No I don´t, I´ll need to get home and paste here, I could put the one is on the github from bruh but I could have made something wrong during my copy and paste, and since noone in the github is having the same problem as mine is better to copy exactly mine sketch.
don’t forget to remove your wifi and mqtt private content before putting it on internet!
BTW I have this in the sketch:
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define FASTLED_INTERRUPT_RETRY_COUNT 0
#include “FastLED.h”
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
maybe the FASTLED entry helps for you also
Thank you guys As soon as arrive home I´ll post it here
hi everyone here´s my skecth:
#include <ArduinoOTA.h>/************ WIFI and MQTT Information (CHANGE THESE FOR YOUR SETUP) *************/
const char ssid = “myssid”; //type your WIFI information inside the quotes
const char password = “mypasword”;
const char mqtt_server = “myhassiohost”;
const char mqtt_username = “mymqttusername”;
const char mqtt_password = “mymqttpasword”;
const int mqtt_port = 1883;/**************************** FOR OTA **************************************************/
#define SENSORNAME “porch” //change this to whatever you want to call your device
#define OTApassword “saraiva” //the password you will need to enter to upload remotely via the ArduinoIDE
int OTAport = 8266;/************* MQTT TOPICS (change these topics as you wish) ************************/
const char light_state_topic = “bruh/porch”;
const char light_set_topic = “bruh/porch/set”;const char* on_cmd = “ON”;
const char* off_cmd = “OFF”;
const char* effect = “solid”;
String effectString = “solid”;
String oldeffectString = “solid”;/*FOR JSON/
const int BUFFER_SIZE = JSON_OBJECT_SIZE(10);
#define MQTT_MAX_PACKET_SIZE 512/*********************************** FastLED Defintions ********************************/
#define NUM_LEDS 10
#define DATA_PIN 5
//#define CLOCK_PIN 5
#define CHIPSET WS2811
#define COLOR_ORDER BRGbyte realRed = 0;
byte realGreen = 0;
byte realBlue = 0;byte red = 255;
byte green = 255;
byte blue = 255;
byte brightness = 255;/******************************** GLOBALS for fade/flash *******************************/
bool stateOn = false;
bool startFade = false;
bool onbeforeflash = false;
unsigned long lastLoop = 0;
int transitionTime = 0;
int effectSpeed = 0;
bool inFade = false;
int loopCount = 0;
int stepR, stepG, stepB;
int redVal, grnVal, bluVal;bool flash = false;
bool startFlash = false;
int flashLength = 0;
unsigned long flashStartTime = 0;
byte flashRed = red;
byte flashGreen = green;
byte flashBlue = blue;
byte flashBrightness = brightness;/********************************** GLOBALS for EFFECTS ******************************/
//RAINBOW
uint8_t thishue = 0; // Starting hue value.
uint8_t deltahue = 10;//CANDYCANE
CRGBPalette16 currentPalettestriped; //for Candy Cane
CRGBPalette16 gPal; //for fire//NOISE
static uint16_t dist; // A random number for our noise generator.
uint16_t scale = 30; // Wouldn’t recommend changing this on the fly, or the animation will be really blocky.
uint8_t maxChanges = 48; // Value for blending between palettes.
CRGBPalette16 targetPalette(OceanColors_p);
CRGBPalette16 currentPalette(CRGB::Black);//TWINKLE
#define DENSITY 80
int twinklecounter = 0;//RIPPLE
uint8_t colour; // Ripple colour is randomized.
int center = 0; // Center of the current ripple.
int step = -1; // -1 is the initializing step.
uint8_t myfade = 255; // Starting brightness.
#define maxsteps 16 // Case statement wouldn’t allow a variable.
uint8_t bgcol = 0; // Background colour rotates.
int thisdelay = 20; // Standard delay value.//DOTS
uint8_t count = 0; // Count up to 255 and then reverts to 0
uint8_t fadeval = 224; // Trail behind the LED’s. Lower => faster fade.
uint8_t bpm = 30;//LIGHTNING
uint8_t frequency = 50; // controls the interval between strikes
uint8_t flashes = 8; //the upper limit of flashes per strike
unsigned int dimmer = 1;
uint8_t ledstart; // Starting location of a flash
uint8_t ledlen;
int lightningcounter = 0;//FUNKBOX
int idex = 0; //-LED INDEX (0 to NUM_LEDS-1
int TOP_INDEX = int(NUM_LEDS / 2);
int thissat = 255; //-FX LOOPS DELAY VAR
uint8_t thishuepolice = 0;
int antipodal_index(int i) {
int iN = i + TOP_INDEX;
if (i >= TOP_INDEX) {
iN = ( i + TOP_INDEX ) % NUM_LEDS;
return iN;
}//FIRE
#define COOLING 55
#define SPARKING 120
bool gReverseDirection = false;//BPM
uint8_t gHue = 0;WiFiClient espClient;
PubSubClient client(espClient);
struct CRGB leds[NUM_LEDS];/********************************** START SETUP*****************************************/
void setup() {
Serial.begin(115200);
FastLED.addLeds<CHIPSET, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);setupStripedPalette( CRGB::Red, CRGB::Red, CRGB::White, CRGB::White); //for CANDY CANE
gPal = HeatColors_p; //for FIREsetup_wifi();
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);//OTA SETUP
ArduinoOTA.setPort(OTAport);
// Hostname defaults to esp8266-[ChipID]
ArduinoOTA.setHostname(SENSORNAME);// No authentication by default
ArduinoOTA.setPassword((const char *)OTApassword);ArduinoOTA.onStart( {
Serial.println(“Starting”);
ArduinoOTA.onEnd( {
Serial.println(“\nEnd”);
ArduinoOTA.onProgress((unsigned int progress, unsigned int total) {
Serial.printf(“Progress: %u%%\r”, (progress / (total / 100)));
ArduinoOTA.onError((ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println(“Auth Failed”);
else if (error == OTA_BEGIN_ERROR) Serial.println(“Begin Failed”);
else if (error == OTA_CONNECT_ERROR) Serial.println(“Connect Failed”);
else if (error == OTA_RECEIVE_ERROR) Serial.println(“Receive Failed”);
else if (error == OTA_END_ERROR) Serial.println(“End Failed”);
ArduinoOTA.begin();Serial.println(“Ready”);
Serial.print("IP Address: ");
Serial.println(WiFi.localIP());}
/********************************** START SETUP WIFI*****************************************/
void setup_wifi() {delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(“.”);
}Serial.println(“”);
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
SAMPLE PAYLOAD:
“brightness”: 120,
“color”: {
“r”: 255,
“g”: 100,
“b”: 100
“flash”: 2,
“transition”: 5,
“state”: “ON”
*//********************************** START CALLBACK*****************************************/
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print(“Message arrived [”);
Serial.print(topic);
Serial.print("] ");char message[length + 1];
for (int i = 0; i < length; i++) {
message[i] = (char)payload[i];
message[length] = ‘\0’;
Serial.println(message);if (!processJson(message)) {
return;
}if (stateOn) {
realRed = map(red, 0, 255, 0, brightness); realGreen = map(green, 0, 255, 0, brightness); realBlue = map(blue, 0, 255, 0, brightness);
else {realRed = 0; realGreen = 0; realBlue = 0;
Serial.println(effect);
startFade = true;
inFade = false; // Kill the current fadesendState();
}/********************************** START PROCESS JSON*****************************************/
bool processJson(char* message) {
StaticJsonBuffer<BUFFER_SIZE> jsonBuffer;JsonObject& root = jsonBuffer.parseObject(message);
if (!root.success()) {
Serial.println(“parseObject() failed”);
return false;
}if (root.containsKey(“state”)) {
if (strcmp(root[“state”], on_cmd) == 0) {
stateOn = true;
else if (strcmp(root[“state”], off_cmd) == 0) {
stateOn = false;
}// If “flash” is included, treat RGB and brightness differently
if (root.containsKey(“flash”)) {
flashLength = (int)root[“flash”] * 1000;oldeffectString = effectString; if (root.containsKey("brightness")) { flashBrightness = root["brightness"]; } else { flashBrightness = brightness; } if (root.containsKey("color")) { flashRed = root["color"]["r"]; flashGreen = root["color"]["g"]; flashBlue = root["color"]["b"]; } else { flashRed = red; flashGreen = green; flashBlue = blue; } if (root.containsKey("effect")) { effect = root["effect"]; effectString = effect; twinklecounter = 0; //manage twinklecounter } if (root.containsKey("transition")) { transitionTime = root["transition"]; } else if ( effectString == "solid") { transitionTime = 0; } flashRed = map(flashRed, 0, 255, 0, flashBrightness); flashGreen = map(flashGreen, 0, 255, 0, flashBrightness); flashBlue = map(flashBlue, 0, 255, 0, flashBrightness); flash = true; startFlash = true;
else { // Not flashing
flash = false;if (stateOn) { //if the light is turned on and the light isn't flashing onbeforeflash = true; } if (root.containsKey("color")) { red = root["color"]["r"]; green = root["color"]["g"]; blue = root["color"]["b"]; } if (root.containsKey("color_temp")) { //temp comes in as mireds, need to convert to kelvin then to RGB int color_temp = root["color_temp"]; unsigned int kelvin = 1000000 / color_temp; temp2rgb(kelvin); } if (root.containsKey("brightness")) { brightness = root["brightness"]; } if (root.containsKey("effect")) { effect = root["effect"]; effectString = effect; twinklecounter = 0; //manage twinklecounter } if (root.containsKey("transition")) { transitionTime = root["transition"]; } else if ( effectString == "solid") { transitionTime = 0; }
return true;
}/********************************** START SEND STATE*****************************************/
void sendState() {
StaticJsonBuffer<BUFFER_SIZE> jsonBuffer;JsonObject& root = jsonBuffer.createObject();
root[“state”] = (stateOn) ? on_cmd : off_cmd;
JsonObject& color = root.createNestedObject(“color”);
color[“r”] = red;
color[“g”] = green;
color[“b”] = blue;root[“brightness”] = brightness;
root[“effect”] = effectString.c_str();char buffer[root.measureLength() + 1];
root.printTo(buffer, sizeof(buffer));client.publish(light_state_topic, buffer, true);
}/********************************** START RECONNECT*****************************************/
void reconnect() {
// Loop until we’re reconnected
while (!client.connected()) {
Serial.print(“Attempting MQTT connection…”);
// Attempt to connect
if (client.connect(SENSORNAME, mqtt_username, mqtt_password)) {
Serial.println(“connected”);
client.subscribe(light_set_topic);
setColor(0, 0, 0);
sendState();
} else {
Serial.print(“failed, rc=”);
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
}/********************************** START Set Color*****************************************/
void setColor(int inR, int inG, int inB) {
for (int i = 0; i < NUM_LEDS; i++) {
leds[i].red = inR;
leds[i].green = inG;
leds[i].blue = inB;
}FastLED.show();
Serial.println(“Setting LEDs:”);
Serial.print("r: “);
Serial.print(inR);
Serial.print(”, g: “);
Serial.print(inG);
Serial.print(”, b: ");
Serial.println(inB);
}/********************************** START MAIN LOOP*****************************************/
void loop() {if (!client.connected()) {
reconnect();
}if (WiFi.status() != WL_CONNECTED) {
delay(1);
Serial.print(“WIFI Disconnected. Attempting reconnection.”);
setup_wifi();
return;
}client.loop();
ArduinoOTA.handle();
//EFFECT BPM
if (effectString == “bpm”) {
uint8_t BeatsPerMinute = 62;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
for ( int i = 0; i < NUM_LEDS; i++) { //9948
leds[i] = ColorFromPalette(palette, gHue + (i * 2), beat - gHue + (i * 10));
if (transitionTime == 0 or transitionTime == NULL) {
transitionTime = 30;
showleds();
}//EFFECT Candy Cane
if (effectString == “candy cane”) {
static uint8_t startIndex = 0;
startIndex = startIndex + 1; /* higher = faster motion /
fill_palette( leds, NUM_LEDS,
startIndex, 16, / higher = narrower stripes */
currentPalettestriped, 255, LINEARBLEND);
transitionTime = 0;
showleds();
}//EFFECT CONFETTI
if (effectString == “confetti” ) {
fadeToBlackBy( leds, NUM_LEDS, 25);
int pos = random16(NUM_LEDS);
leds[pos] += CRGB(realRed + random8(64), realGreen, realBlue);
showleds();
}//EFFECT CYCLON RAINBOW
if (effectString == “cyclon rainbow”) { //Single Dot Down
static uint8_t hue = 0;
// First slide the led in one direction
// Set the i’th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
showleds();
// now that we’ve shown the leds, reset the i’th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(10);
for (int i = (NUM_LEDS) - 1; i >= 0; i–) {
// Show the leds
showleds();
fadeall();
delay(10);
}//EFFECT DOTS
if (effectString == “dots”) {
uint8_t inner = beatsin8(bpm, NUM_LEDS / 4, NUM_LEDS / 4 * 3);
uint8_t outer = beatsin8(bpm, 0, NUM_LEDS - 1);
uint8_t middle = beatsin8(bpm, NUM_LEDS / 3, NUM_LEDS / 3 * 2);
leds[middle] = CRGB::Purple;
leds[inner] = CRGB::Blue;
leds[outer] = CRGB::Aqua;
nscale8(leds, NUM_LEDS, fadeval);if (transitionTime == 0 or transitionTime == NULL) { transitionTime = 30; } showleds();
Please edit the post and put the sketch in side the code blocks.
//EFFECT FIRE
if (effectString == “fire”) {
Fire2012WithPalette();
transitionTime = 150;
showleds();
}random16_add_entropy( random8());
//EFFECT Glitter
if (effectString == “glitter”) {
fadeToBlackBy( leds, NUM_LEDS, 20);
addGlitterColor(80, realRed, realGreen, realBlue);
showleds();
}//EFFECT JUGGLE
if (effectString == “juggle” ) { // eight colored dots, weaving in and out of sync with each other
fadeToBlackBy(leds, NUM_LEDS, 20);
for (int i = 0; i < 8; i++) {
leds[beatsin16(i + 7, 0, NUM_LEDS - 1 )] |= CRGB(realRed, realGreen, realBlue);
transitionTime = 130;
showleds();
}//EFFECT LIGHTNING
if (effectString == “lightning”) {
twinklecounter = twinklecounter + 1; //Resets strip if previous animation was running
if (twinklecounter < 2) {
FastLED.clear();
FastLED.show();
ledstart = random8(NUM_LEDS); // Determine starting location of flash
ledlen = random8(NUM_LEDS - ledstart); // Determine length of flash (not to go beyond NUM_LEDS-1)
for (int flashCounter = 0; flashCounter < random8(3, flashes); flashCounter++) {
if (flashCounter == 0) dimmer = 5; // the brightness of the leader is scaled down by a factor of 5
else dimmer = random8(1, 3); // return strokes are brighter than the leader
fill_solid(leds + ledstart, ledlen, CHSV(255, 0, 255 / dimmer));
showleds(); // Show a section of LED’s
delay(random8(4, 10)); // each flash only lasts 4-10 milliseconds
fill_solid(leds + ledstart, ledlen, CHSV(255, 0, 0)); // Clear the section of LED’s
showleds();
if (flashCounter == 0) delay (130); // longer delay until next flash after the leader
delay(50 + random8(100)); // shorter delay between strokes
delay(random8(frequency) * 100); // delay between strikes
transitionTime = 0;
showleds();
}//EFFECT POLICE ALL
if (effectString == “police all”) { //POLICE LIGHTS (TWO COLOR SOLID)
idex++;
if (idex >= NUM_LEDS) {
idex = 0;
int idexR = idex;
int idexB = antipodal_index(idexR);
int thathue = (thishuepolice + 160) % 255;
leds[idexR] = CHSV(thishuepolice, thissat, 255);
leds[idexB] = CHSV(thathue, thissat, 255);
showleds();
}//EFFECT POLICE ONE
if (effectString == “police one”) {
idex++;
idex = 0;
int idexR = idex;
for (int i = 0; i < NUM_LEDS; i++ ) {
if (i == idexR) {
leds[i] = CHSV(thishuepolice, thissat, 255);
else if (i == idexB) {
leds[i] = CHSV(thathue, thissat, 255);
else {
leds[i] = CHSV(0, 0, 0);
showleds();
}//EFFECT RAINBOW
if (effectString == “rainbow”) {
// FastLED’s built-in rainbow generator
static uint8_t starthue = 0; thishue++;
fill_rainbow(leds, NUM_LEDS, thishue, deltahue);
showleds();
}//EFFECT RAINBOW WITH GLITTER
if (effectString == “rainbow with glitter”) { // FastLED’s built-in rainbow generator with Glitter
thishue++;
addGlitter(80);
showleds();
}//EFFECT SIENLON
if (effectString == “sinelon”) {
int pos = beatsin16(13, 0, NUM_LEDS - 1);
leds[pos] += CRGB(realRed, realGreen, realBlue);
showleds();
}//EFFECT TWINKLE
if (effectString == “twinkle”) {
if (twinklecounter < 2) { //Resets strip if previous animation was running
FastLED.clear();
FastLED.show();
const CRGB lightcolor(8, 7, 1);
if ( !leds[i]) continue; // skip black pixels
if ( leds[i].r & 1) { // is red odd?
leds[i] -= lightcolor; // darken if red is odd
} else {
leds[i] += lightcolor; // brighten if red is even
if ( random8() < DENSITY) {
int j = random16(NUM_LEDS);
if ( !leds[j] ) leds[j] = lightcolor;
}if (transitionTime == 0 or transitionTime == NULL) { transitionTime = 0; } showleds();
EVERY_N_MILLISECONDS(10) {
nblendPaletteTowardPalette(currentPalette, targetPalette, maxChanges); // FOR NOISE ANIMATIon { gHue++; } //EFFECT NOISE if (effectString == "noise") { for (int i = 0; i < NUM_LEDS; i++) { // Just onE loop to fill up the LED array as all of the pixels change. uint8_t index = inoise8(i * scale, dist + i * scale) % 255; // Get a value from the noise function. I'm using both x and y axis. leds[i] = ColorFromPalette(currentPalette, index, 255, LINEARBLEND); // With that value, look up the 8 bit colour palette value and assign it to the current LED. } dist += beatsin8(10, 1, 4); // Moving along the distance (that random number we started out with). Vary it a bit with a sine wave. // In some sketches, I've used millis() instead of an incremented counter. Works a treat. if (transitionTime == 0 or transitionTime == NULL) { transitionTime = 0; } showleds(); } //EFFECT RIPPLE if (effectString == "ripple") { for (int i = 0; i < NUM_LEDS; i++) leds[i] = CHSV(bgcol++, 255, 15); // Rotate background colour. switch (step) { case -1: // Initialize ripple variables. center = random(NUM_LEDS); colour = random8(); step = 0; break; case 0: leds[center] = CHSV(colour, 255, 255); // Display the first pixel of the ripple. step ++; break; case maxsteps: // At the end of the ripples. step = -1; break; default: // Middle of the ripples. leds[(center + step + NUM_LEDS) % NUM_LEDS] += CHSV(colour, 255, myfade / step * 2); // Simple wrap from Marc Miller leds[(center - step + NUM_LEDS) % NUM_LEDS] += CHSV(colour, 255, myfade / step * 2); step ++; // Next step. break; } if (transitionTime == 0 or transitionTime == NULL) { transitionTime = 30; } showleds(); }
EVERY_N_SECONDS(5) {
targetPalette = CRGBPalette16(CHSV(random8(), 255, random8(128, 255)), CHSV(random8(), 255, random8(128, 255)), CHSV(random8(), 192, random8(128, 255)), CHSV(random8(), 255, random8(128, 255)));
}//FLASH AND FADE SUPPORT
if (flash) {
if (startFlash) {
startFlash = false;
flashStartTime = millis();
}if ((millis() - flashStartTime) <= flashLength) { if ((millis() - flashStartTime) % 1000 <= 500) { setColor(flashRed, flashGreen, flashBlue); } else { setColor(0, 0, 0); // If you'd prefer the flashing to happen "on top of" // the current color, uncomment the next line. // setColor(realRed, realGreen, realBlue); } } else { flash = false; effectString = oldeffectString; if (onbeforeflash) { //keeps light off after flash if light was originally off setColor(realRed, realGreen, realBlue); } else { stateOn = false; setColor(0, 0, 0); sendState(); } }
if (startFade && effectString == “solid”) {
// If we don’t want to fade, skip it.
if (transitionTime == 0) {
setColor(realRed, realGreen, realBlue);redVal = realRed; grnVal = realGreen; bluVal = realBlue; startFade = false; } else { loopCount = 0; stepR = calculateStep(redVal, realRed); stepG = calculateStep(grnVal, realGreen); stepB = calculateStep(bluVal, realBlue); inFade = true; }
if (inFade) {
startFade = false;
unsigned long now = millis();
if (now - lastLoop > transitionTime) {
if (loopCount <= 1020) {
lastLoop = now;redVal = calculateVal(stepR, redVal, loopCount); grnVal = calculateVal(stepG, grnVal, loopCount); bluVal = calculateVal(stepB, bluVal, loopCount); if (effectString == "solid") { setColor(redVal, grnVal, bluVal); // Write current values to LED pins } loopCount++; } else { inFade = false; } }
}/**************************** START TRANSITION FADER ****************************************/
// From https://www.arduino.cc/en/Tutorial/ColorCrossfader
/ BELOW THIS LINE IS THE MATH – YOU SHOULDN’T NEED TO CHANGE THIS FOR THE BASICS
The program works like this:
Imagine a crossfade that moves the red LED from 0-10,
the green from 0-5, and the blue from 10 to 7, in
ten steps.
We’d want to count the 10 steps and increase or
decrease color values in evenly stepped increments.
Imagine a + indicates raising a value by 1, and a -
equals lowering it. Our 10 step fade would look like:
1 2 3 4 5 6 7 8 9 10
R + + + + + + + + + +
G + + + + +
B - - -
The red rises from 0 to 10 in ten steps, the green from
0-5 in 5 steps, and the blue falls from 10 to 7 in three steps.
In the real program, the color percentages are converted to
0-255 values, and there are 1020 steps (255*4).
To figure out how big a step there should be between one up- or
down-tick of one of the LED values, we call calculateStep(),
which calculates the absolute gap between the start and end values,
and then divides that gap by 1020 to determine the size of the step
between adjustments in the value.
int calculateStep(int prevValue, int endValue) {
int step = endValue - prevValue; // What’s the overall gap?
if (step) { // If its non-zero,
step = 1020 / step; // divide by 1020
}return step;
/* The next function is calculateVal. When the loop value, i,
reaches the step size appropriate for one of the
colors, it increases or decreases the value of that color by 1.
(R, G, and B are each calculated separately.)
int calculateVal(int step, int val, int i) {
if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive…
val += 1;
else if (step < 0) { // …or decrement it if step is negative
val -= 1;
}// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
}return val;
}/**************************** START STRIPLED PALETTE *****************************************/
void setupStripedPalette( CRGB A, CRGB AB, CRGB B, CRGB BA) {
currentPalettestriped = CRGBPalette16(
A, A, A, A, A, A, A, A, B, B, B, B, B, B, B, B
// A, A, A, A, A, A, A, A, B, B, B, B, B, B, B, B
}/********************************** START FADE************************************************/
void fadeall() {
leds[i].nscale8(250); //for CYCLon
}/********************************** START FIRE **********************************************/
void Fire2012WithPalette()
// Array of temperature readings at each simulation cell
static byte heat[NUM_LEDS];// Step 1. Cool down every cell a little
heat[i] = qsub8( heat[i], random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
}// Step 2. Heat from each cell drifts ‘up’ and diffuses a little
for ( int k = NUM_LEDS - 1; k >= 2; k–) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
}// Step 3. Randomly ignite new ‘sparks’ of heat near the bottom
if ( random8() < SPARKING ) {
int y = random8(7);
heat[y] = qadd8( heat[y], random8(160, 255) );
}// Step 4. Map from heat cells to LED colors
for ( int j = 0; j < NUM_LEDS; j++) {
// Scale the heat value from 0-255 down to 0-240
// for best results with color palettes.
byte colorindex = scale8( heat[j], 240);
CRGB color = ColorFromPalette( gPal, colorindex);
int pixelnumber;
if ( gReverseDirection ) {
pixelnumber = (NUM_LEDS - 1) - j;
} else {
pixelnumber = j;
leds[pixelnumber] = color;
}/********************************** START ADD GLITTER *********************************************/
void addGlitter( fract8 chanceOfGlitter)
if ( random8() < chanceOfGlitter) {
leds[ random16(NUM_LEDS) ] += CRGB::White;
}/********************************** START ADD GLITTER COLOR ****************************************/
void addGlitterColor( fract8 chanceOfGlitter, int red, int green, int blue)
leds[ random16(NUM_LEDS) ] += CRGB(red, green, blue);
}/********************************** START SHOW LEDS ***********************************************/
void showleds() {delay(1);
if (stateOn) {
FastLED.setBrightness(brightness); //EXECUTE EFFECT COLOR
FastLED.show();
if (transitionTime > 0 && transitionTime < 130) { //Sets animation speed based on receieved value
FastLED.delay(1000 / transitionTime);
//delay(10*transitionTime);
else if (startFade) {
setColor(0, 0, 0);
startFade = false;
void temp2rgb(unsigned int kelvin) {
int tmp_internal = kelvin / 100.0;// red
if (tmp_internal <= 66) {
red = 255;
} else {
float tmp_red = 329.698727446 * pow(tmp_internal - 60, -0.1332047592);
if (tmp_red < 0) {
red = 0;
} else if (tmp_red > 255) {
red = 255;
} else {
red = tmp_red;
}// green
float tmp_green = 99.4708025861 * log(tmp_internal) - 161.1195681661;
if (tmp_green < 0) {
green = 0;
} else if (tmp_green > 255) {
green = 255;
} else {
green = tmp_green;
} else {
float tmp_green = 288.1221695283 * pow(tmp_internal - 60, -0.0755148492);
green = 0;
green = 255;
} else {
green = tmp_green;
}// blue
if (tmp_internal >= 66) {
blue = 255;
} else if (tmp_internal <= 19) {
blue = 0;
} else {
float tmp_blue = 138.5177312231 * log(tmp_internal - 10) - 305.0447927307;
if (tmp_blue < 0) {
blue = 0;
} else if (tmp_blue > 255) {
blue = 255;
} else {
blue = tmp_blue;
Finally I did it, the problem was my contact with the din, I think it wasnt fixed enough I bought some trip conectors and now it´s everything ok tks everyone for everything.
you need to use this button when putting code in your forum post
its the sixth button from the left.
