I have an underfloor heating which is controlled by a txm646R.
Unfortunately I can only configure the target temperate from +3 to -3 degrees according to the mode.
For example if the mode is “comfort” which is 22° I can switch to any value from 19 to 25 degrees.
Unfortunately it does not provide a calculated target temperature. So when I switch the knx bus only receives the setpoint. What I need to do now is to calculate my target temperature to show it on the climate card.
Rigth now my climate card looks like this:
It shows the mode “Komfort”, the actual room temperature and the setpoint. I want the calculated target temperature to be displayed instead of the setpoint.
Is there any possibility?
