New code installed and it seems to be working a treat
Forgot to mention, I pretty much only set and disarm the alarm through the android alarm panel iâve setup and wallmounted a rasp pi hardwired near the front door and screen plus iâve got an cheap android phone near the staircase.
Otherwise I just use the alarm panel in lovelace as I found the dedicated frame a bit clunky (although the override / warning of an open sensor is an absolutely incredible feature! WAF (wife approval factor) for the more complex tab to set the alarm doesnât fly need to keep it as simple as possible.
If we could get that override into the lovelace platform that would be amazing, I did notice someone mentioned something about an iframe into the front end which could be cool if we polish it.
Glad to hear your config is working again.
Thanks for the explanation regarding using the component in Lovelace mode.
To be honest, itâs pretty different to how the author designed it and Iâll need to investigate it further to see whatâs possible.
As itâs not a bug fix but rather a feature request, I canât promise anything soon because currently I just donât have enough time to do any serious development. Hope you understand.
hello. i installed bwalarm with no problems. i also have konnected component to manage sensors and siren. but i got 2 questions/problems. 1st is i cant set how long the alarm will trigger from the iu of bwalarm. no matter how long i set the seconds it triggers based on the timer set on the siren set in sensor config file. and second i cant figure out how to set i.ex. sensor triggers, siren hits for i.ex 300 seconds then turn off and if the sensor is still open to retriger the siren for 300 seconds
Well, I personally yet to start using it, but itâs unclear if there is any difference between Perimeter and Home mode. Anyone (before I dive into the code)?
Isnât it that you (the user) can define (in settings) a third âarmedâ option? You have armed away, home and perimeter? So for me:
away: any/all sensors would trigger an alarm, entry/exit doors would be a delayed alarm
home: all DOWNSTAIRS sensors would trigger an alarm
perimeter: only entry/exit doors would trigger an alarm + outbuilding motion
i know the bwalarm settings that you can change the time to the siren but it doesnt work. it still gets the time to trigger from the config file switches -pin7 name alarm the default value which is 300 secs
i got a simple nodemcu with some sensors flashed with konnected files with 3 sensors and 1 siren. all works as intended with normal manual alarm. with bwalarm i cant set the trigger time. no matter what.
also i want when a sensor is open to keep firing i.ex 3 mins straight then stop for a min then fire again 3 mins stop for 1 min then last time 3 mins. so its 3-1-3-1-3-stop
and also the delay for front door dont work for me even if i have set front door to a delayed state for 20 secs, it pops up a warning for a split sec then fires the alarm
its like something else overrides the settings of the bwalarm
Do you want to say that with the alarm.json above your siren will run for 300 seconds?
The value that defines that is trigger_time and as far as I can see you have it set to 6 seconds no matter the alarm mode.
Bwalarm has nothing to do with an sensors, it picks state changes from HA. And itâs the very first time I learn about inability to change bwalarmâs settings.
Try to delete the alarm.json file, copy the default alarm.yaml from the repo and try to configure it wit say, 1 sensor. Itâs quick and easy.
there is no such functionality in bwalarm - itâs designed to run for trigger_time and then back to armed state. If you wish, you can write automation that reacts to alarm.state change to triggered I presume, but I wouldnât recommend that.
If you press Away button, itâs 20 seconds before you leave. If you press Home or Perimeter button, itâs 0 (i.e immediate). Does it make things clear?
and the last thing. I donât know what is your automation for, but it looks like you are reacting to the sensorsâ change of state. If so, just set
initial_state: false
in all of these sensor-related automations and see if it changes the behaviour.
itâs bwalarmâs job and itâs already there.
you need to state which sensors bwalarm should react to (in alarm.yaml manually or via Settings - > Sensors) and thatâs it.
the only automation you need is reaction to alarm entity changing its state to disarmed, warning, triggered etc.
you need to enter which sensors trigger the alarm immediately and after warning_time in appropriate sections of Settings -> Sensors. as soon as you configure it, you should see it in alarm.yaml
you donât need any automation that reacts to your sensors triggering and tries to fire the alarm.
disable all of them or remove completely.
well the problem isnt that bwalarm dont work as expected. i counted that the title says triggered responds to the time you set. the problem is that the actual siren.
there is a switch for the siren. when i set in automations this
- id: alarm_triggered
alias: '[Alarm] Triggered'
- platform: state
entity_id: alarm_control_panel.house
to: 'triggered'
- service: switch.turn_on
entity_id: switch.siren_switch ```
it activates the siren but wont stop on time set on the bwalarm. i know there is something stupid i make but cant figure out
Oh dear. You switched your siren on, you need to switch it off.
There is more than one answer how to do that though.
I cannot provide my own version as itâs a bit special and redundant for many of normal users (I need to cycle my sirens like: 300 seconds in total, 30 seconds on then 10 seconds rest and so on). itâs obsolete after all :\
Itâs almost the same as your code, but the other way round
p.s please please enclose your code between three single back quotes when you post it - that preserves formatting. without that we wonât be able to help you any further.
oh damn it works now. what kind of sorcery is this. well i thought that the action from triggered to armed state should manage the switch to turn it off. thank you very much
i am onto this for over a week trying to figure it out. i could only set the component switch to a momentary to make it work. you are the man!
ps. i would like to see your take on that alarm cycle. i want someting similar. like 180 secs on 60 secs off 180 on and so on for like 10 mins or so. as long as the sensor is on just in case i got a problem with sensor like i had with the normal hardwired alarm
Just as an FYI, this is how commercial alarm systems work. If the siren time expires and the sensor is still in an alarm state, then the siren is re-triggered for its programmed duration again. Otherwise an intruder could simply wait out the siren time (if there was no one home) and then freely stay in the house silently.
