Hi Chris
Thanks for the reply. I had read this information in the Doc. I just donāt know where to insert them in the automation
Hi Chris
Ah, ok. Does this work? (I have to admit Iāve never tried it myself!)
- id: '1642017204324'
initial_state: true
alias: System - Dashboard - Display Doorbell Cam
description: ''
<snip>
condition: []
- service: browser_mod.popup
large: true
auto_close: true
title: TĆ¼rklingel
style:
$: ".mdc-dialog__surface {\n background: transparent !important;\n border-style:\
\ none !important;\n border: 0px !important;\n box-shadow: none;\n}\n"
card:
<snip>
- alias: "Wait 20s"
delay: 20
- service: browser_mod.close_popup
I just installed browser mod. I read the doc and now Iām trying out some things:
It seems popups only work over secure (HTTPS) sessions. So, it works over my Nabu Casa account, but not over a local (HTTP) connection. Is that intentional?
Iām trying to rename entities using
browser_mod:
prefix: "browser_mod_"
disable:
- media_player
- camera
devices:
<device-id1234>:
Iāve restarted HA a couple times, but it never renames the entities. Is that still functional or is something wrong with my syntax?
Not for the life of me can I get the alias working. Itās like a catch 22. When I access Lovelace from a client, all three devices/entities gets created with the deviceID
. In my case light.browser_5697e4d9_ee89c964
. When I add name: in the yaml file, it does not change the devices or entities to remove the deviceID
In reading the following issues link, it states that you cannot change the name of already created entities. It recomends changing the deviceID
. But upon doing so, it creates a NEW entitiy with the deviceID
, hence putting you back in the same loop.
How are you supposed to change the name of the entity?
Hey,
Iāve install Browser_mod from HACS
added ābrowswer_mod:ā to configuration.yaml
trying to launch:
title: Popup example
large: true
hide_header: true
auto_close: true
time: 20
and nothing happend, no popupā¦
Can someone help me?
āfrom HACSā means only in HACS or on HA integration page as well?
[quote=āChenH, post:1457, topic:123806, full:trueā]
Install on HACS.
I see several entities on the integration page but they all āUnavailableā
I tried to reinstall browser_mod, clear browser cache and still no popup
Can you always paste as code?
And secondly, can you please test such an example in developer tools?
card:
type: entities
entities:
- light.bed_light
- light.kitchen_lights
- light.ceiling_lights
Paste the code,
Press ācall serviceā
It gives me green āVā and nothing more, no popup
[/quote]
Please share the relevant part of configuration.yaml
just added there (configuration.yaml):
browser_mod:
Then unfortunately I have currently no other idea. Refresh Browsercache? Or try another clean browser directly?
thanks a lot.
Iāll keep trying
Could it be that what is missing in the config data
is the deviceID:
browsermod-device-id-or-alias that will tell browsermod which device you want the popup to appear on.
No. Working without.
Might be a stupid question,
Why does the popup card for more-info only works on local network but not when your outside of local network?
When i use my phone(android) on local network the popup card shows up, but when i turn off my phoneās wifi and try to use the popup more info it does not show up.
To follow upā¦it seems that there are quite a few issues since 2022.5. Now that Iām confident about my syntax, here are the things Iāve observed as a new browser_mod user:
@thomasloven Do you have everything you need to troubleshoot these issues? Like I said above, I think theyāre covered one way or another by current GitHub issues. Also, along with an alias entity_id, is there a way to change the friendly_name of each entity via the configuration? Thank you.
Is it possible to get the read deviceID of the current browser in a Javascript Template on a lovelace card ?
Did you ever find a solution to this?
Is it possible to make the pop up on mobile not take the entire screen?
