Trying to connect my RM4 mini on Broadlink integration, but I type the IP address from router and from app, end after time out it says unable to connect… I have the same issue on the Harmony integration… same problem
Im new on this and my skills are terrible… I use a DECO mesh network… Maybe could be some authentication problem on my wifi router or something else.
The RM4 only works on 2.4 GHz, which can make setting it up a bit baffling. When I was doing mine I turned off the 5 GHz wi-fi channel until it the Broadlink was working.
Moving to “AP” will make your life easier, but if you don’t want to, you’ll probably have to do some port forwarding on the DECO, as your wifi devices and your HA are not on the same VLAN
Well sure. You moved your HA to the DECO VLAN.
That might break other things, though. Any integrations using upnp that are not on the same VLAN won’t work anymore
Good morning
I’m taking the liberty of reviving this topic because I’m trying to show someone the capabilities of Home Assistant. So I installed Home Assistant on a macOS M2 computer with UTM. It works very well. My goal is to be able to show the capabilities of Home Assistant so that I can control a television with Broadlink m4 mini.So I integrated Broadlink in my Ha but i have this message
“Hôte” should be “Host” which is the IP-address of the RM4 mini within your local network.
If you have not already done so you need to install the BroadLink app on your phone first to connect the RM4 mini to your WiFi network.
Follow the steps shown with the BroadLink app on your phone until the RM4 has successfully connected to your WiFi network. Then leave the BroadLink app. Don’t let it register the RM4 mini to the Broadlink cloud!
Now check your router for connected WiFi devices. If you have successfully connected the RM4 mini to your LAN you should see it’s IP address on your router’s “connected devices” page.
Now insert that IP address into the “Hôte”-field (see your above screenshot) and hit “VALIDER”.
If you have done it correctly the RM4 mini should have successfully registered to Home Assistant.
Good morning
Sorry but it’s impossible to configure the R4 mini with Home Assistant. If I enter the IP address of my router which is 192.168.1.103 I get this message
