šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
The popup syntax changed.
Check this out.
Sorry if it was already asked.
I successfully managed to change the simple popup with new version.
However, was not able to change the simple close of current popup.
How do I change this:
  tap_action:
    action: "fire-dom-event"
    browser_mod:
      command: "close_popup"
Another question.
Is there and option to hide the popup header, like it was before?
The command is deprecated. There is a new service for close popup. Everything is clearly documented.
Yes, I tried of course to change to the below:
  tap_action:
    action: fire-dom-event
    browser_mod:
      service: browser_mod.close_popup
        browser_id: THIS
It is not working for me.
What am I missing?
Thank you for a great update. Indeed, it breaks all. Main inconvenience was changed IDs, but new features and improved performance make worth fixing. Finally, popups work properly on hi-res screens. Thanks a lot.
Finally adapted to new changesā€¦even tho it broke most of my scripts and frontend dashboard. thanks to everyone who made this new changes and alredy loving it .
As per wiki more blur have been added but I donā€™t see much blur effects (looks the same for me tho)ā€¦ also I have no idea how to use tts funtion for all browser media? I know we can play sounds from local folder and it works but not sure how to make use of ttsā€¦if anyone could vouch me on blur and tts funtions it would be helpful
tried something like this but doesnā€™t say anything
service: tts.google_say
  entity_id: media_player.xiaomi_pad_5
  message: text
Yeah itā€™s because cloudflare store caches unless the machine reboots or server restart
Thank you for the big update.
Everything is back working well on my setup, but I would prefer the transparency of the old popup card.
Itā€™s possible to set the popup card to less transparency?
Thank you for your work,best regards.
Long time ago, i did some lovelace config , need some help here ; after updating to 2.x, the more info popup card doesnt work anymore, did an update, readded integration
I use template/declutter cardā€¦ not sure how i need to enable it again?
browser_mod:
  disable:
    - all
example button card:
          - type: custom:decluttering-card
            template: button
            variables:
              - entity: light.dimmer1
              - name: Eetkamer
              - label: "[[[ var bri = Math.round(entity.attributes.brightness / 2.55); return (bri ? bri : '0') + '%'; ]]]"
              - icon: spotlight
              - show_state: false
              - margin-right: 40px
pointed to:
  light.dimmer1:
    title: Eetkamer
    style:
      border-radius: var(--border-radius)
      background: grey
    card:
      template: light-popup
      variables:
and this is template:
default:
  - entity: light.yourentity
card:
  type: 'custom:light-entity-card'
  style: |
    ha-card {
      background: var(--homekit-card-off);
      opacity: 0.7;
      border-radius: var(--border-radius);
      color: var(--name-color-off);
  entity: '[[entity]]'
  group: false
  persist_features: true
  header: ' '
Try this:
          tap_action:
            browser_mod:
              data: {}
Now you can use Style variables when calling pop-ups:
      tap_action:
        browser_mod:
          service: browser_mod.popup
            style: '--popup-background-color: transparent;'
            content:
              type: <some-card>
Rewriting my 7000+ lines lovelace, and I stuck with new popups logic.
Now content: type: cards appears in center of the screen even in mobile view.
How can I stylize popup if I want ā€˜startā€™ alignment in mobile view, but I need to keep ā€˜centerā€™ alignment in desktop view? Like in Browser Mod 1.
style: '--vertial-align-dialog: start' changes align for both view modes.
Thanks.
Thank you is exactly what I was looking for
That did the trick.
Thanks!
Is there anyway to change the padding of the popup?
Before I was using Card Mod from theme, this way:
  card-mod-more-info-yaml: |
      .mdc-dialog .mdc-dialog__content {
          padding-top: 0px !important;
I am just a cut and paste monkey and donā€™t get exactly the styling stuff but found something that worked in 1.0 but canā€™t figure out in 2.0.
The effect I am seeking is to blur the screen behind the popup. I have seen the instruction about using strings to affect the popup and played around with these successfully but donā€™t get how to replicate my current 1.0 configuration.
If anyone has any suggestions, I would be grateful. Thomas thanks for your continued contribution to Home Assistant!
Working 1.0 code; example in the style section:
browser_mod:
  command: popup
  deviceID: this
  title: Vaccum
  style:
      app-toolbar {
        color: white !important;
        background-color: #03a4f4 !important;
    $: |                                             #  << THIS BIT HERE! :-)
      .mdc-dialog {
        backdrop-filter: blur(5px) grayscale(50%) !important;
        background: rgba(0,0,0,0.5);
  card:
    type: custom:vertical-stack-in-card
    cards: ......
any toughts why this wont work
          style:
             '--popup-border-color: transparent;'
How do we handle backdrop-filter now?
Can somone help me on this ?
How to add blur on popup background ?
And tts funtion on browser media isnā€™t working too
