Hi @onkytonk,
I use an Alexa Routine to Arm the alarm via a node red flow which checks if the sensors are open except for the override sensors. i.e Front Door, Hallway Motion. I do this using a Group that lists all the sensors apart from those I want to override. In node red i check the state of that Group. If it is on then at least one sensor is open and the alarm will not Arm and Alexa responds with which sensors are open. If the Group is off then I know all sensors apart from the override sensor are off and then the alarm will Arm. Here is the Node Red flow I use:
[{"id":"e611d8f0.cde5f8","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"4d50ac10.aded9c","type":"template","z":"e611d8f0.cde5f8","name":"Format Friendly Name","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{payload.attributes.friendly_name}}","output":"str","x":880,"y":200,"wires":[["ef57d024.41c9c"]]},{"id":"ef57d024.41c9c","type":"join","z":"e611d8f0.cde5f8","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":",","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1070,"y":200,"wires":[["6eb9023a.f31fdc"]]},{"id":"7986cb1c.fce2f4","type":"ha-get-entities","z":"e611d8f0.cde5f8","name":"","rules":[{"property":"entity_id","logic":"is","value":"binary_sensor\\.((?!kitchen_door|study_door)(.*door.*)|(.*window.*))","valueType":"re"},{"property":"state","logic":"is","value":"on","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":690,"y":200,"wires":[["4d50ac10.aded9c"]]},{"id":"57a90e4a.a29cd","type":"api-call-service","z":"e611d8f0.cde5f8","name":"Alexa Sensors Open TTS","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\"Please close {{payload}} , then say, Alexa Goodbye, to set the alarm to away\",\"data\":{\"type\":\"tts\"},\"target\":[\"{{lastalexa}}\"]}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1430,"y":200,"wires":[[]]},{"id":"6eb9023a.f31fdc","type":"change","z":"e611d8f0.cde5f8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.data.message","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":200,"wires":[["57a90e4a.a29cd"]]},{"id":"d0d0a226.7462a8","type":"api-current-state","z":"e611d8f0.cde5f8","name":"State of Alarm Sensors","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"group.alarm_away_sensors","state_type":"str","state_location":"","override_payload":"none","entity_location":"","override_data":"none","blockInputOverrides":false,"x":490,"y":220,"wires":[["7986cb1c.fce2f4"],["32dec8d4.9935d"]]},{"id":"82ab5371.362fb","type":"api-call-service","z":"e611d8f0.cde5f8","name":"Arm Away","version":1,"debugenabled":false,"service_domain":"alarm_control_panel","service":"alarm_arm_away","entityId":"alarm_control_panel.house","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1430,"y":260,"wires":[[]]},{"id":"9bde7dd0.f6221","type":"server-state-changed","z":"e611d8f0.cde5f8","name":"Alarm Goodbye","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"script.1564690605365","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":120,"y":220,"wires":[["d043a31f.5b9cc8"],[]]},{"id":"32dec8d4.9935d","type":"api-call-service","z":"e611d8f0.cde5f8","name":"Alexa Goodbye","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\"All Windows and Doors are closed, Goodbye\",\"data\":{\"type\":\"tts\"},\"target\":[\"{{lastalexa}}\"]}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":700,"y":240,"wires":[["14a603a2.6655b4"]]},{"id":"af34d1e5.804f1","type":"delay","z":"e611d8f0.cde5f8","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1140,"y":260,"wires":[["82ab5371.362fb"]]},{"id":"14a603a2.6655b4","type":"api-current-state","z":"e611d8f0.cde5f8","name":"State of Vacum","version":1,"outputs":2,"halt_if":"docked","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"vacuum.victor_2","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":900,"y":260,"wires":[["af34d1e5.804f1"],["36edc3a2.f1e194"]]},{"id":"36edc3a2.f1e194","type":"api-call-service","z":"e611d8f0.cde5f8","name":"Arm night","version":1,"debugenabled":false,"service_domain":"alarm_control_panel","service":"alarm_arm_night","entityId":"alarm_control_panel.house","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1140,"y":320,"wires":[[]]},{"id":"d043a31f.5b9cc8","type":"api-render-template","z":"e611d8f0.cde5f8","name":"LAst Alexa","template":"{{ states.sensor.last_alexa.state }}","resultsLocation":"lastalexa","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":290,"y":220,"wires":[["d0d0a226.7462a8"]]},{"id":"ec85d738.90de18","type":"comment","z":"e611d8f0.cde5f8","name":"........................ Goodbye Script and Check Windows and Door Sensors ........................","info":"","x":344,"y":151,"wires":[]}]
