So about the sub-buttons for thermostat, there’s no relevant service call. The only way I could figure out how to do it was through custom button cards as they support JS…
So I think it can be done without JS by making two scripts for each climate device (one to lower and one to increase temp), then making a service call to each script. However, this seems like a tiring solution.
A new card type making life simple would be much appreciated by noobs like me.
I’ve tried again with different themes with no luck, are you sure that you have the v2.0.0-beta.11? You can check that in the editor. If not just try to clear your cache.
It seems like a Safari/WebKit issue, even with cache cleared. I just tested it with other browsers and it works totally fine. Could you confirm this on your side also?
Go to HACS, front end, bubble card. Then click the 3 dots on the top right and redownload. Toggle on show beta versions, select the latest and you’re off.
Has anyone managed to get a good security/alarm control card going with bubble card? I’m struggling and just thinking of sticking with Mushroom for my security control for now
Hey, first thanks for this great project. I just wonder if there is a way to make a popup fit to its content dynamically. (auto height)
Some popups in my configuration are just filled with a small bunch of cards so there is much white space left.
