Please help I can’t us the rm2 pro in home assistant
thanks but i already tried this, is not working
I was refering to this:
And you should look how rm2 is referred to and change it accordly.
Sorry. Your case a bit different.
The editing above is not permanent. If it doest not work and you can’t find the specific solution for your case, you´ll have to wait until a new release recognize your model.
Im using PROXMOX that is running supervisor (without docker) and I’m bought the RM4 Pro from Aliexpress and when I’m trying to add on my HA, I’m receiving the same error “Device is not supported”. Someone could help me to solve the integration, please? Thank you guys.
What is the error log telling when trying to add the RM4 Pro through the Broadlink Integration?
You will have to wait till the new device code is included in HA or maybe try to circumvent including the new code using the method explained above (in case it works, it won’t survive a reboot).
And the RM4C Mini is STILL* unsupported in 2022.7.2. Is there a way to make the Mini work with HA? Or do I need to return it and get the Pro?
I tried this and it doesn’t work.
This worked for me. Two changes:
0x520D
instead of 0x6539
← which I found in the logs as described above.
python3.10
instead of python3.8
when changing directory
