It cannot control the overall device volume setting, but only the relative volume of the audio sent to the browser_mod media player device.
I started using a wall mounted tablet with Fully kiosk and would like to be able to set the theme automatically, so found browser_mod, which is great.
Unforunately, it seems i canāt get it to work.
I try with a basic automation script:
- id: tablet theme
alias: Browser tablet1 - Set custom theme
- minutes: /1
platform: time_pattern
- data:
deviceID:
- cdd414ea-f9905d9e
service: browser_mod.set_theme
initial_state: 'true'
No errors in the logs and the automations triggers:
2020-05-28 11:58:00 INFO (MainThread) [homeassistant.components.automation] Executing Browser tablet1 - Set custom theme
2020-05-28 11:58:00 INFO (MainThread) [homeassistant.components.automation] Browser tablet1 - Set custom theme: Running script
2020-05-28 11:58:00 INFO (MainThread) [homeassistant.components.automation] Browser tablet1 - Set custom theme: Executing step call service
Allready tried clearing cache and restarted Fullyā¦
What am i doing wrong ?
I have a panel in my living room that has multiple views. There is a left hand menu that can be used to switch between pages / views. This works well.
I would like to have the panel go to the main page after a period of inactivity. Users walk away from the panel after using it and often leave it on one of the additional views. The main view is where the important information is and I like to be able to view this as a default.
My entity for the panel is sensor.living_room_panel
and I have the following attributes
type: browser_mod
last_seen: '2020-05-28T07:52:48.872415'
deviceID: a5c9f6d9-8f78aacf
path: /lovelace-panel/main
visibility: visible
userAgent: >-
Mozilla/5.0 (Windows NT 10.0; ) AppleWebKit/537.36 (KHTML, like Gecko)
Chrome/83.0.4103.61 Safari/537.36
currentUser: tablet
width: 1280
height: 800
I am struggling to write an automation that will change the panel path back to /lovelace-panel/main after a period of inactivity on another page, example /lovelace-panel/climate I have multiple other views / paths that the table might have been left on.
Can anyone help me?
Thank you Thomas for your quick reply. I have figured out that if the browser_mod device has an alias in the config file, the browser-player wonāt recognize it as the same device and therefore wonāt control it. The workaround solution is to remove the alias for the device and use long ID everywhere. Regards and thanks again.
Hmā¦ thatās a bug.
Thanks for letting me know!
Someone suggestions ?
Is it possible to have an iframe
as the popup? Neither of these display anything when I click the button but the button does āshadowā so the press is registered.
- type: custom:button-card
icon: mdi:123
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: Title
card:
type: iframe
url: /local/page/index.html
This next one was a guess
icon: mdi:123
tap_action:
service_data:
title: Title
card:
type: custom:hui-elements
card_type: iframe
and yes, this does display the iframe
- type: iframe
I tried the options to play audio on the desired device with the following options:
entity_id: "media_player.browser_513b4669"
message: 'de bel!'
language: 'nl'
entity_id: media_player.browser_513b4669
media_content_id: 'http://hass:8123/local/audio/doorbel.mp3'
media_content_type: music
It works well in the browser and chromecast devices but not in the Android HASS app. I have to open the Android app and tap the volume slider or mute/unmute the audio once.
Then it works fine for a while. Then it stops working after a sudden time.
Could this the same as with the Apple behavior?
First of all, great job @thomasloven with this custom component!
Iāve just started using it to override the more-info popup with my own entity card, following the instructions in the componentās ReadMe. However, I noticed the history graph of the entity in not shown anymore when more-info is overridden.
Is there an easy way to display that at the bottom of my entity card popup as in the original more-info dialog?
Thanks in advance
Thanks @thomasloven!
Are you saying that I can define multiple cards in the lovelace interface?
This is how I have defined it so far:
"popup_cards": {
"switch.my_light": {
"card": {
"entities": [
"entity": "switch.my_light"
"entity": "input_select.my_input_select"
"show_header_toggle": false,
"type": "entities"
"title": "bar"
Can I just go ahead and queue another āfooā history-card after the ābarā entity-card?
The popup accepts only one card, for more you need the vertical-stack.
popup_cards:
switch.my_light:
title: bar
card:
type: vertical-stack
cards:
- type: entities
entities:
- type: history-graph
hours_to_show: 24
refresh_interval: 10
entities:
Thereās also more-info-card which displays the more-info dialog, but as a card, so you canā¦ show the more-info-dialog in the more-info-dialogā¦ dawgā¦
No, really, this is the reason I made it.
Cool, good to know, thanks!
very nice im just lookig for thise! you make a solution?
Not yet, I took a break from my UI. Was getting burnt out.
upon updating to 0.111, thereās a new error in the startup log:
2020-06-11 09:41:51 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2894248144] Received invalid command: browser_mod/connect
not sure it is fatal or not, but Iāve never seen that before, so maybe an issue with 111? Or has the logging simply been improved upon.
Youāre not the only one seeing those on 0.111: https://github.com/thomasloven/hass-browser_mod/issues/105
