I’m trying to integrate my Broadlink TC2 switches that I have around the house because I have a lot of them. I managed to read as much as I could about this in last week or so.
Tried all option that are described to get the codes and there is only one that I managed to use, partially successful. I mean partial because I’m getting codes but I am not able to use them in any way that would actually turn the light on or off.
Getting the codes for TC2 but also for another “test” RF remote:
Install the Broadlink App on my Android Mobile.
Add RM Pro+ that I have to be visible in the app
Add Broadlink 1-Gang TC2 switch in the application.
Install the “Raspbery PI” version of the Broadlink Manager as intructed here: https://en.techblog.co.il/2020/06/24/installing-broadlinkmanager-on-raspberry-pi/?doing_wp_cron=1617368340.0250070095062255859375
Connect to the webgui of the Broadlink Manager.
press “Actions” on the button corresponding with my RM Pro+
Press “Learn RF Code”
Go to the Broadlink App on my mobile and Press Long the ON for the TC2 switch.
Broadlink Manager is changing the status to “Click Continue button” so I did just that on “Continue Scanning” button.
On the Broadlink Manager the message changed to “To complete learning, single press the button you want to learn”
Went on the Broadlink App on my mobile again and Pressed the ON for the same TC2 switch.
On the Broadlink Manager the message changed to “RF Scan Completed Successfully” and I am getting a code:
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
(you can do the same actions to get the code for OFF or as a matter of fact for any other RF, so I tried with a small RF for power sockets and it is learning them as well, same kind of format, some of them shorter, some of them longer but same format)
Then went to HA and configured the switch:
switch:
- platform: broadlink
host: 192.168.2.4
mac: "78:0F:FF:FF:FF:F0"
switches:
- name: OfficeCeilling
command_on: 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
command_off: 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
Restart HA.
Tried with the TC2 codes for ON and OFF.
Tried the same config with the small RF remote.
Then when I select that switch for some actions (ON or OFF), I can see the orange light from the Broadlink RM turning ON but there is no action. Lights or sockets does not turn on or off. For me is looking that the code that is send, is not the right one, but this is a guess.
Can you please let me know what I am doing wrong here so how I can have it corrected to have my TC2’s working?
Thank you!
PS: Noticed today that pressing TC2 OFF on the app, will give each time slightly different code. No clue if that is right or wrong, here you can see it as I tried three times same “OFF” button:
agBwBAAClRzfCgoXAAFwCQoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoAAUngCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAALf3woKFxcKChcKFwoXChcKFwoXChcKFwoXChcKFwoXFwoKFwoXGAkKFwoXFwoXCgoXChcKFwoXFwoKFxcKGAkXCgoXCgABSeAKChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKAAFpCQoXCgABSeAKChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoLFgoAAUngCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXAAGBFgoKFwoXChcKFxcKChcXChcKFwoKFwoAAUngCgogFwkKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAFJ4AoKFxcKChcKFwoXChcKFwoXChcKFwABaRYKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAFJ4AsJFxcKChcKFwoXChcKFwoXChcKFwoXChcKFwoXGgkKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoXCgABSeAKCgABZxYKChcKFwoXChcKFwoXChcKFwoXChcKFwoXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoXCgABSeAKChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoAAnPfCgoXFwoLFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAFJ4AoKFxcKChcKFwoXChcKFwoXChcKFwoXChcKFwoXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoXCgACruAKChcXCgsYCRcKFwoXChcKFwoXChcKFwoYCRcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoAAUngCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKCgABbgkXChcKFxcKChgWChcKFwoKFwoAAUngCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAXcAAAAAAAAAAA=
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
agBsBAACmBvfCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKCh4JFwoXChcXCgoXFwoXChcKChcKAAG/4AoKFxcKChcKFwoXChcKFwoXChcKFwoXChcKFwoXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoXCgABSeAKChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoAAbjfCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcZCRcKChcKFwoXChcXCgoXFwoXChcKChcKAAFJ4AoKFxcKChcKFwoXChcKFwoXChcKFwoXChcKFwoXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoAAWcJChcKAAFJ4AoKFxcKChcKFwoXChcKFwoXChcKFwoXChcKFwoXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoYCwABSOAKChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcAAWgWCgoXChcKFwoXFwoKFxcKFwoXCgoXCgABSeAKChcZCQoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoXFgoAAUngCgoXFwoKFwoXChcKFwoXChcKFwoXCgABcwkXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoAAUngCgoXGAkKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAFJ4AoKFwABhwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAFJ4AoKFxcKChcKFwoXChcKFwoXChcKFwoXChgKFwoXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoXCgACad8KChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcLFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoAAUngCgoXFwoKFwoXChcKFwoXChcKFwoXChcKFwoXChcXCgoXChcXCgoXChcXChcKChcKFwoXChcXCgoXFwoXChcKChcKAAFn3woKFxcKChcKFwoXChcKFwoXChcKFwoXChcKGQkXFwoKFwoXFwoKFwoXFwoXCgoXChcKFwoXFwoKFxcKFwoXCgoXCgABSeAKChcXCgoXChcKFwoXChcKFwoXChcKFwoXChcKFxcKChcKFxcKChcKFxcKFwoKFwoXChcKFxcKChcXChcKFwoKFwoABdwAAAAAAAAAAAAAAAA=
Partial success!
I manged to make the RF remote working when learning new RF devices (non-Broadlink)
The solution is to…do exactly as instructed by the Broadlink Manager.
When told you to press long, then press long. When told you to press once, then press once.
Once you get the code, test it with Broadlink Manager "Send Command (IR/RF). If it works there, then is done. If does not work, learn it again. Key is on the second scan, the short press, to be just right length. It is trial and error.
Total succes!
TC2 added as well after following MichielioZ advice:
- You need a proxy sniffing tool that can decode https. On mac, you can get Proxymand. I used on Windows 10 Fiddler Classic. Fiddler does not do the job by default so you need to configure it a little bit.
Tools -> Options -> HTTPS -> Check: Decrypt HTTPS traffic
Tools -> Options -> Connections -> Check: Allow remote computers to connect
- Add all your TC2 or any other switches working with the default Broadlink app on your phone.
- Create separate “General scenes” (this is what I used, might work with others, don’t know) in that app for every wall switch that you have, every action that switch have.
For example if there is a TC2 - 2 Gang, you need to create one scenes for that switch where you add every action for that switch as device: Main Switch ON, Main switch OFF, Switch 1 ON, Switch 1 OFF, Switch 2 ON, Switch 2 OFF. (the scenes making is extremely important part)
- Install on your mobile, the old IHC app (I installed the IHC for Europe) that is the old Broadlink app.
- Close the Broadlink app on your mobile.
- Go to your mobile and turn off Mobile Data.
- Go to your wireless settings of your phone, go to advanced and set the proxy there. Proxy IP should be your PC where you are running Fiddler Classic. Port is 8888 by default on Fiddler.
- Test going to some website on your phone browser and check in Fiddler if you can see the traffic. If not, then check firewall settings on the PC where you run FIddler to allow incoming traffic to port 8888.
- If all works good, start sniffing network from PC with Fiddler
- Start the IHC app on your mobile.
- Log in the IHC with your Broadlink account (need to be the same account as you used in the Broadlink app)
- Let it work for a while as traffic will start to come to the Fiddler and then it will slow down. Still wait a little bit longer (1-2 minutes) as it will not hurt, just to be sure that you got what is needed.
- Look in the logs from your sniffer for where the IHC app imported the scenes you made earlier. You can search based on scene names (use some unique names if you can)
- Usually the logs shows first the code then the action. Example order is “code” “Switch ON” “code” Switch OFF"
- The code is in hexa so you need to convert it to base64 to use in HA.
- Go to Broadlink Manager and use the Convert HEX-Base64 functionality form there and then with the Base64 code, use it in the same application in the Devices -> Actions -> Sent command (IR/RF) to test it. If it works and your TC2 respond to the action, then success. If not, got back to sniffer and figure out what you need to copy and try again. Data is there, you just need to figure out the exact part of it.
