@schildgenb and anyone else interested in cross grouping between sensors - have a look here.
To anyone who wants this component to work with HA 0.103.0+ AND MQTT enabled.
The master branch is fixed now, but actually all you need is this file - just save it to custom_component/bwalarm/
overwriting the existing one and it should do the trick.
Iâll include that fix in the next release.
Special thanks to @John_Schutte for his help!
Itâs most definitely your theme not supporting this. Try the default HA theme, the sliders will appear
Thanks for fixing. Has this been tested on 104.x?
Iâm still on 0.103.0 so cannot comment.
However, itâs easy to update HA back nowadaysâŚ
Yes works for me on v0.104.1. All my alarm automations are still working. I dont use the side panel much but a quick check showed no issues with it.
Any idea how bwalarm is displayed on tablet ? i wasnt able to load the alarm page the way I want either in lovelace or appdeamon dashboard. If any one is using the alarm page, please share your code.
Sorry, what code are you talking about?
Could you elaborate this
I personally use this component on a 7" tablet that runs WallPanel for Android and opens directly http://hassio.local:8123/alarm
When I work on it, I open the same page on my computer and it looks more or less the same.
No special code or anything.
I checked wallpanel. It basically loads the entire tablet screen with the alarm page. I am looking for adding additional items to the screen.
First i tried with Appdaemon dashboard âŚcouldnot load the properly in iframe componentâŚ
didnt like the lovelace as well.
Looking for some examples where alarm page co exists with orher cards
Thanks Michael. That is exactly what i want to do .but couldnât do without a scroll bar and larger alarm panel buttons. I recently bought a firehd8 and will try the same. Do you mind sharing the lovelace code?
ui-lovelace.yaml
title: Home Control
# View tab title.
- title: Base
icon: mdi:home-outline
cards:
- type: iframe
url: http://x.x.x.x:8123/alarm
aspect_ratio: 100%
- type: glance
entities:
- binary_sensor.front_door
- binary_sensor.garage_door
- binary_sensor.kitchen_door
- binary_sensor.basement_door_and_glass
- binary_sensor.basement_bathroom
- binary_sensor.hall_motion
title: Alarm Sensors
columns: 3
- type: weather-forecast
entity: weather.dark_sky
- type: iframe
url: https://embed.windy.com/embed2.html?lat=xx.xx&lon=-xx.xx&zoom=11&level=surface&overlay=radar&menu=&message=true&marker=&calendar=&pressure=true&type=map&location=coordinates&detail=&detailLat=xx.xx&detailLon=-xx.xx&metricWind=mph&metricTemp=%C2%B0F&radarRange=-1
aspect_ratio: 75%
- type: iframe
url: http://www.clocktab.com/
apect_ratio: 20%
- type: shopping-list
title: To Do
- camera_image: camera.Camera1
camera_view: live
entities: []
title: Camera1
type: picture-glance
As I can see, youâre still using the version with that huge toolbar at the bottom.
Donât you want to give a new version a go?
When will the new version be available in hacs?
Well, it depends on what you call ânew versionâ
The one Iâm suggesting to try is the latest on Github - itâs marked as pre-release because there are many changes and I wanted people to try it and give me their feedback so I could adjust it before creating a release.
I assume you need to enable something like âshow betaâ in HACS settings to be able to install it.
You can even try the version from dev branch (in a way more advanced), but itâs in the middle of something as I canât do a lot at the moment. And you need to install it manually, no HACS here
I see this error quite often in logs @AhmadK do you know what it means?
Mon Jan 20 2020 14:25:31 GMT-0600 (Central Standard Time)
Unhandled exception
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 461, in start
await prepare_meth(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_fileresponse.py", line 340, in prepare
fobj = await loop.run_in_executor(None, filepath.open, 'rb')
File "/usr/local/lib/python3.7/pathlib.py", line 1203, in open
opener=self._opener)
IsADirectoryError: [Errno 21] Is a directory: '/config/resources/bwalarm/images'
I donât. Could you open an issue on Github and provide as much information about this error as possible (your OS/enironment/browser, consequences) to invstigate it further?
Isnât this a misunderstanding of what the buttons do? Doesnât âawayâ set the alarm to âarmed awayâ and âhomeâ set the alarm to âarmed - homeâ ?
thatâs correct
A question to the users of this alarm panel: do you use it (or have use cases for) with only usersâ passwords set (i.e without code
Iâm asking to get an idea if it is acceptable to have users configured but no master code set?
If it is, maybe there is no point to have that master one separately and itâs better to have everything in users
