Thank you for your response!
I thought that the official API was via the cloud.
I’m thinking of buying Legrand Zigbee stuff (Valena Next with Netatmo series), but I don’t know yet whether to choose use it through the official gateway and integrate it using your addon in HA or using Zigbee2Mqtt, because I use some other Zigbee devices from other manufactures.
Do you still recommend using your addon in this situation?
Is the responsiveness quick with HA?
And…, is the addon compatible with Valena Next with Netatmo? Is it the same as Legrand Celiane with Netatmo?
Addresses from 51 to 59 are all energy sensors (Bticino F520)
The last two rows are not included in the generated sdomoticabticino.yaml file.
I know that F520 is not included in the manual but I’ve tried as a last chance.
F523 is included in the manual but is not shown in the home assistant interface because is not included in the sdomoticabticino.yaml file.
I’ve tried to comment the line control:hidden and the configuration has been validated, i can see the item “Finestra lavanderia P2” but his state is unknown.
Can you tell me what I’m doing wrong?
I have a doubt on the right value in “zone” attribute in the SecuritySystem type which is the requested value?
Bonjour,
je viens d acheter une maison équipée en domotique legrand et bticino. J ai un serveur F454.
Je peux piloter, les volets roulant, la lumière par un écran et une application myombox.
J ai aussi le système cosytouch qui me permet de piloter mon gainable à distance ( pompe à chaleur, clim atlantic)
J ai aussi un système d enregistrement vidéo de type comelit.
Tout est connecté en filaire.
3 applications différentes.
J aimerais avoir qu une seule application pour commander ma maison.
Avez-vous des conseils à me donner ?
Je n arrive pas à configurer sdomotica.
Y a t il une doc en français ?
Est ce que je peux récupérer la confit de myhome ?
so to make it clear, connecting to MyHomeServer1 and using Hometouch panel with Legrand Classe 300X Video Door System, is not supported by your gateway for HA ?
