If you read the post before yours you will find the answer
+1
I read lots of people having problems here whith custom cards not supporting new version
I advise to not update to latest version then, since there are so many problems with it?
@thomasloven: is there any reason why you pushed this new version forward, knowing custom cards will have problems with lots of people?
The reason and all the breaking changes are explained on the changelog in HACS and github.
Also, this change will make sure that browser_mod does not break Home Assistant 2021.3.0 (sic!).
Itās a shame people donāt read all the changes before pressing update. There is a button called āchangelogā in HACS. And shame people donāt take 2 minutes of their time to read the thread and other peoples comments before coming here and posting pop-up cards donāt work.
There is NO reason to update right now. Everything will work fine without hitting that update button. Just wait for RomRider and others to update their cards and then update. Also when HA 2021.3 is released (which older browser_mod will break) you can still just wait. Not updating the latest version will not suddenly break your current setup if you just leave everything the way it is for a little longer.
For people using button-card, RomRider has just updated his card
fire-dom-action
should now work with any custom:button-card action (tap, hold, doubletap)
thank you.
Iāve added onto it.
I noticed two interesting errors since yesterday:
Logger: homeassistant
Source: helpers/entity.py:268
First occurred: 17. Februar 2021, 19:28:35 (1 occurrences)
Last logged: 17. Februar 2021, 19:28:35
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 268, in async_update_ha_state
raise RuntimeError(f"Attribute hass is None for {self}")
RuntimeError: Attribute hass is None for <Entity None: 1>
and then
Logger: homeassistant.components.websocket_api.http.connection
Source: helpers/entity.py:422
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 17. Februar 2021, 19:28:35 (4718 occurrences)
Last logged: 8:17:49
[1708808248] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/connection.py", line 95, in async_handle
handler(self.hass, self, schema(msg))
File "/config/custom_components/browser_mod/connection.py", line 42, in handle_update
devices[deviceID].update(msg.get("data", None))
File "/config/custom_components/browser_mod/connection.py", line 89, in update
self.sensor.data = data.get('browser')
File "/config/custom_components/browser_mod/helpers.py", line 106, in data
self.updated()
File "/config/custom_components/browser_mod/sensor.py", line 27, in updated
self.schedule_update_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 422, in schedule_update_ha_state
assert self.hass is not None
AssertionError
Obviously every minute.
Who can tell me, what I should look for.
Iām on 2021.1.4 and on the latest browser_mod.
I use it only for popup cards, configured in the lovelace yaml and as alarm clock - so play a media file at a given time
everything seem to work so far.
Nice to hear button card has the update.
I still got a question though
i got this:
type: custom:button-card
tap_action: !include popup/alarm.yaml
entity: alarm_control_panel.risco
and then the popup starts with
action: call-service
service: browser_mod.popup
service_data:
title: Alarm
hide_header: true
deviceID: this
style:
:host .content {
width: calc(400px);
.mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
background: none !important;
card:
type: alarm-panel
etc etc
Does the button card needs the update there, or the alarm panel card ?
Youāre envoking the popup using a button-card tap_action. So you need to update button-card tap_action. Alarm Card does not open the popup, itās part of the popup itself.
Hy i update butto-card today but all my user interface is againg broken. When i tap ho button card the pop up not open. Someone can help me please.
This is an example:
- type: 'custom:button-card'
entity: alarm_control_panel.ksenia_bticino_bt_4000_16ip
tap_action:
action: fire-dom-event
browser_mod:
command: popup
title: 'My Title'
card:
type: 'custom:mini-graph-card'
entities:
- sensor.temeperatura_18
try this in your alarm.yaml
mapping values are not allowed in line 3
please post your code so that we can see where the error is
browser_mod:
command: popup
title: Alarm
hide_header: true
deviceID: this
style:
:host .content {
width: calc(400px);
card:
type: alarm-panel
states:
- arm_home
- arm_away
Yes! Working thx mate !
Yay, looks like browser_mod popups are working with custom:button-card now with the new update
Hello!
First of all. Thank you for the great mod. Now to my Problem. I tried to find a solution but I didnt find anything:
For me the X of close button is not aligned with the button itself. So I just want to ask if there is a fix for this to make it aligned in every popup window.
Can someone tell me how to uninstall browser mod correctly?
- I unstalled it from integrations
- I removed it from configuration.yaml
- I deleted it from the folder custom components
- I deleted it from hacs
- I searched in entitites, all are gone
I still got many errors, they are flooding my logs!:
ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139683299554112] Received invalid command: browser_mod/update
about the popup and other services, do you know that itās impossible to call any services as popup, toast, command from the devepoler tools page? So in this way itās impossible to call the services in any other part of lovelace! Moreover the popups are solved only for button and button custom card, but if you need to call a popup in any other card (like entities) clicking on entity is impossible, so the call-service doesnāt work anymore!
I have the same problem here, so very interrested how to solve that.
