People have been able to integrate the C100X with my c300x-controller and webrtc cards in HA (works with version 1.x firmware only though)
The only thing I managed to do is install a BT 346833 with a configurator 3 installed in MOD (You can see it in the photo) and then connect it to a relay connected to a clean contact (shelly for me) and be able to open the door with the home assistant as the home assistant. Here is a screenshot of the link.
naturally the intercom system must be installed normally… if there are particular configurations this could be a problem.
I have a BTicino Classe 300 with firm 1.7.19, I currently use the BTicino Door Entry app.
Is it compatible with this module?
Has anything been said or commented on whether these devices will be migrated to the new netamo cloud?
Is there any option to integrate these devices with HA?
P.D.: Just in case, I have installed this add-on and tried with my BTicino Door Entry app user and password and it gives me error.
Reading from the project no, you must have a netatmo device.
To make things slightly more clear for people, this is how it is today:
People with v1 firmware can flash a custom firmware by fquinto and use the c300x-controller to have a local API that handles opening locks, has an RTSP feed and Homekit. This also works for c100x.
People with v2 firmware (netatmo): at the moment there is not way to root or flash a custom firmware, but you can indeed use the integration bticino_intercom which uses the netatmo cloud api.
Thank you for your clarification! When installed the fquinto firmware, does the c300X still work with the door entry app?
Yes it does, it only activates dropbear (sshd) and adds a root2 user account (unless you also add the mqtt part, which is not recommend by him anymore).
I am using the Classe 300X in a rented flat… if I decide to flash the new firmware, can I reset it to the original, non modified firmware, when moving out? If yes, how could I do that?
is it possible to have this in english ?
sorry, only spanish in this moment!
Hi if you could get a new intercom/videocamera/gate opener for HA, would you go with this btcino?
Not questioning the product, but the integration into HA.
I am about to do the swap at an install and this looks like the best option, still lacking of features lie RTSP feed
alnavasa → hikvision …
thanks! looks like a good option
this is not BTicino
because the user was asking what would be a good alternative for a new video door phone.
Ok thanks you for the answer
Can you share your schema and parts?
