namadori
(Namadori)
August 3, 2017, 8:56pm
612
Update: sometimes the sensor displayed weird values like 31.29999999997 instead of 31.3, so I added in the template the rounding to one decimal (scroll right the code snippet to see).
sensors:
broadlink_corrected:
value_template: '{{(states(''sensor.broadlink_sensor_temperature'') | float - 3 ) | round (1)}}'
friendly_name: 'Broadlink corrected'
unit_of_measurement: '°C'
(snippet edited to include parentheses as suggested by keithh666)
If someone can explain this behaviour…
OMG
(Robert)
August 5, 2017, 6:22am
613
Thanks - used this to create wind speed sensor in Km/H instead of m/s. However the round (1) doesn’t seem to be working …
- platform: yr
monitored_conditions:
- temperature
- symbol
- precipitation
- windSpeed
sensors:
new_windspeed:
value_template: '{{states(''sensor.yr_wind_speed'') | float * 3.6 | round (1)}}'
friendly_name: 'Wind Speed'
unit_of_measurement: 'Km/H'
keithh666
(Keith Hull)
August 5, 2017, 2:49pm
614
{{(states(‘sensor.yr_wind_speed’) | float * 3.6) | round (1)}}
namadori
(Namadori)
August 5, 2017, 4:43pm
615
Thanks, I edited the previous message to reflect your suggestion
Hi Im having problem with this one. Something wrong with the template. Im using HASS.IO on RPi3.
2017-08-24 00:12:45 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: unexpected char ‘‘’ at 11) for dictionary value @ data[‘sensors’][‘new_windspeed’][‘value_template’]. Got ‘{{ (states(‘sensor.yr_wind_speed’) | float * 3.6) | round (1) }}’. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
keithh666
(Keith Hull)
August 23, 2017, 4:18pm
617
Try double quotes round the outside not single, you can’t have single quotes followed by single quotes, the parser won’t know what’s going on.
my yaml config file like below:
value_template: “{{ (states(‘sensor.yr_wind_speed’) | float * 3.6) | round (1) }}”
Error from HA:
2017-08-24 20:36:47 WARNING (MainThread) [homeassistant.helpers.condition] Value cannot be processed as a number:
Try:
{{ (states.sensor.yr_wind_speed.state | float * 3.6 | round (1)) }}
Thank you, its working great now.
Hi guys,
I’ve encountered a strange problem when trying to hook up my Broadlink A1 with Home Assistant.
Here is the sensor configuration:
- platform: broadlink
host: 192.168.2.216
mac: 'aa:aa:aa:aa:aa:aa'
update_interval: 60
- temperature
- humidity
- air_quality
- light
- noise
But log throws:
2017-08-28 20:40:19 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform broadlink
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for return fut.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/broadlink.py", line 60, in setup_platform broadlink_data = BroadlinkData(update_interval, host, mac_addr, timeout)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/broadlink.py", line 109, in __init__ self._device = broadlink.a1((ip_addr, 80), mac_addr)
AttributeError: 'module' object has no attribute 'a1'
I’ve ensure all the dependencies are installed via apt-get
and pip3 install
, also A1 is visible and reporting on Android app. I am really stuck at this one.
Any suggestion?
hi
i run Home Assistant on windows 10.
my problam is whwn i try to run Home Assistant, i got “Attempting install of broadlink==0.5” and it want work!
i try to do the same as you write, but no matter what i do i cant install install broadlink==0.5
the error i get is:
Command “c:\users\davidof_pc\appdata\local\programs\python\python36-32\python.exe -u -c “import setuptools, tokenize;file =‘C:\Users\DAVIDO~1\AppData\Local\Temp\pip-build-6amjebk1\pycrypto\setup.py’;f=getattr(tokenize, ‘open’, open)(file );code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file , ‘exec’))” install --record C:\Users\DAVIDO~1\AppData\Local\Temp\pip-xwsprt2z-record\install-record.txt --single-version-externally-managed --compile” failed with error code 1 in C:\Users\DAVIDO~1\AppData\Local\Temp\pip-build-6amjebk1\pycrypto\
this is the full log, can you help?
pip install broadlink==0.5
Collecting broadlink==0.5
Using cached broadlink-0.5.tar.gz
Collecting pycrypto==2.6.1 (from broadlink==0.5)
Using cached pycrypto-2.6.1.tar.gz
Installing collected packages: pycrypto, broadlink
Running setup.py install for pycrypto … error
Complete output from command c:\users\davidof_pc\appdata\local\programs\python\python36-32\python.exe -u -c “import setuptools, tokenize;file =‘C:\Users\DAVIDO~1\AppData\Local\Temp\pip-build-6amjebk1\pycrypto\setup.py’;f=getattr(tokenize, ‘open’, open)(file );code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file , ‘exec’))” install --record C:\Users\DAVIDO~1\AppData\Local\Temp\pip-xwsprt2z-record\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build\lib.win32-3.6
creating build\lib.win32-3.6\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.6\Crypto
copying lib\Crypto_init _.py -> build\lib.win32-3.6\Crypto
creating build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash_init _.py -> build\lib.win32-3.6\Crypto\Hash
creating build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher_init _.py -> build\lib.win32-3.6\Crypto\Cipher
creating build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util_number_new.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util_init _.py -> build\lib.win32-3.6\Crypto\Util
creating build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random_UserFriendlyRNG.py -> build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random_init _.py -> build\lib.win32-3.6\Crypto\Random
creating build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna_init _.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
creating build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG_init _.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
creating build\lib.win32-3.6\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.6\Crypto\SelfTest
copying lib\Crypto\SelfTest_init _.py -> build\lib.win32-3.6\Crypto\SelfTest
creating build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
creating build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
creating build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
creating build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
creating build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
creating build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
creating build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
creating build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
creating build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature_init _.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
creating build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol_init _.py -> build\lib.win32-3.6\Crypto\Protocol
creating build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey_DSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey_RSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey_slowmath.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey_init _.py -> build\lib.win32-3.6\Crypto\PublicKey
creating build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature_init _.py -> build\lib.win32-3.6\Crypto\Signature
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastmath.
building ‘Crypto.Random.OSRNG.winrandom’ extension
creating build\temp.win32-3.6
creating build\temp.win32-3.6\Release
creating build\temp.win32-3.6\Release\src
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Isrc/ -Isrc/inc-msvc/ -Ic:\users\davidof_pc\appdata\local\programs\python\python36-32\include -Ic:\users\davidof_pc\appdata\local\programs\python\python36-32\include “-IC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE” “-IC:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt” “-IC:\Program Files (x86)\Windows Kits\8.1\include\shared” “-IC:\Program Files (x86)\Windows Kits\8.1\include\um” “-IC:\Program Files (x86)\Windows Kits\8.1\include\winrt” /Tcsrc/winrand.c /Fobuild\temp.win32-3.6\Release\src/winrand.obj
winrand.c
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(26): error C2061: syntax error: identifier ‘intmax_t’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(27): error C2061: syntax error: identifier ‘rem’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(27): error C2059: syntax error: ‘;’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(28): error C2059: syntax error: ‘}’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(30): error C2061: syntax error: identifier ‘imaxdiv_t’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(30): error C2059: syntax error: ‘;’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(40): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2146: syntax error: missing ‘)’ before identifier ‘_Number’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2061: syntax error: identifier ‘_Number’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2059: syntax error: ‘;’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(42): error C2059: syntax error: ‘)’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(45): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2146: syntax error: missing ‘)’ before identifier ‘_Numerator’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2061: syntax error: identifier ‘_Numerator’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2059: syntax error: ‘;’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2059: syntax error: ‘,’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(48): error C2059: syntax error: ‘)’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(50): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(56): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(63): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(69): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(76): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(82): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(89): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(95): error C2143: syntax error: missing ‘{’ before ‘__cdecl’
error: command ‘C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.exe’ failed with exit status 2
yes, i am on that over 4 day’s!!! it seems that pycrypto cannot install
i got this error when i try to install it:
Could not find a version that satisfies the requirement pycrypto (from versions: )
No matching distribution found for pycrypto
Without pycrypto, you will not be able to install the broadlink component.
Pycrypto seems to be a problem on Windows. There are several posts about pycrypto and windows in the forum. Try to see if any of them can help you.
i tried to look, but iam not such a tech savy… any way you know how to get Pycrypto to work on windows?
thank you!
i read al that (and it’s alot) and still no fix
I just tried it here as well…:slight_smile:
I went from Windows, not the best experience, to an old Mac Mini, perfect but not the best support, using up kit I had lying about but ended up biting the bullet and getting a Pi because there’s always someone out there who’s been there or done that.
I have an A1 sensor that stops reporting temp in homeassistant (temp gets stuck) but there are no errors in my log. Sometimes after a short period, others it has lasted up to a week. A restart of homeassistant gets it working again.
Anyone else seen the same. My A1 is used to control heating so this is obviously causing me some trouble!
oliverdog
(Fernando)
November 16, 2017, 2:35pm
631
Yes, I was used to face the same problem, it was suddenly stopping send temp, hum and all sensors values… and a restart on HASS always fixed the problem, until 0.54 update, after that the problem is gone (I am still on 0.54). I still have this problem with a SP-Mini AC power switch… it stops working and a HASS restart is enough…
