šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
correct, only works with native cards, as it seems most custom cards havenā€™t implemented handling fire-dom-event as thomasloven mentioned.
I previously used browser_mod for popups in conjuction with the custom button card. I just changed to used the new call-service method thomasloven mentions in his updated readme, but with the native button card, since the custom button card doesnā€™t yet support the fire-dom-event mentioned.
I just did this today because I heavily use popups for my key-master integration for lock codes, and didnā€™t want to roll back browser-mod 1.2.3 that will soon break HA. Once, custom:button-card can support the fire-dom-event, ill switch back to have more control over the button card styling, but the native one works just fine in my scenario here.
below is a snippet
- type: button
  icon_height: 30px
  entity: binary_sensor.active_frontdoor_1
  #template: lock_manager_button
  tap_action:
    action: fire-dom-event
    browser_mod:
      command: call-service
      service: browser_mod.popup
      service_data:
        title: 'Code 1'
        style:
          background: var(--champs-theme-primary)
        card:
          type: entities
          show_header_toggle: false
          entities:
            - type: divider
            - entity: input_text.frontdoor_name_1
Hopefully this will help some of you
@thomasloven I noticed in your call-service section of the readme, that there was an extra colon listed
what you have:
command: call-service:
service: <service>
service_data:
  <service_data>
what I needed:
service: <service>
service_data:
  <service_data>
Well there goes my night!
Edit: Ah! This needs to be in big bold text somewhere!
A good chunk of my browser_mod commands are toast which run on all devices! Whew :grinning:
Anyone issues?
running latest HA and hacs and it stopped working here
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/connection.py:84
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10 februari 2021 20:50:32 (1 occurrences)
Last logged: 10 februari 2021 20:50:32
[547968919776] Received invalid command: browser_mod/connect
I donā€™t think I fully understand the changes. For instance, how would following code look in 1.3.0?
    tap_action: &media_tap_action
      action: >
        [[[ if (entity.state === 'off' || entity.state === 'idle' || entity.state === 'standby') {
        return 'none'; } else { return 'call-service'; } ]]]
      service: media_player.media_play_pause
      service_data:
        entity_id: '[[[ return entity.entity_id ]]]'
      haptic: light
Or a simple popup
 tap_action: !include popup/activity.yaml
Same question here. Iā€™m using browser_mod as ā€œmore-infoā€ popup in the same way:
popup_cards: !include NdRUI/ndrui_popup.yaml
And ndrui_popup.yaml.
  sensor.group_sensori_porta:
    title: "Sensori Porta / Finestra"
    style:
        .mdc-dialog .mdc-dialog__container {
          width: 100%;
        .mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
          width:100%;
          box-shadow:none;
        :host {
          --mdc-theme-surface: rgba(0,0,0,0);
          --mdc-dialog-min-height: 100%;
          --mdc-dialog-min-width: 100%;
          --mdc-dialog-max-width: 100%;
        mwc-icon-button {
          color: #FFF;
    card:
      type: entities
      entities:
        - entity: sensor.scurone_sala
          type: custom:multiple-entity-row
          secondary_info: last-changed
          entities:
            - entity: sensor.scurone_sala_battery
            - entity: sensor.scurone_sala_linkquality
        - type: section
        - entity: sensor.lucernaio_studio
          entities:
            - entity: sensor.lucernaio_studio_battery
Iā€™m not sure on how to adapt this code to the new versionā€¦
Not at all.
That method is still in the readme, so itā€™s still valid.
I turned back version ,have to read first:p how to fix it before upgrading
@thomasloven
My popups dont work on latest version
Old code:
action: call-service
service_data:
  title: Information
  hide_header: true
  deviceID: this
  style:
      :host .content {
        width: calc(400px);
        align: center;
        background: none !important;
  card:
    type: custom:vertical-stack-in-card
    cards:
      - type: markdown
        content: <font color="#1A73E8" size= "5">Batterij niveaus</font>
        style: |
          ha-card {
            background-color: transparent !important;
            box-shadow: none !important;
Do i need to change it to
browser_mod:
  command: popup
  service_data:
    title: Information
    hide_header: true
    deviceID: this
    style:
        :host .content {
          width: calc(400px);
          align: center;
    card:
      cards:
        - type: markdown
          style: |
            ha-card {
browser_mod:
  command: popup
  title: Information
  hide_header: true
  card:
Itā€™s worth repeating that this doesnā€™t work with custom cards like custom:button-card yet.
Does it have a sense to ask if there is any roadmap or process set to have custom components compatible?
Then we canā€™t update to the latest version :stuck_out_tongue:
Can anyone explain to me how to set global styles for popups. For instance the color in the header - I see that app-toolbar in ha-dialog is responsible for that. And it has color set to var(--primary-text-color). I thought/read about two possible solutions:
  1. By modifying variables in theme configuration.
    Letā€™s say primary-text-color: green. It works for the cards directly placed in the dashboard, but in the popup the value of primary-text-color is not correct.
  2. By adding css styles to theme configuration (in themes.yaml).
    card-mod-theme: tablet # <<< What this does?
    card-mod-more-info-yaml: | #<<< Is this correct? Why is that "-yaml" conditional according to the card-mod docs?
        app-toolbar {
          color: green;
And stillā€¦ color: green not added to the app-toolbar.
Worth noting that setting styles for specific popup like this works correctly:
      service_data:
        title: '[[[ return entity.attributes.friendly_name ]]]'
        deviceID: this
        card:
          type: entities
          entities:
            - type: custom:light-popup-card
              entity: '[[[ return entity.entity_id ]]]'
              icon: none
              fullscreen: false
              brightnessWidth: 130px
              brightnessHeight: 360px
              borderRadius: 1.7em
              sliderColor: '#c7c7c7'
              sliderTrackColor: rgba(25, 25, 25, 0.9)
              actionSize: 4.5em
              actionsInARow: 2
              style:
                  .popup-inner > .icon, .popup-inner > #brightnessValue {
                    display: none;
But Iā€™d rather not to copy styles for every popup I create. Am I doing something wrong? Thanks in advance.
Hi, since the last update in 1.3.0, I canā€™t open popups anymore using browser_mod.popup
You need to change the Service call
It was mentioned in the release notes
I understand the changes for the service calls. But I still donā€™t no how to change an action like this to the new browser_mod.
Hi
I canā€™t understand the new option of the fire-dom-event,
- entity: alarm_control_panel.home_alarm
icon: mdi:shield
offStates:
- ā€œdisarmedā€
offIcon: mdi:shield-off
hold_action:
service_data:
card:
states:
- arm_home
# - arm_away
type: alarm-panel
deviceID:
- this
What It should be now ?
hold_action:
  browser_mod:
    command: popup
    card:
Remove
deviceID:
  - this
This doesnā€™t work in custom-cards at the moment, but should work with alarm-panel.
thank you, I tried this with custom media-player, but it doesnā€™t work.
any guidance is appreciated.
Hello i need help with the new update, i canā€™t cope with the new version, and i donā€™t know how to get the new popup windows back?
old code :
              - type: horizontal-stack
                cards:
                  - type: 'custom:button-card'
                    icon: 'mdi:thermostat-box'
                    show_icon: true
                    show_name: false
                    state:
                      - value: 'on'
                        styles:
                          card:
                            - box-shadow: >
                                [[[ return states['sun.sun'].state ==
                                'below_horizon'
                                  ? 'inset -4px -4px 5px rgba(60, 60, 60, .6), inset 4px 4px 5px rgba(0, 0, 0, .5)'
                                  : 'inset -3px -3px 5px rgba(255, 255, 255), inset 3px 3px 5px rgba(0, 0, 0, .08)';
                          icon:
                            - color: var(--paper-item-icon-active-color)
                    styles:
                      card:
                        - width: 80px
                        - height: 80px
                        - margin: 10px
                        - border-radius: 15px
                        - box-shadow: >
                            'below_horizon'
                              ? '-5px -5px 10px rgba(50, 50, 50, .2), 6px 6px 10px rgba(0, 0, 0, .08)'
                              : '-5px -5px 8px rgba(255, 255, 255, .5), 5px 5px 8px rgba(0, 0, 0, .03)';
                        - background-color: var(--primary-background-color)
                      icon:
                        - color: var(--primary-text-color)
                    tap_action:
                      service: browser_mod.command
                      service_data:
                        card:
                          type: 'custom:thermostat-card'
                          entity: climate.termostat_salon_danfos_thermostat
                          small_i: true
                          title: Salon
                        command: popup
                        deviceID:
                          - this
                        title: Termostat Salon
new code:
                cards:
                    show_icon: true
                    show_name: false
                    state:
                      - value: 'on'
                        styles:
                          card:
                            - box-shadow: >
                                'below_horizon'
                          icon:
                    styles:
                      card:
                        - width: 80px
                        - height: 80px
                        - margin: 10px
                        - box-shadow: >
                            'below_horizon'
                      icon:
                    tap_action:
                      browser_mod:
                        command: popup
                        card:
                          small_i: true
                          title: Salon
                        deviceID: this
