Hello
Can not add the new Broadlink RM4C (RM mini 4) HA.
And can’t find it with Broadlink Manager.
Has anyone found a solution for this?
Hello
help us help you. Provide all information possible, like configurations you tried. errors in logs, etc.
It’s not supported.
Vote for it to be supported in Feature Requests.
I voted.
Any news with RM4 mini ?
Support is coming, according to this:
Maybe 0.109?
Does broadlink.send works for you on 0.109 with RM4C mini ?
I have an RM4 Pro… and no… it doesn’t seem to work.
i tried both:
and both with rm4c_pro and rm4_pro as Type (not sure about the difference).
No joy
Matteo
I’m new to Home Assistant, my version is the stable one 0.109.2. I own a RM4C Mini, it has been reset to be only included in the local network and not in the cloud.
I setup the configuration.yaml file as below
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
switch:
- platform: broadlink
host: 192.168.1.18
mac: '24:DF:A7:34:96:04'
type: rm4c_mini
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
I can see in the services both broadlink.lean and broadlink.send
Now I’m not sure what is the good way to operate a learn and a send. Can you please help ?
Thanks a lot,
Manu
o.k. HA version 0.109.4 released already
Does broadlink.send works for anyone with RM4C mini ?
It’s should be supported on version 0.109 already.
Hi, I was wondering how you set up your RM4C Mini for local network only. I’ve had a heck of a time just getting it connected to my network through their app. If you have a moment to let me know how you made it to be local only I’d appreciate it. Thanks!
The point is to avoid any RM4C link to the cloud, to do so here is the procedure:
Got it…thank you! Yeah, saw that in the documentation a bit after I sent the message to you. Thanks again!
Have the same question. I can reach my Broadlink mini 3 via this way and also execute the commands for learning/sending. But I don’t get any code back which I can implement in my automations
Solved it: I accidently configured my Broadlink in the yaml as “remote” and not as a ""switch. After configuring it as a “switch” everything worked like it’s described in the documentation
Maybe for you @dragonslore: I learned all commands like it’s described in the documentation. It goes like this:
Developer Tools -> Services -> broadlink.learn -> host: (IP of your Broadlink) --> call service
After you called the service: Point your remote controller in the direction of the broadlink and press the button you want to implement. Then you get the code you need as a notification (just copy it from there). I did this with every buttons I wanted to implement and saved the codes in an excel table. In my last step I followed the instructions of this video: https://youtu.be/CEwuMh80CSA?t=445 (with the exception of using node red instead of the Hassio automation tool) to create some switches etc. in my interface. Hope that helps
The only thing I don’t know until now is how to implement a volume slider or a status update for my booleans (e.g. that after a restart, Hassio knows that my receiver is on).
Thank you so much LC7894, I tried again this morning after upgrading my home assistant to last version available and it works now like a charm (learn + send).
That’s how it should be! Nice!
Just setup with 0.109 and RM4 Pro. All working good thanks for the setup advice. In order to get the RF signals working see here onwards: https://youtu.be/CEwuMh80CSA?t=661
i have a problem, my Broadlink app need internet to set up rm4c but it connect with cloud automaticaly. So i cant connect rm4c to my Home Assistant.
Can you show me how?
To all.
I have RM4C mini and i configure it as a “remote” and all “remote.learn_command” and “remote.send_command” work well.
Step by step how i did it (hope this would be helpfull):
remote:
type: rm4c_mini
host: 192.168.1.11
mac: '24:DF:A7:4F:78:D3'
entity_id: remote.rm4_mini
device: ac
command:
- turn on
- turn off
Send example:
device: ac
delay_secs: 2
command:
- turn on
- turn off
how do you configure the wifi without the broadlink app, the ihc app does not know the rm4c
