where do I change the broadlink.py??
I am not sure I understand what you mean here. After you call the learn service, it listen for a packet for 20 seconds.
Could be solved by a script/automation. Then you can also customize the delay between each transmitt
Sorry, I mean when you execute the command, the IR emitter flashes too briefly, it should be longer. It barely picks up
We need consider that RM will learn the first 433 315 or ir signal it get…
If you have something emitting close to it… it will learn fast and stop the red light
RF is fine eitting, IR is too short emitting
I don’t know where to put this new broadlink.py file. There is no broadlink.py to be substituted in my .homeassistant directories
It should listen for 20 seconds or until it gets a signal, and I think mine is.
Sorry for not beeing clear. I don’t know for how long it listens. I think the signal is picked up well (I think). When I execute the command the broadlink device emits the IR (LED turning on) for a very short time.
Is like pressing the original remote for a very short time. The IR receiver of the projector, or whatever, does not pick it up because too short, I think
Yes… the original learning process learns as long as you keep pressing the ir button and reproduces the same time you pressed…
Could it be done the same way?
mmhhhh I pressed it a long time (like 5 seconds). But when is beeing executed the LED emits very shortly, I don’t know if emits for 5 seconds (as learned command) or less as it seems from the LED of the broadlink device blinking very shortly)
In any case the projector does not pick the signal (I need to press the original remote for some seconds to have it picked up)
version 0.35.xx is crashing randomly on mac, 0.34.xx with custom_components was working perfect.
You can crash it in few seconds by switching on/off two switches 10-20 times, also crashes via homebridge.
> INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service_data=entity_id=switch.socket_1, service=turn_off, domain=switch, service_call_id=4339826760-48>
> ERROR:homeassistant.core:Error doing job: Task exception was never retrieved
> Traceback (most recent call last):
> File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/switch/broadlink.py", line 148, in _sendpacket
> self._device.send_data(packet)
> File "/Users/mac/.homeassistant/deps/broadlink/__init__.py", line 376, in send_data
> self.send_packet(0x6a, packet)
> File "/Users/mac/.homeassistant/deps/broadlink/__init__.py", line 235, in send_packet
> response = self.cs.recvfrom(1024)
> socket.timeout: timed out
Other smaller issue.
Since I have two broadlink, how can I get temperature from both?
- platform: broadlink
update_interval: 60
host: 192.168.1.89
mac: 'bxxf'
monitored_conditions:
- temperature
you answer to me? In case yes, wHere is this?
I don’t know, an iPad (acting as home kit hub) was not responding from outside the local network. So I restarted everything (rm pro, the mac where HA is running, the wifi router, the iPad, iPhones - even turn the water on and off ) now, the problem is gone… I spent hours last night trying to figure it out, but didn’t occur to me that it can be the iPad messing it all up.
In the same way that I learned you how to set up two switch devices earlier : Broadlink RM-PRO and A1 sensor
for me is also intermittent. I was not able to reproduce a pattern. Now after a full restart is not working …
Yes, i did a quick test, I can choose different device under service, it show up as learn_command_learn_ip_address1 and learn_command_learn_ip_address2, the learning functions work on both device, thanks for the quick rewrite.
By the way, have you got the code for fixing the copy and paste problem from the persistent notification? Thanks
I am not sure how to fix that problem yet.
But currently you can get the same data from the log/console if you enable log level info for broadlink.
But I have a lot of sensors, do I have to rename them all (sensor 1, sensor 2?)
- platform: yr
- platform: netatmo
station: Gilma
modules:
Gilma_outdoor:
- temperature
Gilma_Bedroom:
- temperature
- min_temp
- max_temp
- co2
- pressure
- humidity
- platform: fitbit
monitored_resources:
- "body/weight"
- "activities/steps"
- platform: openweathermap
api_key: !
latitude: !
longitude: !
- weather
- temperature
- wind_speed
- humidity
- pressure
- clouds
- rain
- snow
sensors:
alarm_time:
friendly_name: 'Time'
value_template: '{{ "%0.02d:%0.02d" | format(states("input_slider.alarmhour") | int, states("input_slider.alarmminutes") | int) }}' #- platform: mqtt
#### TIME/DATE ##################################
- platform: worldclock
time_zone: Europe/Rome
# state_topic: "owntracks/tablet/tablet"
# name: "Battery Tablet"
# unit_of_measurement: "%"
# value_template: '{{ value_json.batt }}'
update_interval: 60
host: 192.168.1.89
mac: '!0f'
- temperature
# Broadlink living room
switch 1:
platform: broadlink
host: 192.168.1.89
mac: 'b!'
switches:
p11_asus_router:
command_on: 'slMyAAWSDgYFDw4GDgYFDwUPDgYEEAQQBQ8FDw4GBBAOBgUPDgYEEAUPBQ8EDw4GDgYFDwUPAAAAAAAA'
command_off: 'JgAcAB0dHB44HhweGx4cHR06HB0cHhwdHB8bHhwADQUAAAAAAAAAAAAAAAA='
friendly_name: 'Asus router'
