šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
      right_button_action:
        service: browser_mod.navigate
          path: /lovelace-tablet/server_ha
Resolved!
with version 2.1.1 its working the blur
          card_mod:
            style:
              ha-dialog$: |
                div {
                  backdrop-filter: blur(3px) !important;
                  background-color: transparent !important
                .mdc-dialog .mdc-dialog__surface {
                  box-shadow: none;
Having trouble porting over from 1.x. Iā€™m calling browser_mod from my frontend like this:
tap_action:
  action: fire-dom-event
  browser_mod:
    service: script.mudroom_lights_menu_test
      browser_id: THIS
      groupID: group.mudroom_lights
And invoking the pop-up from a script like this:
mudroom_lights_menu_test:
  sequence:
    - service: browser_mod.popup
        title: TITLE
        content:
          type: entities
          entities:
            - entity: sensor.motion_count
            - entity: sensor.door_count
    - service: system_log.write
        message: "Popup was clicked in {{browser_id}}"
Nothing ever pops up, however the log entry is written correctly, so I know the script is getting called.
If I embed the pop content directly on the client, the popup works just fine. What am I doing wrong? This is the same pattern I used in 1.x. Iā€™ve tried various of combinations, but havenā€™t been able to figure this one out.
Thank you!
@kbed what is your expected outcome? Is it something like this?
Lights button to control multiple lights -
when pressed it calls more info and a pop up appears
clicking one light turns on All Lights
Since last update things are working great. Thanks!
One small issue I am still having.
I am using the below card mod configuration in theme to remove the top padding inside popup.
It works fine on all the browsers, PC and Android tablets, however on iOS an iPadOS it behaves strange, it works the first time I open the popup, but next time the padding is back. If I just refresh the page it work again, and then next time padding is back again. As if I did not clean the cache, but I did of course.
    ha-dialog$: |
      .mdc-dialog .mdc-dialog__content {
          padding-top: 0px !important;
          -webkit-padding-before: 0px !important;
I think there is some inconsistency here only on iOS/iPadOS.
Yes. I have a button that represents every room in the house, when clicked it brings up the popup similar to your second screenshot where I can control on/off the individual light in the room. Works perfectly with the old browser_mod.
Have you tried a pop-up card?
type: custom:popup-card
entity: light.all_lights
title: All Lights
dismissable: true
card:
  type: entities
  entities:
    - light.all_lights
    - light.adelynns_closet_light
    - light.adelynns_room_light
    - light.backyard_security_light
    - light.basement_light
    - light.cafe_lights
    - light.chandelier_light
So I use 2 cards
type: custom:mushroom-template-card
icon: mdi:lightbulb-group
primary: Lights
icon_color: |-
  {% if is_state('light.all_lights', 'on') %}
    orange
  {% endif %}
layout: vertical
multiline_secondary: false
tap_action:
  action: more-info
double_tap_action:
  action: more-info
secondary: ''
and
title: All Lights
dismissable: true
card:
  type: entities
  entities:
    - light.all_lights
    - light.cafe_lights
    - light.dinning_room_light
    - light.entryway_light
    - light.family_room_light
    - light.front_yard_lights
    - light.garage_light
    - light.guest_bathroom_light
    - light.guest_bedroom_closet_light
    - light.guest_bedroom_light
    - light.kids_bathroom_light
    - light.kitchen_island_light
    - light.kitchen_main_light
    - light.kitchen_sink_light
    - light.laundry_room_light
    - light.living_room_light
    - light.master_bathroom_main_light
    - light.master_bathroom_shower_light
    - light.master_bathroom_water_closet_light
    - light.master_bedroom_light
    - light.mudroom_light
    - light.office_of_mike_light
    - light.pantry_light
    - light.stairs_to_upper_level_light
    - light.upstairs_hallway_light
This makes it fire the popup
The second way is as a browser call. This is when the service is called from a dashboard fire-dom-event action, as a part of a browser_mod.sequence call or as a browser_mod.popup _action
Whats nice is 90% is through the gui now
Thanks. I was hoping I could use my existing setup with minimal tweaks. I make use of scripts and anchors and call the scripts with a parameter so to generalize the code. Would love to keep it this way as it is super clean, and would be a couple of hours of work to try and change it, to something like you mention above.
If Iā€™m reading the documentation correct, it should be possible to call from server side and automations. If for some reasons I canā€™t do that in 2.x, I might just revert back until this can be done.
After updating to the newest browser mod the other day my popup is no longer workingā€¦ anyone run into this?
           tap_action:
              browser_mod:
                title: John's Location
                icon: mdi:car
                card:
                  type: map
                  default_zoom: 15
                  entities:
                    - device_tracker.sm_f926u1
                    #- device_tracker.john_wade
                  aspect_ratio: 16:9
                  hours_to_show: 4
                  deviceID:
                    - this
                    - dashboard
Iā€™m stuck, please help. Want to insert a background imge in this popup card:
tap_action:
  browser_mod:
    command: call-service
      title: DOOR
      dismissable: false
      timeout: 3000
      style: |-
        --popup-min-width: 500px; --popup-max-width: 670px;
        --popup-border-radius: 10px;
        --popup-background: url("/local/door.jpg");
        --popup-border-width: var(--ha-card-border-width, 10px);
      right_button: NO
        service: browser_mod.close_popup
          browser_id: tablet_nappali
      left_button: Door Open/Close!
      left_button_action:
        service: switch.toggle
        service_data:
          entity_id: switch.electrodragon_rele1
This one is not working: --popup-background: url("/local/door.jpg");
So how to do that?
Thank You.
Since the upgrade I am geeting this in the log
Logger: homeassistant.config_entries
Source: config_entries.py:349
First occurred: 09:47:51 (1 occurrences)
Last logged: 09:47:51
Migration handler not found for entry Browser Mod for browser_mod
Any ideas
Hi some yaml items are renamed. You should change this:
to
                content:
                  type: map
This is the complete setupā€¦so still confused why itā€™s not workingā€¦
           tap_action:
              browser_mod:
                icon: mdi:car
                content:
                  type: map
                  default_zoom: 15
                  entities:
                  aspect_ratio: 16:9
                  hours_to_show: 4
                  deviceID:
                    - this
                    - dashboard
            multiline_secondary: true
missing data?
    content:
Second line in ā€œInstallation instructionsā€ in the readme.
Ohhhhhhhhh checked the integerations pageā€¦found thisā€¦
Migration error
Thanks @vMeph and @basbrus ā€¦ itā€™s working again! :slight_smile:
            tap_action:
              browser_mod:
                icon: mdi:car
                  content:
                    type: map
                    default_zoom: 15
                    entities:
                    aspect_ratio: 16:9
                    hours_to_show: 4
                    deviceID:
                      - this
                      - dashboard
deviceID is now browser_id:
If you want to add it globally you can add it to your theme:
    dialog-backdrop-filter: blur(2px) brightness(70%) grayscale(70%)
