No, you can just add another sensor 2:
below
Ok, thanks
I just tested it more with the new code, seems like the code break the on/off button icon, the switch function still work but the icon doesn’t change state, i revert back to the old broadlink.py fixed the problem.
I just figured it out. New version out
Mine works with this:
- platform: broadlink
update_interval: 60
host: 192.168.1.153
mac: 'b4:43:0d:38:46:c2'
monitored_conditions:
- temperature
update_interval: 60
host: 192.168.1.225
mac: 'b4:43:0d:70:0e:b5'
- temperature
- humidity
- air_quality
- light
- noise
two times broadlink, and no problem? Ok
gee, you are quick, tested with new version, problem solved, cheers.
where do you put the new broadlink.py file?
It depends on your setup, mine one is here /srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/switch
If you go to this link, it tells you where the path of that file is.
https://github.com/home-assistant/home-assistant/compare/broadlink?expand=1
mine is on:
/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/switch
If you are getting an error message with “ValueError: AES key must be either 16, 24, or 32 bytes long”
it would be great if you could try this version:
Download the file and put it in HA_CONFIG_FOLDER/custom_components/switch/broadlink.py
Report back how it goes.
You can also put it in custom_components/switch/broadlink.py
keeping the file in
or changing in bth directories?
well I put both files (I think 2 different versions…)
It shows the choice to learn from 1 or other broadlink, but the learning command does not work, giving the usual error
16-12-20 15:45:51 homeassistant.components.http: Serving /api/services/broadlink/learn_command_192.168.1.89 to 192.168.1.52 (auth: True)
16-12-20 15:45:51 homeassistant.core: Bus:Handling <Event call_service[L]: service_data=, service_call_id=1978023984-25, domain=broadlink, service=learn_command_192.168.1.89>
16-12-20 15:45:51 homeassistant.core: Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1049, in _event_to_service_call
yield from service_handler.func(service_call)
File "/home/hass/.homeassistant/custom_components/switch/broadlink.py", line 70, in _learn_command
broadlink_device.enter_learning)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/home/hass/.homeassistant/deps/broadlink/__init__.py", line 381, in enter_learning
self.send_packet(0x6a, packet)
File "/home/hass/.homeassistant/deps/broadlink/__init__.py", line 214, in send_packet
aes = AES.new(bytes(self.key), AES.MODE_CBC, bytes(self.iv))
File "/srv/hass/hass_venv/lib/python3.4/site-packages/Crypto/Cipher/AES.py", line 95, in new
return AESCipher(key, *args, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/Crypto/Cipher/AES.py", line 59, in __init__
blockalgo.BlockAlgo.__init__(self, _AES, key, *args, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/Crypto/Cipher/blockalgo.py", line 141, in __init__
self._cipher = factory.new(key, *args, **kwargs)
Is it possible to add the assumed_state attribute so can change the switch icon?
I just tried it here as well…
Sorry, please ignore my question. It is working already.
I was adding the attribute under the broadlink platform, it should be added under customize like this.
customize:
switch.broadlink_switch:
assumed_state: false
similar error
16-12-20 16:21:51 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 192.168.1.3 (auth: True)
16-12-20 16:21:51 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service=turn_on, service_data=entity_id=switch.asus_router, service_call_id=1977274416-7>
16-12-20 16:21:51 homeassistant.core: Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=['switch.asus_router'], service_call_id=1977274416-8>
16-12-20 16:21:52 homeassistant.core: Error doing job: Task exception was never retrieved
File "/home/hass/.homeassistant/custom_components/switch/broadlink.py", line 164, in _sendpacket
self._device.send_data(packet)
File "/home/hass/.homeassistant/deps/broadlink/__init__.py", line 376, in send_data
File "/home/hass/.homeassistant/deps/broadlink/__init__.py", line 235, in send_packet
response = self.cs.recvfrom(1024)
socket.timeout: timed out
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/switch/__init__.py", line 87, in async_handle_switch_service
yield from switch.async_turn_on()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 353, in async_turn_on
None, ft.partial(self.turn_on, **kwargs))
File "/home/hass/.homeassistant/custom_components/switch/broadlink.py", line 150, in turn_on
if self._sendpacket(self._command_on):
File "/home/hass/.homeassistant/custom_components/switch/broadlink.py", line 173, in _sendpacket
return self._sendpacket(packet, max(0, retry-1))
File "/home/hass/.homeassistant/custom_components/switch/broadlink.py", line 170, in _sendpacket
self._device.auth()
File "/home/hass/.homeassistant/deps/broadlink/__init__.py", line 169, in auth
response = self.send_packet(0x65, payload)
hi, which file is now covering what?
i have a broadlink.py under sensor - for an e-air (A1) – which i understand i have to remove after i upgrade.
but for my switch i have to keep the broadlink.py under custom_components/switch
corect?
after giving it a go the point seems moot: turns out I have an SP3 (SPCC-EU-ENG officially),
any chance of supporting the SP3cc… any time soon?
thanks for the good work btw.
