Yes that settings hides the sidebar so you donât see the hamburger menu on the top left.
If you only have a couple of browsers registered, I would delete all of them in the browser mod settings and start over. Sounds like you changed some things and you werenât quite sure what they did. Donât hide any of the side bars until you are sure the browser mod settings are correct for that browser.
I only have 3 registered in the browser_mod settings. And I edited their names as the poured up to aid recognising then to the device. They each got added when I went to the devices browser and then to HA from there.
So what Iâm not sure about it how to get the wall tablet to appear in the browser_mod as a registered device.
Ok thinking about it as I write, so I need to physically open the wall tablet side panel and go to browser_mod menu, then add âthis browserâ as a device in HA. Is that right?
Guys⌠am i right that if i hide header i also disable sidebar? Iâm running fully kiosk and with âhide headerâ set to true i canât access sidebar (at least i donât know how - if i swipe from left to right fully settings appear). Is this correct behaviour?
Second: is there any way to enable/disable these show/hide settings from card? Let me explain: i donât hide my header/sidebar to prevent persons from browsing, but for lovelace to âlook niceâ. Currently iâm using kiosk hacs add-on and i can disable it from lovelace card with toggling âinput_booleanâ defined for it. Can be same achieved here? Since it would make hacs kiosk addon needless thenâŚ
No I donât think the two are linked. As last just now with the help of my daughter whoâs at home, I hide the side bar and it doesnât hide the header. So I assume the reverse would be true.
So I managed to sort out the wall tablet. But not so much joy with my wifeâs iPhone. I wanted to set the default dashboard from browser_mod and also hide the side bar and header. However initially it looks like it worked, but then when the user refreshes the page by dragging down from top of the screen, the original header is back with the hamburger side menu button!
Is there something else to be done for iPhones? I know that Apple are very conservative on third party app controls⌠Ok the android wall tablet and my phone it all works as expected.
Once youâve hidden the side bar on a device you have to disable that from an admin account browser, as far as I know anyway. But yes, with browser mod once itâs hidden, itâs hidden.
Yep, youâre right, thanks. If i have âalways hide sidebarâ enabled in personal settings then sidebar is also unavailable when i hide header from browser mod. However, if sidebar is set to visible then itâs there. Good to know.
OK, if a person is not admin then thereâs not much to do with that account anyway, so itâs acceptable. Before i used kiosk on/off switch to, say, reselect lovelace when blank page appeared on tablet - before at login (or sometimes reset) default lovelace appeared and if a person didnât have access to it a blank page appeared, so iâve had to select personâs lovelace manually from sidebar. Now i can assign default lovelace for each user in browser mod, so that doesnât happen anymore.
Hi, I want to join your discussion, you wrote that you were having problems with the dashboards, I explain my problem to understand if it is the same as yours: I begin to use two dashboards one main that I use for the PC and one for the android tablet with the app (wall dashboard) after updating to browser_mod 2, in the tablet I seem to have a blank page and to view it I have to restart HA or do many refreshes, is it the same problem you had? and is yes can you explain to me the various steps of how you solved it? thank you
I just updated to the 2022.10.3 and now my Browser_Mod is not working as beforeâŚwas there a breaking change and will an update for Browser_mob be released to fix it? I only just got it all working with the help of this threadâŚso I was a bit hacked off that the HA update seems to have broken it again.
Please can anyone else confirm this has happened to them as well with this update?
Thank you for confirming a breaking change to browser_mod do we need to report it on the official github? I would have reverted back to the previous HA but I didnât do the back up and I had made a lot of other changes to the system that dayâŚI have to wait for someone to find the fix for this.
I have the same question. Did you find a solution for this? I donât want the popup to close after clicking the left or right buttons. Tx for your reply.
Hi, what is the most elegant way of calling a popup from another popup?
The code I am using is below, what happens however, is that the second popup âflashesâ the background (since the first popup blurs the background, then the second unblurs it and reblurs it quickly). Is there a better way to achieve this?
Hi, I would appreciate a bit of help - I am trying to move the popup close button âXâ to the right edge instead of the current left. I have managed to move the actual âXâ but it loses the button/close ability.
This is what I have:
