Do you want to be notified when a new firmware is available [y] or not [n]? (y/n): n
thank you very much
that question would not be better YES, so that it warns in the future although it is necessary to prepare the firmware again of course…
thank you very much
Wouldn’t it be better yes?
Is it possible to get the video live stream of the bticino?
So i can take a picture everytime somebody rings?
did you get an answer to that?
May I do Step 1 Prepare and create firmware via python script using the same RPi where HA is running or should I use anoth way?
Probably my question is stupid but the true is that I don’t know how to perform step 1.
Any help is welcome
It’s fine on Linux (RPi) itself or whatever Linux you’re using.
I have used Synolosy NAS and everything was ok until the following command:
sudo python3 -m pip install -r requirements.txt
The error was:
Building wheel for pyminizip (pyproject.toml) did not run successfully
error: command '/usr/local/x86_64-pc-linux-gnu/bin/ccache/x86_64-pc-linux-gnu-wrap-gcc' failed: No such file or directory
any idea on what was wrong?
I think there is no need to generate such a file individually for each of us. I don’t understand why nobody has left the file already prepared to upload it to the computer, I will try to generate the file and leave a direct link to download it.
I guess this is because of copyright reasons. Anyway, I would be happy if anyone could share a patched or unpatched version of latest Classe100X-firmware version 1.5.5, as it’s not possible to download it anymore. ![]()
I just managed to patch the available version 1.5.1, but I don’t really want to flash an old version to my intercom ![]()
hi to all, bticino 300x now works with home assistant?
If not, can i use an other internal device that works? Thank, bye
Hello, I have tried to generate the modified firm for my bticino 300x but I have not succeeded, so I can not share it here, if someone gets it please share. The latest version of firm for bticino 300x is the 1.7.19 that in its original version is the following link:
I repeat, if someone has the 1.7.19 modified and working it would be great to share it here. @ptuk @fquinto
I’ve just found a download of version 1.5.5 (latest) for Classe100X. Anyway, have not tested it yet and I’m not sure it works for all WiFi capable Classe100X devices.
https://www.homesystems-legrandgroup.com/home/-/productsheets/4221129
Hi all, would this also work with the following display: BT-332851?
No news here?
Do not open that door ![]()
No news here ![]()
Does no one know of another method that is simpler or explained in more detail? I have not been able to understand it.
is there any news about DOOR ENTRY being deprecated and moving to the new NETAMO architecture?
I am also interested
Has anyone managed to integrate Classe100X16E with HA?
