Thanks for reply, i formatted my post.
I have read the documentation, the configuration seems to be correct but it does not work.
Maybe i canāt use the service in this way anymore (switch template)?
Your issue has nothing to do with it being in a switch.
I think there are still some lingering issues from the change to browser mod 2.0. There are a handful of things Iāve come across that arenāt working exactly as documented.
I just checked my config, and all my browser_mod.navigate
service calls happen to have a device_id and are working. I wasnāt able to get ithe navigate command to work without a device_id even though the docs suggest it should work (and affect all browsers)
Try constructing your service call using the service tool in Developer Tools. In there, you canāt even call the service without choosing a device to run it on.
This gives you the following in YAML, which absolutely works.
service: browser_mod.navigate
path: /hacs/entry
device_id: 844e8df7e589372a13ee7d6a638afb79
Is there a section in this post where we can set the popupās to not appear on certain devices if a user selects it on their device?
There is information here and here about what browsers a browser_mod service will happen on.
When called like this, the popup will only happen on the browser that initiated the action.
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
content: ...
So Iām using the following code for my doorbell automation which works great. The only issue is that my Amazon Fire Tablet running WallPanel goes into clock screensaver mode after a minute and the browser_mod popup never wakes the screen to show the image. Any workarounds?
content:
type: picture-entity
entity: camera.blueiris_pc_frontdoor
timeout: 5000
title: Front Door
device_id:
- xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Is there any way to work around the need to touch the screen to enable browser_mod (the privacy icon)? Iām only interested in using the window popup function so no need for TTS or camera.
Is it possible to add another brwoser (my wifeās PC) if she doensāt have HA installed?
Hi. So Iām running on a Home Assistant Blue(Odroid N2+)
Home Assistant 2022.10.5
Supervisor 2022.10.0
Operating System 9.3
Frontend 20221010.0 - latest
browser_mod 2.1.3
button_card 3.4.2
I installed browser mod on Sept 16th - Never used it before, so donāt think I have any migration issues. I just started setting up some configs and cannot seem to get any form of āfire-dom-eventā to work.
Full Card Code
- type: 'custom:button-card'
tap_action:
action: navigate
navigation_path: "garage"
template:
- custom_card_room
- grey_off
entity: light.garage_light
icon: mdi:garage
variables:
ulm_icon_tap_action: 'none'
room_card_area_name: 'Garage'
room_card_image_path: '/local/images/garage.jpg'
entity_1:
entity_id: binary_sensor.garage_camera_smart_motion_human
templates:
- grey_off
- purple_on
tap_action:
action: toggle
entity_2:
entity_id: light.garage_light
templates:
- grey_off
- yellow_on
tap_action:
action: toggle
entity_4:
entity_id: switch.garage_vacuum_plug_on_off
templates:
- grey_off
- pink_on
tap_action:
action: toggle
entity_5:
entity_id: switch.garage_fan_single_car_on_off
templates:
- grey_off
- blue_on
tap_action:
action: toggle
entity_6:
entity_id: switch.garage_fans
templates:
- grey_off
- blue_on
tap_action:
action: toggle
entity_7:
entity_id: cover.single_car_garage_door
templates:
- green_closed
- red_open
tap_action:
browser_mod:
large: true
hide_header: true
content: !include garage/garage_doors.yaml
entity_8:
entity_id: cover.two_car_garage_door
templates:
- green_closed
- red_open
tap_action:
action: call-service
service_data:
label: >-
return ' <ha-icon icon="mdi:thermometer" style="width: 16px; height: 16px;"></ha-icon>' +
states['sensor.garage_sensor_temperature'].state + 'Ā°F' +
'<br><ha-icon icon="mdi:water-percent" style="width: 16px; height: 16px;"></ha-icon>' +
states['sensor.garage_sensor_humidity'].state + '%' +
'<br> <ha-icon icon="mdi:snowflake-alert" style="width: 16px; height: 16px;"></ha-icon> ' +
states['sensor.garage_frostrisk'].state
Entity 7/8 garage_doors.yaml
type: 'vertical-stack'
cards:
- type: custom:webrtc-camera
url: >-
rtsp://user:[email protected]:554/cam/realmonitor?channel=1&subtype=1
intersection: 0.75 # auto pause stream when less than 75% of video element is in the screen, 50% by default
muted: true # disable sound, default true
ui: true # custom video controls, default false
shortcuts: # custom shortcuts, default none
top: 0 # top margin in pixels, default 0
left: 0 # left margin in pixels, default 0
orientation: vertical # orientation (horizontal or vertical), default horizontal
- type: "custom:button-card"
template: card_cover
entity: cover.single_car_garage_door
variables:
ulm_card_cover_enable_controls: true
ulm_card_cover_garage: true
entity: cover.two_car_garage_door
variables:
Entity 7 doesnāt work with āfire-dom-eventā, while entity 8 does with call service:
entity_7:
templates:
- green_closed
- red_open
tap_action:
browser_mod:
entity_8:
templates:
- green_closed
- red_open
tap_action:
service_data:
Below, the card - garage doors on the right are entity 7/8. Entity 8 opens the popup, but on all devices. Iām sure this has been covered, but I have scrolled through this thread like mad, and used all examples of fire-dom-event, including what is documented. Can anyone help lead me down the right path to get fire-dom-event working? Or point me to the documentation or an example of fire-dom-events for Developer Tools ā Events and which events to subscribe to figure out if they are even firing?
Edit: Actually I figured it out. While the UI Minimalist Templates are using custom:button-card which supports browser_mod. The Entities within the templates are also using ācustom:button-cardā but the definitions limit them in returns.
Entity 8 for example in my template - Referencing āwidget_icon_roomā
i8:
card:
template: >
var templates = ['widget_icon_room'];
if (variables?.entity_8?.templates?.length) {
return ['widget_icon_room'].concat(variables.entity_8.templates);
return templates;
variables: "[[[ return variables.entity_8; ]]]"
entity: >
if (variables?.entity_8?.entity_id) {
return variables.entity_8.entity_id;
state:
- operator: "template"
value: "[[[ return !variables.entity_8; ]]]"
styles:
card:
- display: "none"
widget_icon_room - I had to add the ābrowser_modā line for tap_action, and hold_action.
widget_icon_room:
variables:
tap_action:
action: "toggle"
hold_action:
action: "more-info"
tap_action:
action: >
[[[ if (variables?.tap_action?.action) return variables.tap_action.action; else return 'none'; ]]]
entity: "[[[ return variables.tap_action.entity; ]]]"
navigation_path: "[[[ return variables.tap_action.navigation_path; ]]]"
url_path: "[[[ return variables.tap_action.url_path; ]]]"
service: "[[[ return variables.tap_action.service; ]]]"
service_data: "[[[ return variables.tap_action.service_data; ]]]"
browser_mod: "[[[ return variables.tap_action.browser_mod; ]]]"
hold_action:
action: >
[[[ if (variables?.hold_action?.action) return variables.hold_action.action; else return 'none'; ]]]
entity: "[[[ return variables.hold_action.entity; ]]]"
navigation_path: "[[[ return variables.hold_action.navigation_path; ]]]"
url_path: "[[[ return variables.hold_action.url_path; ]]]"
service: "[[[ return variables.hold_action.service; ]]]"
service_data: "[[[ return variables.hold_action.service_data; ]]]"
show_icon: true
show_name: false
styles:
grid:
- grid-template-areas: "'i'"
card:
- height: "100%"
- box-shadow: "none"
- padding: "0px"
- border-radius: "50%"
icon:
- width: "50%"
- height: "50%"
- line-height: "0"
- color: "rgba(var(--color-theme),0.2)"
img_cell:
- background-color: "rgba(var(--color-theme),0.05)"
color: "var(--google-grey)"
TLDR; Card templates might be limiting you.
@thomasloven it might be worth adding a note in the documentation about adding returning ābrowser_mod:ā data to card templates if fire-dom-event is not working for a specific card.
Iām playing with popup and i canāt find a way to change font sizeā¦
How to increase fonts in popup card (words " Switch to NET radio?" and āYESā, āNoā) ? Iāve tried a number of things, but nothing works.
type: custom:button-card
entity: script.onkyo_set_net
tap_action:
browser_mod:
autoclose: false
style: |
--font-size: 30px !important;
--popup-border-color: lime;
--popup-border-width: 5px;
--app-toolbar-font-size: 50px;
content: Switch to NET radio?
right_button: YES!
left_button: No!
right_button_action:
service: script.onkyo_set_net
show_name: true
icon: mdi:radio
show_state: false
styles:
card:
- background: cyan
- color: black
- font-size: 30px
- font-weight: bold
- height: 80px
icon:
- color: red
Hi !
Is it normal when I turn off the screen in FKB, the motion binary_sensor becomes active ?
Hi, I am trying to turn off the screensaver in a particular browser/device that has both WallPanel and browser_mod installed but getting nowhere, Iāve followed the instructions here but can get the screensaver to turn off only one device in particular when using an input_boolean?
https://github.com/j-a-n/lovelace-wallpanel/blob/main/README.md#integration-with-browser_mod
wallpanel:
enabled: true
image_order: random
profiles:
device_72429d4d-b7a9d750:
image_url: https://source.unsplash.com/random/${1920}x${1080}?dogs
screensaver_entity: input_boolean.screensaver
device_b79de8c5-bc58aa78:
image_url: https://source.unsplash.com/random/${1920}x${1080}?cats
profile: device_${browser_id}
title: Home
- path: default_view
title: Home
visible:
Hey, thanks for an awesome project.
I found out that itās not possible to play local media on the browsers that are connected over the internet and not via local network. It kinda makes sense given itās local media, but does anyone knows if there is a way how to play a sound on media_player.some_player
that is connected from outside via the internet?
this seems not to work anymore with 2011.11.x
any idea why?
I try to open a more_info from an other entity as showing in the card. So I have create a template to get the sunset up and down from the sun entity. But if i tap at this chip cards I want to sho the more info from the entity sun.sun but nothing happens.
Here is my code:
type: custom:mushroom-chips-card
chips:
- type: entity
entity: sensor.tmp_sun_sonnenaufgang
use_entity_picture: true
icon_color: yellow
tap_action:
service: browser_mod.more_info
entity: sun.sun
large: true
Thank you.
I tried doing a search on this however I didnāt really see a solution unfortunately. I added a new tablet and registered it, all the sensors seem to work and the screen switch also works however the media_player only shows as āunavailableā. Is there a solution to this? Will that only appear if I am using Fully Kiosk? Any way to make that available?
I pretty much gave up on browser mod. Itās just too unreliableā¦ available, not available, availableā¦ i canāt be sure that anything, connected with browser mod will or wonāt work.
Author is being silent for quite a while now, so itās not clear if he gave up on browser mod or is he sick or something (hopefully not).
Hi All,
After a restart of HA I see this error:
2022-11-08 12:58:24.642 ERROR (MainThread) [homeassistant.components.sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_path already exists - ignoring sensor.tablet_browser_path
2022-11-08 12:58:24.650 ERROR (MainThread) [homeassistant.components.sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_visibility already exists - ignoring sensor.tablet_browser_visibility
2022-11-08 12:58:24.652 ERROR (MainThread) [homeassistant.components.sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_userAgent already exists - ignoring sensor.tablet_browser_useragent
2022-11-08 12:58:24.654 ERROR (MainThread) [homeassistant.components.sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_user already exists - ignoring sensor.tablet_browser_user
2022-11-08 12:58:24.657 ERROR (MainThread) [homeassistant.components.sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_width already exists - ignoring sensor.tablet_browser_width
2022-11-08 12:58:24.659 ERROR (MainThread) [homeassistant.components.sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_height already exists - ignoring sensor.tablet_browser_height
2022-11-08 12:58:24.662 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_dark_mode already exists - ignoring binary_sensor.tablet_browser_dark_mode
2022-11-08 12:58:24.664 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Browser_FullyKiosk already exists - ignoring binary_sensor.tablet_browser_fullykiosk
2022-11-08 12:58:24.666 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-activity already exists - ignoring binary_sensor.tablet
2022-11-08 12:58:24.669 ERROR (MainThread) [homeassistant.components.light] Platform browser_mod does not generate unique IDs. ID ae1b43e7-eb57c683-Screen already exists - ignoring light.tablet_screen
What can I do to resolve this?
Hey - @GGexe and @Olivier974 - wanted to share my āfixā for this issue:
I experienced this issue as well and figured out how to resolve it by following the troubleshooting steps in the Lovelace Plugins Ā· thomasloven/hass-config Wiki Ā· GitHub guide, but I do think this may be a bug still.
When installed via HACS, this is added as a lovelace resource. I kept seeing this error described above:
Uncaught SyntaxError: Identifier 't' has already been declared (at browser_mod_panel.js:1:1)
In the troubleshooting steps, Thomas wrote:
Uncaught SyntaxError: Unexpected identifier
You may have specified the resource as type: js when itās supposed to be type: module. Read the docs again to make sure.
So what I did to resolve this was in my configuration.yaml I added an extra_module_url to /browser_mod.js and then removed the resource link under dashboards. Once this was done and I restarted, I was able to view the browser_mod panel in my dashboard.
configuration.yaml example:
frontend:
extra_module_url:
- /browser_mod.js
Not sure if something needs to be changed with the install or with the instructions? But once I adjusted the above and restarted - boom, the panel loads fine now.
HTH!
hello @stratotally
i really appreciate your feedback! thanks
but unfortunately it doesnt work for me.
I redownload Browser_mod in hacs, then do integration part. Then add the config in configuration.yaml and then delete the module line in dashboard.
Browser_mod is on the left side but i still have a blank page when i click on itā¦
Did you restart after adding in the extra_module_url to configuration.yaml?
Edit: AND force a refresh? (in chrome: view inspect, right click on refresh āempty cache and hard reloadā)
