That’s really weird. Can you access the device in the Broadlink e-Control app? Is your HA instance on a separate VLAN? Are you pinging it from the HA instance?
I’m wondering if there’s something network-wise that’s preventing HA from seeing it. I have this issue from time to time when crossing VLANs, but it almost always clears itself up after restarting HA.
Sundenly it stops to work and platform is not aviable again, and I did nothing. I’ve stop squid and erase firewall rules, so port 80 is not longer translated to 8080, but the same warnig remains in my HA logs.
Broadlink remote is working on broadlink app and I’ve not separated on difererents instances my HA network and the rest, this is some thing in my todo list (So no vlans).
Can any one with nmap installed post the output of this command?
nmap -p80 broadlink_ip
This’s my output
[REMOVED]$ nmap -p80 192.168.1.53
Starting Nmap 7.80 ( https://nmap.org ) at 2020-01-21 17:01 CET
Nmap scan report for 192.168.1.53
Host is up (0.0043s latency).
PORT STATE SERVICE
80/tcp closed http
Nmap done: 1 IP address (1 host up) scanned in 0.08 seconds
There is a problem with the new broadlink protocol, if python.broadlink discovers your device as 0x5f36:
./broadlink_discovery
Discovering ...
Unknown
# broadlink_cli --type 0x5f36 --host 192.168.1.53 --mac 5f5d7aa7df24
Device file data (for use with --device @filename in broadlink_cli):
0x5f36 192.168.1.53 5f5d7aa7df24
This device won’t learn new commands. There is a gritub issue (#537) that explains the problem.
On the other hand, if you connect your mini 3 with the new broadlink app, it will never connect to HA (That was my problem). You must to reset it and configure it with the old e-Connect or IHC app.
That’s a really bad news. I tried to reset it and to connect to e-Connect without success.
Is this something on which someone is working or it will be impossible to use with HA?
Try IHC app, e-Connect doesn’t work to me, but IHC does. Anyway if broadlink_discovery discover it as type 0x5f36 there is nothing to do right now, it doesn’t work with HA.
