[36mGET /img/broadlink.png HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:51:16] "[37mGET /img/clippy.svg HTTP/1.1[0m" 200 -
192.168.2.2 - - [16/Jun/2020 14:51:23] "[37mGET /discover HTTP/1.1[0m" 200 -
/usr/local/lib/python3.6/dist-packages/werkzeug/filesystem.py:60: BrokenFilesystemWarning: Detected a misconfigured UNIX filesystem: Will use UTF-8 as filesystem encoding instead of 'ascii'
BrokenFilesystemWarning,
192.168.2.2 - - [16/Jun/2020 14:51:30] "[35m[1mGET /ir/learn?type=0x2733&host=192.168.2.13&mac=34ea34f5aa72 HTTP/1.1[0m" 500 -
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 2464, in __call__
return self.wsgi_app(environ, start_response)
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 2450, in wsgi_app
response = self.handle_exception(e)
File "/usr/local/lib/python3.6/dist-packages/flask_restful/__init__.py", line 272, in error_router
return original_handler(e)
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 1867, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.6/dist-packages/flask/_compat.py", line 39, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 1821, in handle_user_exception
raise value
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python3.6/dist-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/opt/broadlinkmanager/broadlinkmanager.py", line 201, in learnir
dev.enter_learning()
AttributeError: 'sp2' object has no attribute 'enter_learning'
192.168.2.2 - - [16/Jun/2020 14:51:32] "[35m[1mGET /rf/learn?type=0x2733&host=192.168.2.13&mac=34ea34f5aa72 HTTP/1.1[0m" 500 -
raise value
raise value
File "/opt/broadlinkmanager/broadlinkmanager.py", line 247, in sweep
dev.sweep_frequency()
AttributeError: 'sp2' object has no attribute 'sweep_frequency'
192.168.2.2 - - [16/Jun/2020 14:53:27] "[37mGET / HTTP/1.1[0m" 200 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /css/all.min.css HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /js/bootstrap.bundle.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /js/hex.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /css/adminlte.min.css HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /js/jquery.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /js/adminlte.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /js/home.js?V=4 HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:27] "[36mGET /js/clipboard.min.js HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:31] "[36mGET /img/broadlink.png HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:53:31] "[36mGET /img/clippy.svg HTTP/1.1[0m" 304 -
192.168.2.2 - - [16/Jun/2020 14:55:13] "[35m[1mGET /ir/learn?type=0x2733&host=192.168.2.13&mac=34ea34f5aa72 HTTP/1.1[0m" 500 -
raise value
raise value
192.168.2.2 - - [16/Jun/2020 14:55:15] "[35m[1mGET /rf/learn?type=0x2733&host=192.168.2.13&mac=34ea34f5aa72 HTTP/1.1[0m" 500 -
raise value
raise value
192.168.2.2 - - [16/Jun/2020 14:55:30] "[37mGET /about HTTP/1.1[0m" 200 -
192.168.2.2 - - [16/Jun/2020 14:55:40] "[37mGET / HTTP/1.1[0m" 200 -
