šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
Wonder if itā€™s possible to downgrade ?
yes you can, I just downgraded to 1.5.3 version to avoid the interaction icon
Team, I`m using 1.5.3 version ( to avoid interaction icon which breaks my layout on my tablet ) and using Browser_mod to show front door video stream on tablet when somebody rings. The stream works fine but when I call to close POP window I get ā€œthis entity is unavailableā€
Anyone know what could be causing this?
Had struggles with close too, using auto close now, works really nice for me
@thomasloven should I report this on GitHub as an issue?
Thanks for the wonderful integration btw, reaaaallllllly appreciate your work!!
How can i make a popup centered height-wise on my mobile screen? See picture
Im not that familier with css etc so im a little bit useless in figuring that outā€¦
Downgrading resolved all my issues. Very happy and glad I did so. Everything working reliably again.
my pop up card isnt working can anyone point me in the right direction please?
action: fire-dom-event
browser_mod:
  service: browser_mod.popup
    title: Velux Windows & Blinds
    card_mod:
      style:
        hui-vertical-stack-card:
          $hui-entities-card$: |
            #states {
              padding-top: 0.5em;
              padding-bottom: 0em;
      content:
        type: vertical-stack
        cards:
          - type: custom:mushroom-cover-card
            show_position_control: true
            show_buttons_control: true
            entity: cover.all_kitchen_windows
            actionsInARow: 3
            sliderService: cover.set_cover_position
            entity: cover.all_kitchen_blinds
            fullscreen: true
            actionsInARow: 3
            entity: cover.velux_window_3
            fullscreen: true
            actionsInARow: 3
            entity: cover.velux_window_2
            fullscreen: true
            actionsInARow: 3
            fullscreen: true
            actionsInARow: 3
            entity: cover.velux_internal_cover_2
            fullscreen: true
            actionsInARow: 3
            entity: cover.velux_internal_cover_3
            fullscreen: true
            actionsInARow: 3
            fullscreen: true
            actionsInARow: 3
So to add it pops up but nothing is displayed (empty box) it used to work on v1 i could control my windows etc.
Your code isnā€™t correct. You have content as a card_mod option like style. It needs to be to the left, rigt under title and card_mod
Like in the example in the docs: GitHub - thomasloven/hass-browser_mod: šŸ”¹ A Home Assistant integration to turn your browser into a controllable entity and media player
perfect got it working - THANK YOU
any idea how to have it not transparent ?
You either need to change your theme settings, or add popup styling to either your theme, or through card_mod.
Also in the docs: hass-browser_mod/popups.md at c46fcf222bb9b8a893af9d5f0612576359e24f10 Ā· thomasloven/hass-browser_mod Ā· GitHub
thanks
ive tried
browser_mod:
    card_mod:
      style:
            #states {
              padding-top: 0.5em;
              background: #00809e;
              opacity: 0.9;
    content:
        cards:
and
    card_mod:
      style:
        ha-dialog$: |
          div.mdc-dialog div.mdc-dialog__scrim {
          background: rgba(0, 128, 128, 0.9);
 #         $hui-entities-card$: |
 #           #states {
 #             padding-top: 0.5em;
 #             padding-bottom: 0em;
 #             background: #00809e;
 #             opacity: 0.9;
    content:
but doesnt seem to work
Please post (and change your last post as well) code with code function. Either with funktion in toolbar I editor or with three starting and ending quotes.
This way
Scroll up a few posts and you will find the solution.
done and changed
Easiest solution is to add it to you theme.yaml:
popup-background-color: '#E0E0E0'
Change to color of your liking and make sure you reload the theme service and refresh dashboard.
thank you!
Alright, I will try asking this question again since noone seem to be able to answer or accomplish this.
How can I configure a service utilizing browser_mod that can be called with the call-service-function?
The following example does not seem to work and I donā€™t understand why. Can anyone please share some insight? (Iā€™ve tried browser_mod.console too, and although I can make everything work from the UI/Lovelace it doesnā€™t work as a service.)
  popup_test:
    alias: Popup Test
    sequence:
      - service: browser_mod.popup
          content: Test
          title: Test
using card_mod on a picture card like
  - type: picture-entity
    card_mod:
      style: |
        ha-card {
          {{'filter: invert(100%)' if is_state('binary_sensor.dark_outside','on')
             else 'filter: none'}} ;
    show_state: false
    show_name: false
    entity: camera.weer_roosendaal
works fine in the main view. since its a mainly white card, it turns it into a nice dark card when the sun is set.
however, clicking it to expand it in the more-info brings back the original white card.
Can Browser-mod somehow help me out here? Using yaml, how would I go about doing so?
I did manage to do:
    tap_action:
      browser_mod:
          content:
            card_mod:
              style: |
                ha-card {
            show_state: false
            show_name: false
which opens up the same card (so not really expanded), and when clicking that, it expands and turns white againā€¦
would appreciate any help, thanks
Yes, this is how you exclude browser_mod events from the logbook:
logbook:
  exclude:
    entity_globs:
      - binary_sensor.bbbbbb12345_bbb12345*
      - sensor.bbb12345_bbb12345*
      - light.bbb12345_bbb12345*
      - media_player.bbb12345_bbb12345*
