I know there has been some work done, but there is no official component yet.
I’m not a programmer so can’t help, but i can test. I have a full installation with, lights, dimmers, covers, heating, …
Regards
Regards
Are BTicino components usable into home assistant? If yes, which one?
Sandro,
I know your solution, the problem is that i’m new to Homeassistant and it not a componenent.
so It’s quite difficulte to figure out how you configure it withint HASS.
I want to create a dashboard like this:
But with your “version” of HASS, i don’t know where to start.
Would you consider to make a component for Myhome BT SCS for HASS.IO?
You can use two raspberry, one with Hassio another with Sdomotica, just put Sdomotica ip as mqtt component into hassio.
As you know Sdomotica has other softwares running and already configured for talk with BT.
Bye
Sandro
I would like to encourage you to try Julien’s custom component - Legrand/Bticino MyHome and maybe collaborate with him.
It is an old discussion, but I would like to concentrate everything on Julien’s work, which I think is on the right track.
